Old 07-01-2014, 04:21 PM   #1
ddeflyer
Effect of wheel offset
One of the things I have tried to understand but don't fully have a grasp on is the effect of wheel offset on the car's handling characteristics and steering feel.
From what I have read there are two main elements that will have an effect, track width and scrub radius. Supposedly increasing track width gives a little better grip and scrub radius changes steering feel (though frankly I am confused if less offset would increase or decrease that steering feel).
Could someone explain this to me? How much effect will a +35 rim have on our cars on the track?
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
Old 07-01-2014, 04:34 PM   #2
gramicci101
Off Topic
Increasing track width will increase stability when vehicle weight is transferring from side to side, just because the car now has a wider base.
Having a lower offset will increase the scrub radius, which is the distance from the center of the tire to the point around which the hub pivots with steering input. In a perfect world, these two points would coincide and you would have no scrub radius, effectively meaning that when you turn the steering wheel, the tire pivots in place. In the real world where we do have scrub radius, when you turn the steering wheel you're basically dragging the tire through an arc centered on the steering pivot point. Increased scrub radius means you're dragging the tire through a bigger arc and covering more distance, which will make the steering system work harder because it has more friction to overcome. This will make the wheel feel heavier.
Not a lot though. I'm running 20/25mm spacers and I can't tell if the wheel is any heavier or not. I do take care not to crank the wheel from one side to the other while sitting still, because that's a lot of friction to overcome. When you're rolling it's not an issue though.
Old 07-01-2014, 04:41 PM   #3
sluflyer06
Drives: 2014 BRZ Ltd - DGM
It's also worth nothing that spacers and offsets that push the wheels out place significantly more strain on your wheel bearings.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
Old 07-01-2014, 07:23 PM   #4
gramicci101
Off Topic
Not really. No more than wider wheels and tires or lower offset wheels do.
edit: Now, whether spacers are approved for track duty is another matter. That would be up to the tech rules for your racing association and the inspector looking at your car.
Old 07-01-2014, 10:50 PM   #5
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
It's hard to find a car in the paddock during a race weekend that doesn't utilize spacers of some type.
I use a combination of no spacer, 5mm and 10mm spacers. I often run 10mm up front and non in the rear to widen my front track. (not the FRS)
What's going to get you into trouble in tech is if your spacers keep your lugnuts from engaging enough of the studs.
PRO86 | STL | LuckyDog
Old 07-01-2014, 11:25 PM   #6
gramicci101
Off Topic
What about bolt on spacers vs. spacers that use replacement studs?
Old 07-02-2014, 12:27 AM   #7
rice_classic
Version 1 w/ extended studs, of course.
Version 2 w/ bolt on.. I'm not sure. I've haven't seen a tech supp that specifically rules these out so..
Old 07-02-2014, 02:18 AM   #8
D K
Stig's dark passenger
not directly related, but in karts (shifters) wheel spacing is a majority of overall setup
D K is offline   Reply With Quote
Old 07-02-2014, 07:29 AM   #9
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
In a perfect world, these two points would coincide and you would have no scrub radius, effectively meaning that when you turn the steering wheel, the tire pivots in place..
Small point, but that's not actually true. In a perfect world, you want a reasonable amount of scrub, because zero scrub makes the tires squirm when you turn. Some cars have positive scrub, some have negative, but either way it gives you road feel and increases steering effort the more you have. On a light car with power steering this probably won't matter until you get to a truly ridiculous amount of scrub. One effect you WILL notice, though, is that with a large scrub radius (lots of spacer) the wheel swings in an arc instead of pivots when it turns and you will rub in bizarre places against the frame / in the tub at lock.
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
For a limited time Sonax Full Effect Wheel Cleaner 500 ml - $12.95! DetailersDomain Wheels and Tires 2 03-25-2014 03:20 PM
For a limited time Sonax Full Effect Wheel Cleaner 500 ml - $12.95! DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 03-25-2014 02:23 PM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 12:34 PM
Wheel Directory: Effect Sengen 17x7.5 +40 Leonardo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 11-14-2013 03:18 PM
Here's your shot to WIN A LOT of Sonax Full Effect Wheel Cleaner DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 01-18-2013 08:15 PM
