LED Switchbacks strange issue
I've tried installing two sets of LED Switchbacks (amber-off type) on my FR-S and they both have the same issue. The problem is that the light will flash white-amber-off instead of the correct amber-off sequence. This occurs during the following actions:
-Unlocking/Locking doors -Emergency lights -Turn signals when headlights and parking lights are off Has anyone encountered this issue or have an idea of what could be causing it? Thanks. Here is a video of the issue: [ame]http://youtu.be/GZQbMXsjm3Y[/ame] |
TALLY FT86
Drives: 2014 FR-S Monogram -- SBD Turbo --
Well, if your normal halogen bulbs work like they are supposed to then the problem is with your switchbacks.... Which Brand did you get?
They are diode dynamics. Their customer service had been great but they haven't been able to track down the issue yet.
That's kind of badass.
TALLY FT86
I had an issue with my one of bulbs from them, but they sent out a replacement that worked great, I will say their customer service was great! @Diode Dynamics
Drives: 2013 Firestorm FRS
They are white when the car is running/driving normal(when driving lights or headlights are on), but when you flip on your blinker they turn orange(law states blinker bulbs must emit orange)
#8 | |
Drives: 2014 FR-S 6MT Whiteout
The first is White normally, alternating Amber/off when turn signal active. The second is White normally, alternating Amber/White when turn signal active. Which way they work depends on the particular type you've got - most of the distributors on the forum sell both types. I'd bet the OP has been taking part in a bad batch of parts.
520
Drives: Series 10 Fr-s #520
Mine do that exact same thing. Only when I have the headlights off.
I thought it was pretty cool, so I'm OK with it. Definitely no doubt I'm turning! I had regular LED's (Diode Dynamics) on all four corners and was using an LED Flasher module from them. Everything worked fine. Then I swapped out my stock tail lights for Valenti units. Since the Valenti's have resistors built in, I had to put the stock Flasher unit back in and I ordered a new set of switchbacks from DD along with the 6 ohm resistors. Just put the stock front turn signals in while I waited for the switchbacks and resistors since I had the hyper-flash issue with the LED's up front. Once I installed the new switchbacks and resistors, everything works as it should, except for that little white flash of the turn signal just like in your video. It doesn't happen when I have the park lights, or the headlights on though. I'm sure it's probably a small current draw issue - either a little too much or too little, but I'm kind of digging the strobe thing anyway! |
#10 | ||
Noob
Drives: FR-S Mammogram
#11 | |
I think its a direct swap... but you might have to get a different relay...Someone who has these wanna chime in? I was under the impression they had resistors or whatever built in, but I could be wrong. Last edited by continuecrushing; 07-08-2014 at 07:05 PM. |
#12 |
Depends on the lights. Believe with DD you'd need to add resistors or new flasher relay.
#13 |
You will need to add resistors or a relay with all turn signal LEDs. It's very simple with the FR-S
Here's a video demonstrating the normal operation: [ame="https://www.youtube.com/watch?v=AAEz3YC8SCA"]FR-S / BRZ Fix Turn LED Hyperblink with Flasher - YouTube[/ame] Thanks! Nick C.
#14 |
Did you try the Valenti taillights with the CF18 flasher relay? Did the turn signals actuate properly, and at what speed? I'm curious, because I got a set of DD switchback units, and I have Spyder taillights in the rear. I got the CF18 relay, but now I'm wondering if I should've gone with resistors instead. I'll report back with my findings.
| Fogs + switchbacks | mrunal91 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 05-29-2014 05:23 PM |
| WTB: Vicious LED Switchbacks | FRSTRM | Want-To-Buy Requests | 2 | 02-04-2014 02:33 AM |
| Anyone try Precision LEDs DRL lightbulbs/switchbacks? | ortizwyld | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 07-12-2013 07:11 PM |
| LED DRLs and Switchbacks question | FR-Slide | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 04-17-2013 05:08 PM |
| Does 6k HID's Go well With the Turn Signal Switchbacks | J-Money | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 01-29-2013 11:41 PM |
