Old 06-08-2014, 09:02 PM   #1
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Scion Steering Wheel Airbag Badge Emblem dimensions?
What are its' dimensions? Preferably in millimeters; but, inches would be fine too.
Thanks
fooddude is offline   Reply With Quote
Old 06-08-2014, 09:35 PM   #2
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
It isn't an elogated circle by the way. I do not have any numbers for you.
Old 06-08-2014, 10:06 PM   #3
fooddude
I'm doing research and asking around about different emblems. Looking for an emblem that will fit somewhat well Inside the oval indentation left over..instead of over the hole/border, like everyone else has already been doing successfully with a slightly bigger "T" emblem.
I just need dimensions is all.
Old 06-08-2014, 10:32 PM   #4
fooddude
Well..I did a bit of searching...and 1 person posted his measurements:
45mm x 25mm
Is this correct???
I may have found an oem emblem that has to be the closest in size that anyone has done yet, at 50mm x 35mm.
Yes, the Toyota emblem is more of an elongated circle that the Scion emblem, which is a little pointier on the sides..but since this Toyota emblem is slightly bigger, it should cover any difference in oval's the curvature well.
Old 06-08-2014, 11:05 PM   #5
boredom.is.me
Custom User Title
I'll get measurements when I go back down.
Old 06-09-2014, 12:02 AM   #6
boredom.is.me
Custom User Title
I got 58mm x 41mm.
Old 06-09-2014, 01:55 AM   #7
fooddude
Thanks man!
Hmmm....that's a lot different than the 45x25mm someone posted lol. ..but at least it sounds close to the emblem I found as well.
Old 06-09-2014, 01:59 AM   #8
kALMIGHTY
Drives: TRD Ultramarine '13
Originally Posted by fooddude View Post
Thanks man!
The 45x25 is probably the Subaru emblem. I believe it's slightly smaller than the Scion one on the steering wheel
Old 06-09-2014, 02:04 AM   #9
boredom.is.me
Custom User Title
Although I originally said 58mm, go with 59mm. It is really close.
Old 06-09-2014, 03:18 AM   #10
fooddude
Drats...I guess the emblem wont fit.. 9x6mm too small.
Old 06-09-2014, 01:59 PM   #11
fooddude
Anyone have a micrometer digital caliper that can take precise and exact measurements? I am in communication with an emblem maker, to make a nice Toyota "T" airbag emblem. W x H mm
....and, I also want to know the depth of the indentation left on the steering wheel, and/or the emblem's thickness (I want to design and have them made, that will be nicely flush to the airbag and close to as oem as possible)
Old 06-10-2014, 04:06 PM   #12
boredom.is.me
Custom User Title
This is a project of personal (your) interest. You have to do your own "research". When I wanted to try something, I had to take apart my interior and learn everything on my own. Someone will eventually provide the required info, but when and how accurate will it be?
Old 06-10-2014, 05:15 PM   #13
boredom.is.me
Custom User Title
Ah I see.
Old 06-10-2014, 09:51 PM   #14
fooddude
@ADMIN:
You can delete this thread please.
Wtb '13 scion frs driver steering wheel airbag air bag mnb0225 Want-To-Buy Requests 0 03-18-2014 07:56 PM
Scion Emblem without the word "Scion" for steering wheel Airbag.. 86-tundra Cosmetic Modification (Interior/Exterior/Lighting) 2 01-18-2014 03:15 PM
FS: Scion stock steering wheel and airbag JackSmiley Interior Parts (Incl. Lighting) 16 01-09-2014 05:15 PM
Red Embossed Scion Steering Wheel Emblem boredom.is.me Cosmetic Modification (Interior/Exterior/Lighting) 3 11-17-2013 12:13 AM
OEM Scion FR-S Steering Wheel/Airbag FS & Trade for Parts! TylerLieberman Interior Parts (Incl. Lighting) 4 07-12-2013 07:05 PM
