Drives: Hot Lava Scion FRS
Left turn signal not working.
Hey guys not too sure if this is the right spot to post this but here it goes.
Yesterday I installed my winjet headlights but now my left turn driver's side signal doesn't seem to work. The light turns on when I turn on my night time lights but it doesn't seem to flash for my hazards, left turn signal or alarm. I tried replacing the flasher and also putting back the stock lights but still not luck. Any ideas? Thanks! on the side note - these lights look great! |
Did you check the rear bulb?
how about the right side? Normal flash?
Did you check your wiring going into the socket on that side to make sure it's still connected?
Check the bulb too, put it in the other side to test it Nick C.
Drives: Grocery cart
Sounds like a bad bulb for the front.
SOLD: 2014 BRZ Limited WRB 6 Speed.
Update?
Garage must have exploded and took down his interwebs.....
#10 |
#11 |
Drives: 2014 FRS Raven. 2011 sti red (gone)
#12 | |
Hey, so yes I ended up fixing the issue. I think when I removed the bumper I damaged the bulb somehow so it wasn't flashing. I just replaced it with a brand new bulb and it was good to go. |
#13 |
Hmm. Alright.
I'm have a very similar issue, but the bulb comes on with the parking lights. |
#14 |
Drives: Asphalt Scion FR-S
It's a dual filament, so the turn signal portion isn't working.
| FRS turn signal mods | subiestyle | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 03-07-2014 02:34 AM |
| Crystal eye tails turn signal not working. | FRSfan111 | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 01-06-2014 06:54 PM |
| My front turn signal lights not working after shop installed LED DRL bezel | speedy racer | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 10-11-2013 06:08 PM |
| Left fog light stopped working 2 days after LED switch, possible culprit? | tracerit | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 09-18-2013 01:41 AM |
| Anyone seen these turn signal/drl less? | djliquidsteele | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 07-15-2012 04:32 AM |
