Old 05-23-2014, 11:22 PM   #1
Im_SPEED
Drives: FRS hot lava
how to tell if i have an ecutek tune/licence
so there are a few things on my car that dont make sense. ie a soft rev limiter. is there any way i can tell if my car has been tuned or has an licence associated with the pcm?
Im_SPEED is offline   Reply With Quote
Old 05-23-2014, 11:43 PM   #2
steve99
Read ROM if you carn't read it its probably brzedit or ecutek and its locked or encrypted
If read sucessful then open the ROM you read with a hex editor or romraider , ecuflash
search for ZA1J this is what all rom caibration codes start
it will be something like ZA1JA00C for manual or ZA1JA00D for auto.
Then do a hex comparison with a stock rom hex file of same calid if it matches it stock, if it dont match (apart from the vin number on the rom) its been messed with.
Romraider or ecuflash will compare the tables but may miss the ecutek or brzedit licience info as its placed in an unused part of the rom usually filled with FF.
Old 05-24-2014, 07:34 AM   #3
eighty666
what do you mean by a soft rev limiter?
eighty666 is offline   Reply With Quote
Old 05-24-2014, 09:20 AM   #4
dp1
driving smoother faster
Drives: Sold
Maybe pulling back timing at the rev limit instead of stock that has abrupt cutoff? I have an ecuteck dyno tune that does this, much gentler cutoff that stock.
dp1 is offline   Reply With Quote
Old 05-24-2014, 11:08 AM   #5
onzippy
Drives: 2014 FRS
OP: If you don't have any tuning tools to connect to the ECU maybe give the cruise stalk a pull and hold it for a few seconds with the ignition on. If ecutek racerom maps are loaded it will make the tach jump to 1,000rpm. Almost everyone seems to be tuning with multiple maps. Not a guarantee but might work.
This was a pre-owed car you purchased?
onzippy is offline   Reply With Quote
map problem ecutek tune. ChinoAnthrax Software Tuning 8 05-05-2014 03:57 PM
EcuTek Tune SalM Software Tuning 20 01-30-2014 11:09 PM
ECUTek - can I see which tune is set Pokeguyjai Software Tuning 10 11-29-2013 09:46 PM
Help?!? Maybe..Ecutek tune JerryMichaels7 Software Tuning 6 10-01-2013 12:47 AM
FA20CLUB.COM ECUTEK TUNE hayleybeaners Engine, Exhaust, Transmission 21 11-13-2012 10:52 AM
