Drives: 2013 FRS
Hi guys,
Here are the results from last week's TQ250 testing. This is with the dual pack battery set-up and the auxiliary charger. For those who know, I was also testing the TQ300 a while ago but now back to the TQ250 since it's a lot less current hungry and also seems to be noticeable more responsive and torquey ![]() 2013 FRS 6MT Mods: OpenFlash Tablet OpenFlash Header Single tip cat-back Modified air duct 93oct (although the it's mapped conservatively enough to make the same power on 91oct) [Stock run shown for reference] ![]() Testing conditions were quite a bit warmer than the least dyno results I posted (75F vs 50F) so that is probably costing us a few hp compared to before. So it's hard to quantify just how much the dual battery packs are helping. If I had to guess, I'd say the extra current is probably worth 7-10hp all other things equal. But where the extra juice really helps is on the road. Spool up seems to be quicker and I can run the car HARD without seeing voltage go below 21.5v during WOT. In my backroad testing location, I could routinely get the single battery back setup to go below 19v. Keep in mind that these testing conditions are unlikely to be seen by anyone running on normal roads. I just happen to live near some pretty spectacular farm roads that are largely uninhabited (and in Mexico of course!). Also worth mentioning is the auxiliary charger which works rather brilliantly. Even with I'm able to get voltage to drop to 22v, it only takes several seconds of off-boost conditions for it to climb back up to 28v again. Engine Bay: ![]() 4 Batteries (relocated the factory batter to the trunk): ![]() Aux Charger: ![]() Tomorrow, I'll be posting up new TQ250 tune files that will work with both 2 battery and 4 battery setups. My apologies to those who emailed me asking for maps in the last few days and have not gotten a response. I've been out of the office wrapping up the final calibration ![]() Cheers, shiv |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Phantom TQ250 Dyno FBO (Dual Battery Pack)
LOL. I literally just posted about this in the crawford posting. Thanks for the heads up on this. Will the new maps include e85? (Answered in other thread. Work to be done on the power blocks first then esc) Those numbers look about the same as my setup on e85. Its amazing what the dual battery setup was able to push. Nice job shiv.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel Last edited by Sojhinn; 04-07-2014 at 03:38 AM. |
Drives: 2013 FRS
with Crawford Billet Power Blocks
Also, we had the opportunity to test the Crawford Billet Power Blocks on the dyno as well. Both with and without the Phantom ESC.
Here are the results with and without the BPB. Running the same map. Run 243 is without the BPB. Run 246 is with the BPB. ![]() While the BPB work very well with an NA set-up, they don't seem to have the same positive effect when boost is added to the equation. That's not too surprising but it's interesting nonetheless. With the BPB, you can see a small gain in the 6000-6500rpm range but a loss everywhere else. I suspect we could have custom tuned 6500-7500rpm range to pick up the lost power but that remains to be proven. Still, I'm looking forward to more testing/tuning. Anything is possible ![]() Cheers, Shiv |
#4 | |
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
Drives: 2013 FRS
Drives: Fiat Abarth
Edited due to me being an ass.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel Last edited by Sojhinn; 04-07-2014 at 03:09 PM. |
Thanks again. |
#10 |
Shiv, something I've been wondering about is how can we artificially induce some form of "boost control" with something like the on/off ESC. What are your thoughts on implementing the following? Is this doable? |
#11 | |
Are you talking about controlling the ESC with this or just close the throttle so you make less power? Seems like it is complicating something that is otherwise very simple. My guess is that it will lead to driveability issues. Do you have a ESC installed on your car currently? |
#12 | |
#13 | |
You know what I'm sorry too. I had a bad morning and I took it out on you. Sorry bro.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel Last edited by Sojhinn; 04-07-2014 at 03:19 PM. |
#14 | |
I don't have an ESC, but I have been considering it. One of the holdups for me is the lack of proportional control which would become an issue during autox, I'm quite certain of it. This post elaborates a bit on my concern: http://www.ft86club.com/forums/showp...postcount=4142 What this idea is trying to accomplish is to provide some modulation of engine torque after the ESC is engaged so you can balance the car with the throttle. This is shown via the manifold pressure line on the plots I posted. I completely realize that there would be more to this than just a modification of the drive by wire tables. I also expect the hysteresis of the pedal switch to be a bit of an issue. That being said, it's just an idea of mine that I've been kicking around for awhile. The ultimate solution is proportional boost control via ESC speed control. ESC engagement could still happen at 50 or 75% throttle position, but the boost, thereafter, be proportional with throttle position. |
| J2 Engineering Catback Dual Exhaust system, dyno? | rhythmM | Engine, Exhaust, Transmission | 18 | 11-17-2015 06:53 PM |
| Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package | KCMachine | Brakes, Suspension, Chassis | 111 | 10-08-2014 09:26 AM |
| Phantom Superchargers | VR46 | User/Vendor/Sponsor Reviews, Feedback, Comments | 5 | 05-22-2014 10:03 AM |
| Battery tray for Braille 21lb battery? | lordtakuban | Engine, Exhaust, Transmission | 4 | 09-10-2013 09:55 AM |
| TR-B1500 battery and billet battery tray install. | mines13 | DIY (Do-It-Yourself) Guides | 8 | 12-07-2012 04:59 PM |
