Just a dude
Drives: Scion FR-S 2013
Kraftwerks / Jackson Racing SC kits with Radium Dual Catch cans setup?
Hi folks. As I look through some photos of where the Rotrex SC oil reservoir is and also noting placement of the Radium brackets for their dual catch can system I am wondering how folks with either KW or JR kits got around this?
New home made bracket for SC reservoir? Aftermarket one available? Please share if you can with pics if you have the dual catch cans and a KW or JR kit it would be greatly appreciated!!!
Drives: Really slow
All you will need is one nut and bolt for this mod. Keep in mind that the bracket will only be mounted with this one nut and bolt, but I can assure you that it is solid and does not wiggle. For additional stability, I would advise using a zip tie to secure the tubes as shown.
This should be obvious but I didn't mention it in the red text but you are supposed to cut at the red line as well and round out the bottom section of it to accommodate the SC reservoir. Just follow the example picture. It's very straight forward. ![]()
I'll be doing this setup very soon with both the Kraftwerks SC and Radium catch cans. Look forward to these great products.
Drives: GT86 Cosworth
Drives: 2013 FR-S Matte Orange
I have both Radium cans and am running the Kraftwerks S/C
Drives: WRB Limited
Running a JRSC with dual Radium catch cans. Here's what I did...
![]() ![]() I mounted the SC oils reservoir on the passenger side using one of the nuts on the top of the strut. When I upgraded to the SC (I had the NA oil cooler setup previously), I ended up with another bracket that moves the windshield washer neck. i used that to extend the position of the reservoir and zip tied it to the firewall brace. Ghetto, I know. I'll swap it out with a clamp (~$7 from what I've found so far) soon. I was really hoping to not modify the Radium setup, they're really nice pieces. The SC reservoir is still elevated above the SC unit as per directions. Hope this helps! Credit goes to the member who mounted it in a similar position near the battery. I saw it somewhere in the JRSC owners thread (too lazy to reference sorry), not sure what their solution is. Tony
So...at last we meet for the first time for the last time...
Drives: BRZ, STI, 535, Tiffin Allegro
Drives: WRB Limited
OOOoooh that's clean @romin. Must've been you in the owner's thread. I'll have to relocate when my battery craps out and I can get a smaller one.
Tony
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Radium Engineering Catch Cans | FRS2000 | Engine, Exhaust, Transmission | 111 | 03-02-2016 01:49 AM |
| Catch cans: what are you running? | Apex Chase | Engine, Exhaust, Transmission | 144 | 08-14-2014 08:17 AM |
| Radium or Crawford catch cans/AOS | diss7 | Forced Induction | 16 | 02-18-2014 08:50 AM |
| cusco catch cans difference | Silverdub | Engine, Exhaust, Transmission | 15 | 04-23-2013 10:17 AM |
