Drives: 2007 Altima 3.5 SE 6sp
Guys,
Looking for some advice on the matter. I had the rear tick/pop issue resolved under warranty at the dealer. The issue has come back after one month...however now it's really random and happens once in a blue moon. I particularly notice it when I throttle out of a corner and get the chassis to flex. Anybody have recommendations on how they resovled this issue? I read something about a chassis ear that helps. Is it worth chasing the issue down? At this point my car has problem been torn apart many times - which I know can lead to more rattles. I was thinking of maybe just living with the issue for now until I dynamat the rear trunk area...but I hate covering up problems. |
Drives: Ultramarine FR-S (MT)
Have you tried using WD40?
#5 | |
Canadian FR-S Member
Drives: FR-S '10 Series'
The dealer may have followed the TSB for rear deck pop but didn't crack a weld spot enough or get all of it so you still are left with part of the issue. Or not enough grease was used.
Drives: Toyota 86
I still had the popping/clicking in the rear even after doing the TSB fix. It would stop popping if the rear seats are folded down. It turned out to be the rear seat. This fix worked for me: http://www.ft86club.com/forums/showp...0&postcount=30
Lower rear seat then slowly position it near closed and use your fingers to feel underneath if the gap is even. I used the "flaps" on the rear of the seatback to gauge the space. The flap on the driver side of mine was touching the rear latch while the passenger side was not, meaning the seatback was uneven. I just loosened the 12mm bolt in the photo shown in the link, pulled the seat forward, then retightened. Problem solved, easiest fix ever. |
Drives: Toyota 86 Silver
First you need to make sure that the rattle is really coming from the rear deck.
I suggest you ask someone who is small enough to sit at the back and try to listen where the rattle comes from. It might be not from the rear deck. There is separate thread in issues/Warranty/Recall section about this. |
#9 | |
I'm assuming it is because the sound it's making is the same as before where the fixed my rear deck and it went away for a month. It's a pretty distinct sound but I could be wrong. |
#10 | |
Here's the tricky part to me though...when i dropped the seats I actually heard more noise but it sounded different. Is this normal?...I imagine the seats up adds some rigidity vs them down. |
#11 | |
Waited 5 years for this
Drives: '18 MX-5 Club
I would try to get as much spots as possible from inside of the trunk and see if that gets rid of the noise. Kind of like this. If that doesn't get rid of the noise, then either you or the dealer is to remove the rear deck cover and get the rest of the spots from the top. Like this one. |
#12 | |
How do you know which welds to crack? All of them? lol. |
#13 | |
I was lucky that mine had only one spot that was making noise, which is here: When I pressed the red circled spot with my thumb, it made the cracking sound. I just sprayed some WD-40 as shown in the picture. The noise didn't come back since then and it's almost 2 years now. |
#14 |
Drives: 2014 BRZ Limited
| WTB: REAR window top Brake Light (just top half with leds) or full rear deck | Kayzer Soze | Exterior Parts (Aero, Lighting, Etc.) | 1 | 08-31-2013 03:23 PM |
| eliminate rear deck popping with rear strut bar? | chenshuo | Issues | Warranty | Recalls / TSB | 11 | 07-03-2013 07:44 PM |
| Tick tick tick from the dash | FRiSson | Issues | Warranty | Recalls / TSB | 23 | 06-12-2013 06:11 PM |
| What are these things on the rear deck? | josby | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 01-17-2013 06:48 PM |
| Tick Click Tick (injector orgy) | empower-auto | Issues | Warranty | Recalls / TSB | 4 | 08-27-2012 03:28 PM |
