Old 07-17-2014, 10:09 AM   #1
OnionTou
OnionTou's Avatar
Drives: Toyota GT 86
Lost the air bleeder plug. Help!
I was following this DIY Guide on checking and replacing the engine coolant on the DIY forum, and I lost the air bleeder plug.
This one right here:
Long story short, I unscrewed it a bit too much, and it fell into some parallel dimension. I'm pretty sure it did, I moved my car out the garage, moved everything it might have rolled under, and still no sign.
Toyota doesn't have it in stock, and it's a 4-6 week wait, and it costs $50 to get it. Villagescionparts.com has it for $23, but with the S&H to Peru I'm still bound to pay $50, so can anyone take a picture of the plug and the dimensions so I can just buy any other bolt that fits there while my part ships over?
OnionTou is offline   Reply With Quote
Old 07-17-2014, 10:17 AM   #2
d1ck
Drives: Black 2013 FRS
If there's an o ring on it should be a normal metric thread, if there's no oring it's probably a tapered thread. I'd guess 3/8" NPT if so.
d1ck is offline   Reply With Quote
Old 07-17-2014, 10:22 AM   #3
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
It's probably still in the engine bay. Flip the car over and shake it and I bet it will fall out.
Seriously though, more searching in the engine bay may be quicker than ordering a new one.
AdrianG is offline   Reply With Quote
Old 07-17-2014, 10:32 AM   #4
Urmyson
I dropped a socket and it ended up on the plastic panels under the car. I had to take them off and there it was. Try taking those off and see if it falls out.
Urmyson is offline   Reply With Quote
Bleeder valves CB762 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 06-16-2022 12:38 AM
Motive Power Bleeder THEmailman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 24 09-26-2017 12:13 AM
Motive Power Bleeder, which one? ZionsWrath Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 06-06-2015 04:18 PM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 11:53 AM
NAV Install -Pulling VSS, Reverse and factory USB plug from HU 28 pin plug sikest Electronics | Audio | NAV | Infotainment 7 01-21-2013 10:38 PM
