Old 05-26-2014, 01:14 AM   #1
Boba_kz
Radiator for AT
Which one will be fit FBM turbocharged AUTOMATIC TRANSMISSION BRZ?
As I understand where is some difference in fitment between MT and AT...
What does it mean?
Note: Koyo All-Aluminum racing radiators are made for manual transmission applications only. Automatic transmissions will require an external transmission oil cooler.
Boba_kz is offline   Reply With Quote
Old 05-26-2014, 01:50 AM   #2
Sithspawn
Drives: '14 Hot Lava FR-S w/Flappy Paddles
Traditionally, automatic radiators have an auxiliary heat exchanger built into them to cool the transmission fluid. That said, this car has a different setup where the heat exchanger is external from the radiator. I could be wrong, but the AT and MT appear to use the same radiator for this application.
Sithspawn is offline   Reply With Quote
Old 05-26-2014, 03:00 AM   #3
Boba_kz
@OrbitalEllipses
^Aftermarket radiators are usually MT unless otherwise stated; I know most WRX radiators were "not for AT" because they didn't have a place to cool the AT fluid, like the stock WRX AT radiator did.
The factory service manual shows the below as the oil cooler assembly for the TX6A automatic transmission. The unit appears to be a piece entirely separate from the radiator, thus radiators shouldn't be different between models (you'd think). The oil cooler is accessible once removing the No.1 and No.2 engine covers. I would add an aftermarket (Long Tru Cool; highly recommended line of coolers) unit in series with the stock unit such that you're not over-cooling, since AT vehicles usually have some functionality reduced until they reach proper temp.
Old 05-26-2014, 03:15 AM   #4
Boba_kz
So I'm so f...ing stupid, don't understand, why i can't install for example Koyo radiator? No additional holes on it? Or what?
Old 05-26-2014, 04:49 AM   #5
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Yes, it would not have a hole for the ATF cooler lines. However, Koyos website lists it as applicable to the At as well, so I would confirm with a vendor if that means it fits or it has the ATF cooling capability as well.
Old 05-26-2014, 03:46 PM   #6
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
I have an AT. The MT and AT radiator are the same. So no problems installing the Koyo on your car.
Tye300 is offline   Reply With Quote
Old 05-26-2014, 04:05 PM   #7
8686
8686's Avatar
Drives: 86
Do this mean that our AT dont have a cooling system?
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 05-26-2014, 04:06 PM   #8
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
I have the koyorad It says in the instructions to not install it on an automatic car. Koyorad said they were working on automatic transmission compatible radiator they may have it done I have had my radiator for over a year now.
Sent from my Q10
Old 05-26-2014, 05:18 PM   #9
Tye300
Tye300's Avatar
It has one. It's the one in the picture above. It runs off coolant, but it is connected to the block instead of the radiator.
Old 05-26-2014, 05:23 PM   #10
Tye300
Tye300's Avatar
Sent from my Q10
I have installed an aftermarket radiator. From the pictures, it seems the same with the koyo. I used a supposedly MT only radiator on my AT car. The AT radiator has the same outlets as the MT one. The coolant for the AT is run off the block. The people that installed the oem forester oil cooler discovered where the coolant is run off from. You can check my radiator install in my build thread. HTH
Old 05-26-2014, 05:24 PM   #11
Captain Insano
Tye300 are you using the same MT koyo radiator on your AT?
EDIT: nevermind you posted right before me and answered. Thanks!!
Old 05-27-2014, 01:34 AM   #12
Boba_kz
Old 05-28-2014, 08:32 PM   #13
mashal
DADA
mashal's Avatar
Drives: 2013
Why not get an FBM one and call it a day? It works flawlessly
mashal is offline   Reply With Quote
Old 06-10-2014, 06:32 AM   #14
Boba_kz
Bought Koyo
FS: OEM Radiator MicheleAbbate Engine, Exhaust, Bolt-Ons 10 09-12-2016 02:11 PM
FS: Robispec Radiator (Massive radiator and liquid to liquid oil cooler in one) Sportsguy83 Engine, Exhaust, Bolt-Ons 15 05-27-2014 01:18 PM
JR SC kit and Koyo radiator dp1 Forced Induction 1 02-17-2014 12:49 AM
1.1 vs 1.3 Radiator Cap JPxM0Dz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 01-21-2014 02:21 AM
Mishimoto Radiator & Mishimoto Radiator Hose Kit tlinspired830 Engine, Exhaust, Bolt-Ons 5 01-08-2014 09:44 AM
