Ridge Racerrrrrrrrr
STI Brembo caliper mounting bolts...
Does anyone know where I can get some shipped to Canada for a fair price? Most places charge 1-4 dollars a bolt (Perfect!) and then $40USD or more to ship them...kind of insane. I am having a very hard time finding the bolts in Regina
M12x1.5 35mm. I found some m12 35mm that were grade 8.8 but turns out they were not the right pitch...so that sucked. Too big, so like 1.75 I guess. If I cannot find these bolts I am just going to sell my brembo set up, cause I have had it for almost a year now and it has come down to bleeder valves *solved after months of work and worry* and now bolts...the simplest things EditLooks like my local subaru dealership (well known to be the worst dealership *of any marque* in Saskatchewan FYI) has "4" of them in-stock. Which is perfect. They are 9 dollars a piece, but considering how much I have spent on everything else, I guess I should just buy them and get them installed. Until it is locked, if anyone needs the parts number for the bolts, here it is Subaru Parts #901120103
Drives: BMW E84
You can't use the bolts from your original calipers?
Ridge Racerrrrrrrrr
The individual I bought the Brembo's off of did not ship me the mounting bolts..I do not know why but I also didn't know I needed them at the time as every DIY said "simply bolts on using OEM bolts" So when I took my wheels and breaks off two weeks ago to do it, I was a little shocked and annoyed to see the OEM bolts did not thread in
![]() P.s. ^ your car is sexy. Looks like my local subaru dealership (well known to be the worst dealership *of any marque* in Saskatchewan FYI) has "4" of them in-stock. Which is perfect. They are 9 dollars a piece, but considering how much I have spent on everything else, I guess I should just buy them and get them installed. mmm how do I go about getting this locked as it is not needed anymore... @Dave-ROR ? Does that work? Lock this bad boy. Until it is locked, if anyone needs the parts number for the bolts, here it is Subaru Parts #901120103
or you can order from Mcmaster carr catalog
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Drives: BMW E84
Thanks for sharing the part number. That's very awesome of you.
And thanks for the compliment.
| GRB Brembo caliper on BRZ | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 66 | 11-15-2016 03:50 PM |
| Window Regulator Mounting Bolts - Noise Issue & Part Revision? | PollosHermanos | Issues | Warranty | Recalls / TSB | 1 | 03-06-2014 11:39 AM |
| STI Brembo HELP ~ | Trap63 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 08-02-2013 07:59 PM |
| Brembo + STD R9 | dompower | Brakes, Suspension, Chassis | 17 | 06-13-2013 08:56 PM |
| The price of one Brembo Caliper. | chuttney1 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 01-18-2013 05:32 PM |
