Old 05-18-2014, 05:02 PM   #1
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Kosei K4R 17x7.0 +50
As posted in @2poor4LFA's build topic...
http://www.ft86club.com/forums/showthread.php?t=66097
Originally Posted by 2poor4LFA View Post
first and most important mod:
light weight wheels: 14lbs!
Kosei 17x7 +50
What a difference it makes!
Stock setup:
Kosei + Michelin PSS (225/45/17):
5 pound difference per corner!
20 pounds shed total which equates to roughly 400lbs shed of the car!
Old 01-22-2015, 02:24 PM   #2
G_Rossney
Drives: 2013 BRZ, Limited, 6spd MT, GBS
Send a message via AIM to G_Rossney Send a message via MSN to G_Rossney Send a message via Yahoo to G_Rossney
Do you know the bore on the K4R? I have these and the hub rings that Tire Rack provided are plastic. I want to find better rings. I know the FR-S is 56.1mm. I can't find the data anywhere!
G_Rossney is offline   Reply With Quote
Old 01-22-2015, 02:54 PM   #3
fatoni
Definitely doesn't equate to 400lbs but I like those wheels
Drive upgrades. Don't buy them.
Old 03-16-2015, 12:07 AM   #4
travisb
travisb's Avatar
Drives: N/A
I just installed my Kosei K4R 17x7.0 and 215/45R-17 Dunlop Direzza ZII Star Specs.
The light-weight wheels are immediately noticeable and these tires grip fantastically.
travisb is offline   Reply With Quote
Old 03-16-2015, 12:29 AM   #5
Pat
Pat's Avatar
Drives: 2023 BRZ
Looks great. Can I ask why you went with the narrower version?
Old 03-16-2015, 08:12 AM   #6
travisb
travisb's Avatar
Drives: N/A
Thanks. I bought this tire/wheel combo primarily for autocross.
To stay in street (stock) class you need to keep the same wheel diameter and width as stock within a 6mm offset. This means 17x7 with an offset between +42 and +54.
These are the lightest wheels that I liked that fit my budget. They feel great and honestly I could feel a difference even before I left the driveway.
Old 03-11-2016, 11:30 PM   #7
tk1138
The rings that Tirerack ships with them say 73.0mm, but 73.1 would be the more common size. I haven't tried rings other than the ones TR sent with them though.
Mine show 5x114.3 stamped near the rim, but it looks like the spacing is 5x100 and the sticker shows 5x100. Maybe they use the same cast and drill them out differently depending on the needed pattern.
tk1138 is offline   Reply With Quote
Old 03-12-2016, 12:45 AM   #8
zigzagz94
BRZerhood Lurker #13
zigzagz94's Avatar
Drives: 15 DGM BRZ Premium
Just got my Kosei K4R 17x7 +50 with 225/45/17 MPSS from Tire Rack and they're also stamped 5x114.3
I think everyone I've seen has been stamped that way and you're probably right about them using the same mold and just drilling them differently depending on the pattern needed.
Yesterday is history. Tomorrow is a mystery. Today is a gift and that's why it's called the present.
zigzagz94 is offline   Reply With Quote
Old 03-12-2016, 11:23 AM   #9
Timmy_Jones
Spun
Drives: 23' Supra
Before you left your driveway? They handled better in your driveway? Is your driveway a mile long? I don't follow.
Timmy_Jones is offline   Reply With Quote
Wheel Directory: Kosei K4R 17x8.0 +36 Vracer111 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 59 05-01-2017 12:39 PM
Is anyone using Kosei K4R 17x8 +36 wheels? Dave-ROR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 02-02-2015 03:09 PM
(4) 17x8 Kosei K1 TS wheels for sale $600 + shipping skaria Wheels and Tires 2 02-27-2014 11:58 PM
Enkei RP03 vs Kosei K4R vs Kosei K1 TS TheLaughingMan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 02-11-2014 01:01 PM
Kosei TS EUrope Skurj Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-28-2013 10:30 PM
