Drives: 2013 Scion FR-S (HKS SuperCharged)
FS: HKS Supercharged 2013 FR-S. 482 ORIGINAL miles, $20k+ in mods, White with wrap.
MANY more pictures and details can be found here:
http://www.speedforsale.com/viewcar/?vid=533 PRIVATE PARTY SALE, NOT A DEALER! General Info: This like new HKS Supercharged 2013 Scion FR-S has only 482 ORIGINAL miles, $20,103 worth of aftermarket upgrades (NOT including thousands more in labor and dyno tuning costs) from all premium high end brands, a factory warranty, a 6-speed manual transmission, the optional factory ‘Whiteout’ paint upgrade with a custom vinyl wrap on it which can be removed, and black suede interior with red stitching accents on the seats/doors/steering wheel/shift boot. It still has the factory catalytic convertors and NO check engine lights, so yearly inspections and emissions tests are no problem! Our company, SpeedForSale Motorsports, built this car for the Motovicity ‘Ticket To Ride’ contest and track day at Irwindale Speedway road course in California where it was driven by 2013 Formula D Champion Michael Essa and Tyler McQuarrie to test it’s before-and-after performance with all of the new upgrades listed below. This FR-S beat a similarly modified 2013 Mustang GT V8 by almost 1 second on the road course and took only 102 feet to stop from 60 to 0 MPH! You can find complete details from the blog MotoIQ.com about it’s build from a brand new stock FR-S to the reliably built street car and part-time track day animal it is now by viewing the links shown below. Here is a quote from the track day comparison article regarding this FR-S compared to the modified Mustang GT V8: “The Ticket To Ride FR-S was also greatly improved and being lighter on its feet, was still the preferred car by our drivers.” It made a conservative 220 wheel horsepower (about 260 HP at the crank with a light 2800 pound weight) at 6psi of boost on our Mustang-brand dyno using 93 octane gasoline with the STOCK fuel injectors and catalytic convertors. So, it has much more power to be had with a simple fuel injector upgrade, race exhaust header and mid-pipe, and removal of the HKS Supercharger’s intake restrictor which limits boost by 2-3psi. It starts and drives just like a factory FR-S with no compromises. The vinyl body wrap on it can be removed, and we still have all of the original Scion/FR-S badges to put back on the body. It has ALL matching VIN tags in place, and has never been in any wrecks or had any damage/paint work. The car has no leaks or smoke. It’s like a brand new factory built performance model that Scion never offered…but should have! Special thanks to Motovicity Distribution for the opportunity! Modifications: • REMOVABLE Custom Vinyl Body Wrap. The OEM paint color underneath is the factory upcharge color called ‘Whiteout’, which is a beautiful pearl white. • All major OEM parts which were upgraded are included with the car, including the original OEM wheels and tires, seats, exhaust, intake, etc. • HKS Supercharger Complete Kit (Supercharger, front mount intercooler, Super Mega Flow air filter and intake system with MAF housing, Bypass valve, Supercharger oil cooler, intercooler hard pipes, front mount power steering cooler, much more!) $4750 • HKS F-Con fuel/ignition timing control piggy back unit for stock computer. OBD2 diagnostics and emissions checks still work like factory! • HKS Legamax Premium Exhaust System (part# 32018-AT040) $1600 • Exedy Stage 2 Cerametallic clutch kit, 300 ft/lb torque capacity (part# 15953FW) $829 • Sparco Fighter seats, Red color with black accents. Driver and Passenger seats and bases are included, but not shown in some of the pictures! (part# 00954RS) $1320 • Sparco seat bases/sliders $600 • Eibach Pro Street-S adjustable coilovers with remote reservoirs (part# 82105.711) $2170 • StopTech Sport Kit: Front and Rear brake items included are slotted rotors, brake pads, stainless steel braided brake lines (part# 977.44016) $855 • Advan RSII Lightweight wheels with Racing Hyper Black finish, 18” x 9.5” size, +42mm offset $2864 • Muteki Forged Steel Super Tuner Lug Nut Set, black $65 • Yokohama S.drive tires in 255/35/18 size front and rear $800 • SpeedForSale Front Mount Engine Oil cooler with thermostatically controlled Mocal oil cooler sandwich plate, B&M core, and -10an braided hoses mounted behind passenger side front bumper duct $750 • SpeedForSale Boost Cut Control Device to prevent MAP sensor trouble code when over 0psi MAP signal $119 • AEM High Flow Fuel Pump (part# 50-1000) $141 • AEM AQ-1 Data Logging System (part# 30-2500) $520 • AEM AQ-1 Flying Lead Wiring Harness (part# 30-2906-96) $363 • AEM Wideband and Boost Pressure Failsafe gauge (part# 30-4900) $424 • AEM digital oil pressure gauge (part# 30-4401) $283 • AEM digital oil temperature gauge (part# 30-4402) $245 • Garmin GPS unit connected to AEM AQ-1 datalogger to track the car’s exact position on the race track or anywhere else $75 • MANY hours of very meticulous and neatly ran/spliced wiring went into the datalogger and gauges, as you can see from