Old 07-29-2014, 05:54 PM   #1
MurderRider
MurderRider's Avatar
Drives: 2015 Raven FR-S 6MT
OFT 2.0 Stage 1 93 Tune
Now that I've seen the thread on 2.0 MAPS, I am really close to pulling the trigger on an OFT. My car is all stock, so this would be my first upgrade of any kind.
Is there anyone out there who can show me a dyno comparison of stock ECU vs. the 2.0 OFT stage 1 93 tune? I want to see the lines of the torque and HP, and see how much of a difference I can expect. I'm assuming it won't be much, but I'm really not sure.
MurderRider is offline   Reply With Quote
Old 07-29-2014, 06:03 PM   #2
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
If anyone would have it, it would probably be @Shiv@Openflash
BirdTRD is offline   Reply With Quote
Old 07-29-2014, 06:12 PM   #3
MurderRider
K, I don't mind waiting it out. He's probably got a million questions to field right now. Can't bother someone over a free product (as regards MAPS)
Old 07-29-2014, 06:19 PM   #4
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Do it. Currently on 93 stage 1 with no mods. Really wakes the car up. Better gas mileage, no torque dip, linear throttle mapping, better noise from sound tube, smoother idle... The list just goes on and on.
xxBrun0xx is offline   Reply With Quote
Old 07-29-2014, 06:28 PM   #5
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
OP, just to cage your expectations, there is still very much a torque dip on Stage 1. Until you do a power adder or headers, it will be there. Not to the same degree, but still pretty evident.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 07-29-2014, 06:40 PM   #6
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
yup, the tune does not get rid of the torque dip, it's still there. The tune does help with extra umph.
to get rid of torque dip, it's best to get a good header and then tune with OFT OTS tunes, OR get a custom tune.
CamryDS is offline   Reply With Quote
Old 07-29-2014, 06:50 PM   #7
MurderRider
Sounds like it'll be worth it. Is there at least a comparison dyno for the old stage 1 91/93 combination MAP? I know it wasn't a dedicated 93 MAP, but maybe it will serve me in my decision making process.
Old 07-29-2014, 06:53 PM   #8
bfrank1972
Drives: 2013 FR-S Argento
Dyno's don't tell the whole story - definitely a worthwhile upgrade for $500, car idles much smoother, low rpm snatch is way better (rolling in 1st gear, traffic), smoother through the rev range, engine feels much more responsive & eager.
bfrank1972 is offline   Reply With Quote
Old 07-29-2014, 07:01 PM   #9
nunonuna
nunonuna's Avatar
In worst senario, you would lose maybe $50 bucks if you dont like it because you can always sell it after unmarry it from your car, but I dont think that is gonna happen. That was my main reason I chose oft over ecutek. You can not sell tunes and license which will be stuck and locked to your car.
nunonuna is offline   Reply With Quote
Old 07-29-2014, 07:31 PM   #10
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
my mpg went down .... bc this tune makes you wanna DESTROY THE ROADS !!!
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 07-29-2014, 07:35 PM   #11
nunonuna
nunonuna's Avatar
But mine gets better mpg~ before tune 24 mpg only local, now its 27 mpg.
Old 07-29-2014, 07:40 PM   #12
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
I want to see the lines of the torque and HP.
Agree.
This would be awsome to see back to back on a stock car.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 07-29-2014, 07:56 PM   #13
RedFRS4me
RedFRS4me's Avatar
Drives: Firestorm '13
Has anyone tried 93 tune with lower octane? 91/92?
'13 Firestorm
RedFRS4me is offline   Reply With Quote
Old 07-29-2014, 08:14 PM   #14
steve99
The tune will work but you will get knock, the ecu will then pull timing across the entire rpm range to protect the motor from damage. IAM will be reduced to less than 1. The ecu is quite agressive in pulling timing and generally pulls more than it needs to for safety. This results in a reduction in power and torque. The ecu is always trying to return the lost timing so it will cause the engine to knock then pull the timing again, it probably not the best situation to be in for long periods.
The 91 tunes are optimised for 91 and should in theory produce a better result ie power and torque wise than a 93 tune running on 91.
If you run the correct tune for the fuel you are using their should be little or no knock and the ecu will not have to intervene to pull timing constantly.
Once you put the correct fuel back in the ecu will no longer detect knock and the timing will be restored as well as power.
see links below
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 09:15 PM
WTB: Innovate Motorsports Stage 1 W/O Tune jjkerr626 Want-To-Buy Requests 0 01-01-2014 02:32 PM
Ecutek stage 2 tune on stock brz 01s0uljah Software Tuning 15 10-15-2013 03:52 PM
So whate does stage 3 tune do? I already have 2 Frsexxxy Engine, Exhaust, Transmission 17 05-14-2013 07:30 AM
Perrin Stage 1 Tune brz007 Northwest 5 10-03-2012 06:59 PM
