| Southeast AR, AL, GA, FL, KY, LA, MS, NC, SC, TN |
I Love custom Turbo kits
Drives: Limited BRZ
How do you get around OBD2 Testing in GA? (System Not Ready)
Fellow GA 86's.
I believe if you remove Cats, your Emmisions system will show "not ready" in the OBD2 monitor... Then, if you use the EVAP soleniod line for boost control, that is a second system that will show "Not ready".... So how do you get around this in GA? (Having two systems not ready for OBD2 yearly test) @Reaper @dwx @ATL BRZ
Berz
the readiness should go away after about a week. I've had that before (not in my BRZ, but in another car). After driving roughly a full gas tank, the readiness was...ready.
We don't need emissions yet for our cars. I believe next year will be the first year. I think it's 3 years after the car comes out is when you need emissions to get your tag... and even then it is/was only in metro atlanta. The rest of the state, unless I'm mistaken, doesn't have emissions. |
#3 | |
Drives: Limited BRZ
Is one system allowed not be ready like in other states? Or all systems are required to be ready?
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
I know that my tuner has disabled the DTC for cat readiness so I've never seen it, but then again I've never actively monitored that metric in Torque in regular driving so it may not be actively "ready" even though the DTC is disabled. I'm not sure how that works. As far as I know we do not have visual inspections in Fulton county. I have a secondary cat but I never bothered to move the secondary O2 sensor aft of it since there's no point to. Worst case scenario I have my OEM header and can swap it on the lift if I absolutely needed to.
Drives: Limited BRZ
I need to actually drive the car around now that I'm not flashing it 3 times per drive to see what the monitors read... Maybe they all show ready and I don't even know.
Drives: GTI, BRZ
I had tons of issues dealing with customers cars without cat and with tunes in the Volkswagen world here in NC (OBD2 only inspection testing) curious to see what's needed to get catless and tuned cars though inspection on this platform.
The issue we ran in to with inspection was when the tune disabled the fault codes for the missing catalyst, the ECU no longer checks to make sure it's working so the readiness test wont run and it will be unset. Obviously different tunes can handle that differently, but what we had to do was run a O2 spacer and the stock tune, then force the readiness tests using our scan tool, get it inspected and then flashed back to the stage 2 programming. PITA like I said. |
i'm sorry, what?
Drives: Canada
it's 2014
can people stop ripping the cats out of their daily driven cars?
#8 | |
Drives: Limited BRZ
[ame="https://www.youtube.com/watch?v=umDr0mPuyQc"]NO GOD! PLEASE NO!!! NOOOOOOOOOO - YouTube[/ame]
Drives: 2013 asphalt scion FRS
FYI, the state of Georgia allows 2 sensors to not be ready before auto failing the test. If a sensor shows not ready, you need to put between 65-150 miles on the car. Then it should pop ready. A tune should not matter, in fact...it theoretically should help pass emissions. Other than that, there is no way to "sneak" an obd2 car. Unlike an obd1 where you can manually input info, obd2s do it all automatically from the port.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car) 1995 gmc 1500 4x4(off road toy) 2005 Yamaha yz250f |
#10 | |
Drives: Limited BRZ
#11 |
in orbe terrum non visi
Drives: violent
@Sportsguy83 I am exempt from emissions testing in 49 states.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#12 | |
Drives: Limited BRZ
#13 |
Drives: violent
Sorry.
#14 |
NASA SpecE30 Racer
New job offer?
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| WheelDude.com | Stivo Racing Exhaust System - in stock and ready to ship! | WheelDude.com | Engine, Exhaust, Bolt-Ons | 13 | 10-20-2013 06:59 AM |
| FA20CLUB CAI V2 SYSTEM NOW READY | FA20Club.com | Engine, Exhaust, Transmission | 51 | 10-03-2013 08:26 AM |
| INJEN and aFe Intake System, In stock and ready to ship!! | 10k Redline | Engine, Exhaust, Bolt-Ons | 5 | 10-03-2012 05:05 PM |