the MotoIQ blog entry shown below. • Custom USB port for AEM AQ1 and toggle switch for data logging ON/OFF mounted neatly in arm rest area. $150 • Triple Gauge Pods on complete driver’s A-pillar replacement panel, along with matching color passenger’s side A-pillar panel $300 • Energy Suspension urethane shifter bushing (part# 8.1105) $30 • Energy Suspension urethane rack and pinion bushing set (part# 8.10105) $24 • Energy Suspension urethane front lower control arm bushings (part# 8.3131) $67 • Energy Suspension urethane rear control arm bushing set (part# 8.3130) $173 • Energy Suspension urethane front anti-sway bar bushing set (part# 8.5138) $23 • Energy Suspension urethane rear anti-sway bar bushing set (part# 8.5139) $140 • Royal Purple engine oil $40 • Royal Purple 75w90 Synthetic Gear Oil in rear differential $35 • Motul RBF600 brake fluid $38 • Professional aggressive street alignment for best mix of performance and low tire wear $150 • Whistler radar and laser detector (needs new suction cups for window mount) $100 • Professional installation labor of all parts cost many thousands of dollars extra • All OEM dealer delivery window sticker, owner’s manuals, blue protective delivery tape on door sills, airbag warning label, front license plate mount (still new in plastic), and two extra spare keys (one ‘smart’ and one ‘regular’) included. Like a brand new car! Links to April 2014 media and blog posts: 1. Built Part 1: http://www.motoiq.com/MagazineArticl...ld-Part-1.aspx 2. Build Part 2: http://www.motoiq.com/MagazineArticl...ld-Part-2.aspx 3. Track testing versus a modified Mustang GT and stock FR-S at Toyota/Irwindale Speedway in California (driven by 2013 Formula D Champion Michael Essa and Tyler McQuarrie): http://www.motoiq.com/MagazineArticl...-Shootout.aspx 4. Video Coverage of the track testing: [ame="http://www.youtube.com/watch?v=ZyYSTgFjIoI"]Motovicity's Ticket to Ride: Performance Shootout - YouTube[/ame] Conclusion/contact info: My name is Jeremy Blackwell (extension 100), so please ask for me if you call. This car is being sold as a PRIVATE PARTY sale, NOT as a car dealership. However, we can refer you to a sports car financing company if you need financing. We are a performance and tuning shop in the Atlanta area and have sold 100+ high end sports cars over the last 13 years...from Supra to Viper, GT-R to Lotus, we specialize in forced induction and performance cars. We get wholesale pricing on performance parts and will sell the person who buys this car any parts they want at better prices than they will find anywhere, as well as provide them with technical assistance and advice on modifying and caring for the car. Also, we can install whatever parts you need at great labor rates. We offer dyno tuning, custom fabrication, and more, so the sky's the limit as far as what we can do with this car if you want more upgrades prior to delivery. You can view some references of people who have purchased sports cars from us in the past by clicking here on this link. I often speak with many people we have sold cars to, and they can tell you how much we help them with parts selection, troubleshooting, etc. If you need financing, we can refer you to a specialty car loan company. We will set up shipping of the car to anywhere in the world at your expense. We are asking $29,900 for this top quality and nearly new FR-S. If you want the OEM seats and/or wheels installed instead of the aftermarket seats/wheels, we can reduce the price a little bit. But, we will NOT part out any of the other items on the car. Feel free to email me any other questions at Blackwell@SpeedForSale.com , call 770-777-4774 extension 100, or AOL instant message me at 'JeremyJBlackwell'. We are in NO rush to sell the car, so please remember that we are not going to jump on a cheap offer. This Supercharged FR-S will be sitting in our shop, waiting. Thanks, and let us know if we can assist you in any way! ![]() ![]() ![]() ![]() ![]()
Free bump. For the price of the Subaru Limited trim level - this is a pretty solid street car. Pull off the wrap and it's a mean little sleeper. Good luck with the sale!
#3 | |
If anyone else wants to get a second shot at it in case the funds/etc of the potential buyer don't come through in the next few days, please let me know. However, the price is firm, and no trade-ins will be accepted (unless it's just some RIDICULOUSLY good deal, obviously). Please give me a call with any questions! Thanks guys. |
Sold, thanks.
| SOLD - 2013 Supercharged BRZ - 15K in parts/mods - San Diego, CA - 3,500 Miles | KSpider | Cars for Sale/Trade | 36 | 05-24-2014 12:58 PM |
| sold | siuhen | Cars for Sale/Trade | 0 | 04-07-2014 09:51 PM |
| For sale, 2013 Raven FR-S MT 23,000 miles with mods | Jimmythedude | Cars for Sale/Trade | 0 | 10-27-2013 10:35 PM |
| Hot Lava Rocket Bunny Supercharged Magazine Cover 2013 Scion FRS 869 Miles $39.9K | RWDRIFT | Cars for Sale/Trade | 23 | 07-01-2013 04:35 PM |
| For Sale 2013 White BRZ Limited with 2900 miles | jpit | Northwest | 1 | 02-03-2013 08:11 PM |
