Old 06-06-2014, 03:14 PM   #1
D K
Stig's dark passenger
Flywheel torque specs
Does anyone know these off hand?
D
D K is offline   Reply With Quote
Old 06-06-2014, 03:17 PM   #2
OrbitalEllipses
Drives: Attitude
151FWTQ
Unless you meant the bolts, in which case there's a shop manual available for download on this very forum that will specift the torques for you.
Old 06-06-2014, 03:46 PM   #3
D K
I tried but they wont download...
Old 06-06-2014, 04:13 PM   #4
fubarian
Drives: 13 FR-S
63 ft/lb. Straight off of TIS.
fubarian is offline   Reply With Quote
Old 06-06-2014, 05:42 PM   #5
D K
Thank you
For some reason wont load on my ipad
Old 02-05-2021, 04:18 PM   #6
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Since it's only a single step torque of 63 ft/lbs, does that mean these bolts are re-usable and not TTY?
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 02-07-2021, 03:45 PM   #7
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
I reused mine without issue.
Trueweltall is offline   Reply With Quote
Old 02-07-2021, 04:10 PM   #8
AT-JeffT
Drives: 14 BRZ SWP
I reused mine without issue also.
AT-JeffT is offline   Reply With Quote
List of torque specs for FR-S/BRZ? 96z2 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 02-15-2018 05:21 AM
Torque specs for rear toe arm Malt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-02-2014 08:24 PM
Exhaust torque specs Prowl647 Engine, Exhaust, Transmission 0 08-13-2013 01:57 PM
Flywheel bolt torque? Turdinator Engine, Exhaust, Transmission 12 03-08-2013 12:10 AM
Torque specs (brakes) CB762 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 09-08-2012 01:26 PM
