Old 07-18-2014, 11:15 PM   #1
Argento86
Drives: Argento
Can I use Motul 300ls on transmission and differential
I ordered Motul 300ls without doing my research. My question is what do you guys think bout using it on my transmission and diff. I honestly don't feel like returning that's why If I can use it with no issues I'd rather do that.
Thanks
Argento86 is offline   Reply With Quote
Old 07-24-2014, 05:04 AM   #2
limitedblkwrx
Ultimate Member
limitedblkwrx's Avatar
Drives: 2014 Satin White BRZ
You can use it for the rear diff. I wouldn't recommend for the trans.
https://www.motul.com/gb/en/products/recommendation
-Rob
limitedblkwrx is offline   Reply With Quote
Old 07-24-2014, 05:41 AM   #3
You *can*, but I'd recommend you hold onto it and get regular Gear300 for the trans.
The oil won't go bad sitting on the shelf.
Old 07-24-2014, 10:28 AM   #4
FR-S Matt
I just put the Gear 300 in both transmission and differential a week ago. HUGE difference, and holy crap at the shavings in the differential at 18k miles on the magnetic drain plug. I'm sure my car thanked me for that swap. Every shift feels so smooth, power delivery even feels a lot better throwing between gears.
Highly recommend everyone does this. Well worth it, and a very simple task with a lift.
Old 07-24-2014, 10:34 AM   #5
sluflyer06
Drives: 2014 BRZ Ltd - DGM
I would not but the friction modified oil in the transmission personally, either return some of it or hold onto it.
I put the regular Gear 300 in both the trans and diff at 1k miles, my rear diff pretty much stop binding entirely when cold vs the stock fluid. Trans also shifts better.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
Old 07-24-2014, 11:53 AM   #6
Maverickgear
Drives: World Rally Blue BRZ
I can't believe my eyes when I saw how dirty was the oil when I drained out the factory oil. Seriously +1 for this recommendation!
Maverickgear is offline   Reply With Quote
Old 07-27-2014, 06:43 PM   #7
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Gear 300 LS is not recommended for the Trans...
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 07-29-2014, 07:18 PM   #8
skyloran
Honeydew old ID
skyloran's Avatar
Drives: GT86
Motul Gear 300, for both tran/diff...any big difference.?
Used to owned M3 and Lotus, but love my GT86 the most.
skyloran is offline   Reply With Quote
Old 07-29-2014, 07:52 PM   #9
Gear300 works in both the trans and OEM Torsen differential. I wouldn't recommend the Gear300LS for the trans, but it'll work in the diff.
Old 07-29-2014, 07:59 PM   #10
skyloran
Honeydew old ID
skyloran's Avatar
Drives: GT86
I just place my order of the Gear300, will be change it soon. I had 26K on my brz now and it is still running stock fluid. I think it is time to change it.
BTW..how often do i change the fluid?? 15K, 20K???
Old 07-29-2014, 08:46 PM   #11
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
most maintenance schedules are 75k between changes.
DanoFA20 is offline   Reply With Quote
Old 07-30-2014, 12:49 AM   #12
AZP Installs
We suggest 30k for most street driven applications. For tracked cars 1x a season is a good idea.
-Mike Paisan
Old 07-30-2014, 01:13 AM   #13
For street cars, every 30k.
For lightly tracked cars, we recommend once a year, or every 15k.
If you're tracking heavily, then we recommend you get a used oil analysis done to determine your interval, but the common "safe" margin that is often used is every oil change. Remember, the differential is thousands, the fluid is less than 1% of the price of a differential.
Old 08-05-2014, 03:43 PM   #14
skyloran
Honeydew old ID
skyloran's Avatar
Drives: GT86
how many liter of Gear 300 u use for tranny and diff?
motul 300 vs motul 300ls about to buy some need help. NickFRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 03-24-2016 11:51 PM
Aftermarket differential (LSD) options for automatic transmission (AT)? dp1 Tracking / Autocross / HPDE / Drifting 44 07-21-2014 05:30 AM
Transmission fluid blending Redline MTL and Motul Gear 300 okay? imom Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 11-01-2013 09:03 PM
Differential and Transmission Fluid Swap with Red Line Oil - 2013 Subaru BRZ JPxM0Dz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 05-05-2013 06:12 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 07:01 PM
