Old 04-04-2014, 04:38 PM   #1
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
AFR in Closed Loop
Has anyone messed with the afr's in closed loop to increase MPG? I was reading on the mr2 forums that on closed loop they were running e85 as lean as 17 afr (on a wideband set for pump gas) to try to get some of the mpg back they lost. I don't know and think that i should run 93 pump that lean because egt would be high but i think we could run it leaner the 14.7 standard afr in closed loop fueling? Anyone try? I bet we could get close to 40 mpg?
Toyota John is offline   Reply With Quote
Old 04-04-2014, 05:49 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
I don't think you can set the CL fueling tables to leaner than 14.7. The only way to do it would be to offset the O2 sensor scaling.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-04-2014, 07:50 PM   #3
arghx7
Drives: car
For what it's worth, I did it a long time ago on a 2005 Legacy GT with an older version of Cobb Accesstuner. There were some tables labeled as closed loop target AFR on that version (this was before Bill from RomRaider joined Cobb and redid a bunch of stuff). I leaned it out enough to help gas mileage but not enough to cause misfire. I just dug up an old screenshot of a log I made.
arghx7 is offline   Reply With Quote
Old 04-04-2014, 08:08 PM   #4
gonzo
Drives: frs
This would be amazing. I'm thinking of flashing back to 91 with this e85 price increase. It was $3.20 just a few weeks ago and now $3.70. And I'm only getting 14-16 mpg
gonzo is offline   Reply With Quote
Old 04-06-2014, 12:52 AM   #5
Toyota John
Calle Atun
I talked to my turner friend and he said the only way he got it to work was to turn off O2 feed back. But this wasn't on an frs. I think he said it was on an older sti. The mr2 guys that were doing it didn't have the ability to change closed loop fueling but they could turn it off and run from just the fuel table. I would like to try and see if I can change closed loop and have it make a change.
Old 04-06-2014, 05:01 AM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
AFAIK you can't set the open loop fuel table to leaner than 14.7 too so even if you running full time open loop you can't do it. Unless of course you skew the MAF scaling....
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-06-2014, 10:02 PM   #7
Toyota John
Calle Atun
I tried to change the closed loop fueling table and nothing happened. AFR stayed at 14.7. I guess that table does nothing? The main fueling table can not be changed to anything higher then 14.7 ether. Only lower numbers are accepted.
Old 04-07-2014, 03:20 AM   #8
Kodename47
Kodename47's Avatar
Drives: UK GT86
From what I've read on previous ECUs, the CL fueling table is basically CL enrichment. There was a table to set the base CL fuel target as @arghx7 said. However this may not be the same on our ECU, it's not been defined yet if it is.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-07-2014, 01:40 PM   #9
Ross
Drives: 85 corolla gts
You would have to completely disable the factory closed loop system to do this. It is doable, I have not done any long term testing so I can not give a good answer on reliability.
Ross is offline   Reply With Quote
Old 04-07-2014, 01:54 PM   #10
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
man thats low mpg. my average on 93 pump is 30.5. average on e78-85 is 24. i reset it once a week and calculate when i fill up so i know the gauge is somewhat accurate. my driving is about 50/50 highway/city.
Old 04-07-2014, 07:29 PM   #11
mad_sb
Drives: 2013 Asphalt FR-S
Actually, you don't have to disable anything.
you can do this using the coolant temp based target offset tables. I forget the names right now. As others have said the closed loop target afr is not what the name would indicate and you cannot set a value leaner than 14.7 without error. I saw some strange fuel trim stack-up when i messed with it and have not bothered to try again.
Old 04-08-2014, 09:13 AM   #12
Toyota John
Calle Atun
The more I learn about this car the less i seem to understand.
Old 12-14-2015, 04:53 AM   #13
Kodename47
Kodename47's Avatar
Drives: UK GT86
Thread revival. Thought that this is the best place for this. Having some wierd closed loop fueling issues that I've finally decided to tackle, seems like the ECU targets around 13.8 for a while before reverting to the CL fuel table target, which I have set mostly to 14.7. You can see in the graph below that the AFR tracks pretty well, but it always goes to 13.8 when changing to Fuel System Status 2.
Blue is Commanded AFR / Yellow is AFR
This chart the load and RPM are not changing much, in fact the earlier part of the chart is at lower RPM and loads so should be hitting 14.7.
I have tried changing the minimum open loop enrichment value and the closed loop targets are never that rich.
Map is A02G
I'm no running a rear O2 sensor, I wonder if that makes a difference?
Ideas?
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-16-2019, 07:24 PM   #14
504
504's Avatar
Drives: 2014 86 GTS
Map is A02G
Ideas?
Did you find a solution to this? I'm having similar issue as my fuel goes down to E3 (flex tune). 13.7 commanded on light cruise then when idles, it shoots back to 14.7, it's pretty annoying
Certain, my closed loop fuelling is not targetting lower than 14.7 and temp comps are all set to 0
504 is offline   Reply With Quote
BRZedit Fuel Trims, Closed to Open loop transiton mad_sb Engine, Exhaust, Transmission 32 08-06-2015 04:14 AM
Closed Project Kick Revo Lug Nuts (closed) ARP Extended Lugs Sportsguy83 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 02-25-2014 11:46 AM
Screencast: closed loop boost control with RaceRom jamesm Software Tuning 2 02-10-2014 03:23 PM
Screencast: experimenting with full-time closed loop fueling jamesm Software Tuning 2 12-27-2013 11:19 AM
i've been out of the loop! VenomRush Off-Topic Lounge [WARNING: NO POLITICS] 0 02-16-2013 12:25 AM
