Old 06-24-2014, 12:43 AM   #1
b rawr z
b rawr z's Avatar
Drives: 2014 BRZ, 2008 Impreza
ST coilovers noise
me and a friend installed my ST coilovers yesterday and ive been hearing clunking noise on rough roads. Like metal to metal type of clunk.
I had a mechanic tighten the front and rear top bolts with an air impact wrench which i think fixed the front clunk noise.
Rear clunk noise is still there tho. We tightened all the bolts on the LCAs (total of 8). Also we used the stock rubber ring and im not sure if were supposed to but it helped lessen the clunk noise.
Any idea what is causing the clunk? Thanks in advance
Update: only the left rear is clunking on rough roads. I think the top nut needs a little bit more tightening.
Im just wondering what kind of tool people use to tighten them other than an air impact wrench.
b rawr z is offline   Reply With Quote
Old 06-24-2014, 04:59 AM   #2
TheProdigy
TheProdigy's Avatar
Drives: 2013 WRB Subaru BRZ Limited
I've had mine for a couple days now but thankfully I had no clunking issues yet. I'm not sure what's the problem but I hope you get it fixed soon buddy.
TheProdigy is offline   Reply With Quote
Old 06-24-2014, 09:46 AM   #3
b rawr z
b rawr z's Avatar
thanks. do u have the ST coils too?
Old 06-24-2014, 09:48 AM   #4
d1ck
Drives: Black 2013 FRS
Try to avoid using an impact on the top nuts, it's not good for the seals. A pass through socket set it the way to go. Also did you have the car on it's wheels when you tightened the rear control arms?
d1ck is offline   Reply With Quote
Old 06-24-2014, 09:52 AM   #5
b rawr z
b rawr z's Avatar
I might buy me a set of those kinds of socket. We did try tightening them again when we dropped the car down but ill try it again. Thanks
Old 06-24-2014, 10:21 AM   #6
RYU
RYU's Avatar
Drives: really slow...
How's the ride on the STs?
RYU is offline   Reply With Quote
Old 06-24-2014, 11:53 AM   #7
Bongertz
Drives: Brz
Will watch this thread!
Bongertz is offline   Reply With Quote
Old 06-24-2014, 12:08 PM   #8
b rawr z
b rawr z's Avatar
The ride is pretty good. Afaik, the spring rates are the closest to oem compared to other entry level coils (<$1k).
clunk, noise, st coilovers
Road noise? Tread Noise? zERoTu Issues | Warranty | Recalls / TSB 21 10-07-2020 11:21 PM
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 01:09 PM
WTB: Ksport Control Pro Coilovers or BC Racing Extreme Low Coilovers ProjectBrz Brakes, Suspension, Chassis 1 04-15-2014 01:21 AM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 09:56 PM
