520
Drives: Series 10 Fr-s #520
Flasher problem after Valenti tail light install!
Looking for some help! I had Diode Dynamics LED turn signals installed on all four corners and installed their CF18 flasher, which is specific for the FR-S to fix the hyper blink problem.
All was well, until I installed a set of Valenti LED tail lights. Now, when I turn on the turn signal, the opposite side signal blinks faintly, and my climate control lights blink as well. It does not seem to occur when I have my head lights on, but quite annoying otherwise. Any ideas? I have not tried re-installing the stock flasher to see if the problem goes away, but figured I'd get the hyper-flash back if I did. |
Drives: TRD Ultramarine '13
I had a problem with my relay that came with my Buddy Club tails. The left side would keep blinking for 3 more blinks after I turned it off. The right side was fine. I replaced it with the flasher relay I got with my Diode Dynamics switchbacks and the problem went away. I think you probably just got a faulty relay, so just ask for a replacement. Diode Dynamics has awesome customer service so they'll replace it quickly.
520
I'll contact them and see what they say. Thanks.
Drives: 2013 FRS
The Valenti already have resistors built in and are designed to work with the stock flasher unit. Use the stock flasher and install universal resistors for the front turn signals. That should do it.
Victim's aren't we all
Drives: Toyota GTS 86 - Pegasus White
I have Smoked Valenti's and front LED bulbs for my flood and indicators. The relay that came with the LED's makes them operate normally (slightly slower) but no anomalies.
#6 | |
520
I'll throw the stock flasher back in. If the hyper flashing comes back, I'll just put the stock front turn signal bulbs back in and source some resistors for the LED's. Thanks. |
Drives: 2013 FRS
Your welcome.
520
That did the trick. Connected the stock flasher back up. Got the hyper blinking with the front LED's. Put the stock front bulbs back in and all is good. Now I just need some in line resistors for the LED bulbs.
Drives: 2013 FRS
Got mine from Diode Dynamics. 10 bucks a pair.
#10 |
520
Ya. They are out of stock right now on the 7443's. I'll just wait until they are back in Stock and pick up a set of switchbacks too!
#11 |
Drives: 2013 FRS
Happy motoring is here again. Smiles.
| Valenti tail light signal light issue | djdnz | Cosmetic Modification (Interior/Exterior/Lighting) | 70 | 12-03-2017 01:49 AM |
| FS: Valenti LED Tail Light in Socal | mtsui | Exterior Parts (Aero, Lighting, Etc.) | 6 | 06-25-2014 06:13 PM |
| DIY - FR-S Valenti Tail Lights Install | bobpuffer | DIY (Do-It-Yourself) Guides | 15 | 03-15-2014 10:43 AM |
| Valenti Tail light on GBS | alpine | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-24-2014 11:16 PM |
| **Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** | nigel-jdmparts | Exterior Parts - Lighting | 13 | 04-30-2013 01:14 PM |
