$4,900 till FR-S
Drives: 1999 Mazda Protege
Ok, I'm old. And this FR-S will be my first performance oriented import experience. I have a question about using lowering springs on the FR-S.
My thoughts are to cut the unsightly, 4x4 like gap between the tires and the fender edge. It's just too much. At the same time I would like to increase over-all handling capability by 10-20%. Nothing too radical in either area. Maybe 1" of drop. I also want to stay with a very simple approach. I do not want to use a coil-over system due to cost restrictions. I am thinking a good set of springs with properly matched dampers and upgraded sways. My question is this. Do any of the Tuners ever do suspension sets that include springs and dampers? Having something pre-packaged to work together would make things much easier on a neophite that just want to enjoy driving the car as opposed to a gear head who creams is jeans over spring and damper rates. Thanks, Eric |
Registered you sir
Drives: 99 impreza coupe
Welcome! Youve got your head in the right place.
A quality spring and strut setup can perform better than many coilovers on the street. There will be plenty of options for you, especially because you dont want to go stupid low. Give it some time and you will see most aftermarket suppliers that create subaru setups will have adapted variants for the BRZ/FRS. |
$4,900 till FR-S
Thank you chulooz. I know it's a little early to worry about aftermarket products for the FR-S/BRZ. And we might even see the TRD options for what I'm looking for become available before I ever order my car. I just like to educate myself before I drop my hard earned $$$'s.
I would love to see an over-all set up that would keep the factory suspension feel and performance. Just slightly improved while removing that unsightly huge gap. I can't wait to see what TRD and the rest of the aftermarket comes up with for this car. |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
You're going to want the RaceComp Engineering "Black" springs.
http://www.ft86club.com/forums/showt...light=RaceComp They're a 20mm drop all around with rates high enough to compensate for the reduced travel, but low enough for good street use. Couple them with the RCE lowering front camber plates for an additional 10mm drop with no reduction in travel and you'll have a great setup. They have also put the stock dampers on a shock dyno so they know their rates will match well. RCE pays attention to the details. Not many other aftermarket companies will take the time to determine the stock spring rates and damper profiles to ensure they are making a product that will help performance instead of just looking good. Beware companies trying to sell you springs with large differences front to back. The stock rates are the same front/rear for the BRZ (186lb/in) and slightly higher in the rear for the FR-S. There have already been aftermarket springs with much higher front rates, as if they were for a nose-heavy sedan. |
#5 | |
$4,900 till FR-S
Looks like RaceComp is doing some great work for the BRZ/FR-S crowd. Thanks for the link and info. |
Kuruma Otaku
They are also active here and very helpful at explaining suspension overall, not just their own products.
Because titanium. |
| BRZ DRIVEN FULL REVIEW (lowering springs pics too) | Racecomp Engineering | BRZ First-Gen (2012+) — General Topics | 99 | 12-14-2019 06:14 PM |
| Noob question | fitcious | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 05-03-2012 12:18 AM |
| Total noob tire-change question | Sport-Tech | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 38 | 04-17-2012 08:15 PM |
| [Noob Question]Will you be able to swap BRZ and 86 headlights? | Slide | Cosmetic Modification (Interior/Exterior/Lighting) | 41 | 02-18-2012 02:26 AM |
| Noob to the forum! | Altezza_86 | Off-Topic Lounge [WARNING: NO POLITICS] | 14 | 12-19-2011 06:34 PM |
