| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Back Up Camera
Anyone install a backup camera that displays on the radio / gps head? On a Canadian 2013 BRZ?
Thanks |
Drives: 2013 Subaru BRZ
Canadian spec comes with a pioneer AFAIK. Pioneer radios have an RCA input on the rear for back-up camera. You can use the same process for mounting and running the camera wires as US spec models, except you will want to tap the camera turn on to the reverse wires at the tail lights and just plug the RCA into the HU.
Build Thread:
http://www.ft86club.com/forums/showthread.php?t=43355 |
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
Yes...SEARCH is your friend....
Drives: 14BRZ
Anyone know a local dealer that can install a back up camera in Toronto?
Drives: SOLD...
c&c motors in Whitby, auto links in scarborough
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018 and its gone... Sept '18 tho I am sure I will miss it Replaced with 18 50th edition ND ![]() |
Drives: BRZ Limited
you'll need the pioneer harness. your reverse camera will have a yellow RCA input, red wire and black wire. yellow RCA will plug into the brown RCA output wire from the pioneer harness. Black wire goes to ground (any screws will do), red wire taps into the 16 pin connector harnesss (orange wire), lastly, to get the reverse signal, you take the purple wire from the main Head unit harness and you splice it with a unused 26 pin connector harness (orange/white) wire, pin slot number 2
here's the harness that you'll need [ame="http://www.amazon.com/Replacement-Assembly-Harness-Pioneer-X9310BT/dp/B0088HRFJG/ref=sr_1_3?ie=UTF8&qid=1398022470&sr=8-3&keywords=pioneer+x930bt+harness"]Amazon.com : Subaru Replacement RCA Cord Assembly AV Radio Harness for Pioneer Avic X9310BT. : Vehicle Wiring Harnesses : Car Electronics[/ame] FYI, you can also bypass your navigation system by unplugging the yellow MUTE wire and moving it up one pin slot then grounding the wire to your head unit screws. This allows you to use your navigation while your car is in drive, also allows you to watch movies anytime
Drives: 2013 Subaru BRZ Limited in DGM
Does the stock head unit in the US have the ability to hook up a backup camera so easy? I thought that I had read that it is, but searching does not give me much info.
Drives: 2013 BRZ Limited WRB
Maybe this can help you, I'm wondering the same thing ..
You didnt search hard though ... come on buddy, us canadians are suposed to be nice and stuff !! http://www.ft86club.com/forums/showthread.php?t=61660 |
| Back up Camera | Wilson15 | CANADA | 13 | 01-14-2014 08:49 PM |
| Back up camera on BRZ? | rip curl | CANADA | 8 | 10-05-2013 05:07 PM |
| FS: JDM BRZ Back-Up Camera | Beyer Subaru | Audio/Visual, Electronics, Infotainment, NAV | 3 | 06-21-2013 11:55 AM |
| OEM Back up Camera | Perihelion | Electronics | Audio | NAV | Infotainment | 11 | 03-25-2013 05:49 PM |
| DIY back-up camera? | SloS13 | Electronics | Audio | NAV | Infotainment | 5 | 02-24-2013 02:14 AM |
