Old 03-28-2014, 03:48 PM   #1
dejxx
dejxx's Avatar
Drives: FT-86
OFT back to stock
Hey there! this might be a dumb question, but whats the exact step by step to flash the car back to stock for service dealership with the OFT? Thanks a lot!
dejxx is offline   Reply With Quote
Old 03-28-2014, 03:50 PM   #2
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Step 1) Plug in OFT
Step 2) Select "TUNING"
Step 3) Select "WRITE"
Step 4) Select "Original File"
Step 5) Wait approx 5 minutes
Done
Old 03-28-2014, 04:01 PM   #3
Sirsimon
Sirsimon's Avatar
Drives: 2021 GR Supra A91 Edition
^ 2 minutes to an answer from the source himself - how's that for customer service? :-)
Sirsimon is offline   Reply With Quote
Old 03-28-2014, 04:14 PM   #4
dejxx
dejxx's Avatar
Drives: FT-86
Thats some customer service right there!!! FAST!!!! thanks a lot!!!
Old 03-28-2014, 11:38 PM   #5
DeviantBlue
I have a related question. If I copy the stock file on to the OFT, will I be able to make a back up of that file on my computer? I am concerned about that because I don't like the idea of loosing the only file that can bring my car back to stock configuration to be lost (broken tablet/corrupting the file).
Is this something I should be worried about?
DeviantBlue is offline   Reply With Quote
Old 03-28-2014, 11:55 PM   #6
Marusich
Marusich's Avatar
Yes you can copy to computer.
Marusich is offline   Reply With Quote
Old 04-20-2014, 10:38 AM   #7
Mytoyo
Drives: Lightning Red 86
Hi @shiv@Vishnu. Would you please advise also how to "unmarry" OFT to be used from one car to another?
Mytoyo is offline   Reply With Quote
Old 04-20-2014, 02:24 PM   #8
Shiv@Openflash
Drives: 2013 FRS
Sure. Just flash the original file to the ECU. Then connect oft to OF Manager and go to Erase Data section. Then erase data. After that, the OFT can be used in another vehicle. If for any reason the Erase Data function isn't selectable, let us lom and we can enable it remotely
Old 04-20-2014, 08:57 PM   #9
Mytoyo
Thanks a lot Shiv. OFT needs to be reopened the reinsert USB (after deletion of bin files) in order to have the erase data section available...
Old 04-20-2014, 09:08 PM   #10
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
this was exactly what i needed to know. had no idea about the erase data portion. hands down best upgrade for the money. its to bad the twins couldnt drive out of the box like it does on e85.
garfull is offline   Reply With Quote
Old 04-21-2014, 08:58 AM   #11
mid_life_crisis
Drives: FR-S 10 #103 AT
I'm sorry, I can usually figure out typos or odd abbreviations, but this one kicked my butt.
The reasonable guess would be "know", but that has the wrong number of letters.
Old 01-30-2020, 04:06 PM   #12
auryn79
auryn79's Avatar
Drives: Asphalt 2013 FRS
Originally Posted by Shiv@Openflash View Post
Step 1) Plug in OFT
Done
Anyone know if the engine needs to be started during this process?
I'm reverting ecu back to stock (currently using stage 1 tune) in order load a base CARB tune for newly installed FI via ECUtek.
Problem is I already installed all the hardware which was my mistake and I don't want to start the engine with new parts installed without the CARB tune.
Thanks
auryn79 is offline   Reply With Quote
Old 01-30-2020, 04:12 PM   #13
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Thanks
No, the ignition gets turned on, but the car should not get stared.
BigTuna is offline   Reply With Quote
Old 01-30-2020, 04:15 PM   #14
auryn79
auryn79's Avatar
Thank you.
Stock cat back exhaust Spencer Engine, Exhaust, Bolt-Ons 3 06-30-2015 10:10 PM
FS: FR-S Stock Cat-back Exhaust LOZZI Engine, Exhaust, Bolt-Ons 0 01-02-2014 02:53 PM
Thinking about keeping stock cat-back diss7 Engine, Exhaust, Transmission 12 06-17-2013 07:58 PM
stock OEM cat back exhaust and intake stout90 Engine, Exhaust, Bolt-Ons 2 06-02-2013 11:41 PM
Stock brz axle back norcal_brz Engine, Exhaust, Bolt-Ons 0 01-03-2013 08:09 PM
