Old 05-17-2012, 02:25 AM   #1
TwinscrollGT35R
Drives: 2006 Subaru
Exclamation Vs. threads....
What the hell is up with all these FR-S vs _______ threads.
Its a car, its a car built with light weight, rwd and fuel econ. Not big performance. Sure the aftermarket has picked up in a big way. Like no other car I have seen. But its still a 155whp car.
Its not going to tackle the 300+hp cars. Id really start thinking of it in the lines of the Lotus Elise. Build the crap out of the handling and braking. Learn how to carry corner speed. That is going to be a huge key in this car.
You will own a ton of cars at the track. I see it all the time with the miata. That little car has a small under powered motor. Slap some quality handling bits on with brakes and in the right hands everyone is chasing it. And do not go cheap on tires. Seems like everyone goes cheap on tires. A brake system is only as good as the tire holding the ground.
If I had to build up a FR-S today.
Cat-back (so I could hear what rpm at the track)
Brake lines (better pedal feel)
Clutch lines (better pedal feel)
Brake Fluid (higher boil point)
Brake pads (good bite and less fade)
Sway bars (improve handling while decrease weight)
Coil-over (unsprung weight reduction, proper suspension set up)
Wheels and Tires (unsprung weight reduction, larger contact patch)
And get the corner weight set and top it off with a quality wheel alignment.
This car would out handle almost all the cars in these FR-S Vs. _____ threads.
And a quality track day drivers school can go a very long ways!! With that being said.... you would not have to concern yourself with big power.
These cars are not built for drag racing. These are road cars. Polish them up so they car shine.
TwinscrollGT35R is offline   Reply With Quote
Old 05-17-2012, 02:36 AM   #2
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Most member feels the same... BUT that doesn't mean they won't compare em with other RWD or other sports car.
We had WAY too much comparison thread was made and our boss had it enough, so he made a section just for it.
Simple as that
Old 05-17-2012, 02:37 AM   #3
Capt Canuck
Drives: BMW E36 323is
Are you new to interweb car forums?
Pretty common construct really, every forum has them. Think everyone knows the value/lack of value in them.
Simple enough to not read them
Capt Canuck is offline   Reply With Quote
Old 05-17-2012, 03:02 AM   #4
Dimman
Kuruma Otaku
Dimman's Avatar
Troll traps.
Because titanium.
Old 05-17-2012, 03:04 AM   #5
TwinscrollGT35R
Drives: 2006 Subaru
Simple as that
Its all good. Its good to get people posting. Mine was more to get people thinking about how they can make them or their car better then those "other" cars.
Yes sir I am new to the internet. What is interweb car forum? Is it like this place here or does it have all the car brands?
Old 05-17-2012, 03:19 AM   #6
fatoni
Wheels and tires wont change the contact patch size. Not worth mentioning anyways. Vs threads are important because people care about cost v benefit
Old 05-17-2012, 03:53 AM   #7
TwinscrollGT35R
Drives: 2006 Subaru
Old 05-17-2012, 05:07 AM   #8
serialk11r
Drives: '06 AM V8V Coupe
Errr, yes they will? If tires were a flaccid piece of rubber then yea, air pressure would be the only thing that matters, but real tires have thick tread blocks and steel reinforcements everywhere.
Old 05-17-2012, 11:42 AM   #9
fatoni
If you read the whole post I think ill sound less stupid or maybe youre confusing sizes and shapes
Old 05-17-2012, 11:48 AM   #10
fatoni
I know they will but it isnt a very significant factor. Its like saying body roll affects weight distribution. I know what tires are made of and you can deform them with your bare hands which, relative to the forces exerted by a car, arent worth mentioning. If a tire was rigid you would have a contact line instead of a patch. The structure of a tire becomes important as you drop in pressure I dont see that as a practical argument
Old 05-17-2012, 07:30 PM   #11
serialk11r
I dunno, I'm curious to see real data on this. Can you really deform the tread part by hand? I doubt it... The reinforced part of the tread it seems to me would have a more complex interaction with air pressure.
Old 05-19-2012, 03:42 PM   #12
fatoni
the thing is that it is really hard to find real data with a margin of error smaller than what the results would show. things like tread weight and tread wear are always kind of changing. a wider tire will usually be stickier per any given tread wear rating because that should make the contact patch shorter front to back. what that means is that the tire can cool off more quickly so it would last longer. i dont really get it all but i think that tires have been designed to have air pressure be the primary factor at normal situations. as you go up or down in pressure i think that the other variables come in to play
Old 05-19-2012, 04:32 PM   #13
Midship Runabout
formerly Dixie Normous
Midship Runabout's Avatar
Drives: The ladies wild!
Such a simple answer is getting waaaaay over complicated. Wider wheels allow wider tires. Wider tires equal larger contact patch. That simple.
Midship Runabout is offline   Reply With Quote
Old 05-19-2012, 09:45 PM   #14
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
This is certainly right.
Who would argue that a larger tire doesnt have a larger contact patch? Take a civic with 185s then a 911 with 235s, the naked eye can notice the difference.... driving it is even more impressionable.
chulooz is offline   Reply With Quote
Finally Got Mine...Yep Another One of These Threads! kmbkk Scion FR-S / Toyota 86 GT86 General Forum 15 05-25-2012 12:49 AM
