Old 07-31-2014, 03:44 PM   #1
Autocon
Autocon's Avatar
Drives: 2014 Whiteout FRS
Muffler impossible/difficult to remove?
So my buddy and I tried to remove my FRS muffler last night to install my new Nameless Axleback. There are 2 bolts you have to take off and we couldn't get a single one of them to budge, not even slightly. I felt like if I could even pull any harder to try and get them to loosen I would have pulled my car off the jackstands.
Has anyone had this issue? We don't have any power tools, just hand tools. Any tips for removing them? Since we couldnt even get the first easy accessed bolt off I dont know how we would ever get the second one which isnt as easy to get too.
I know I could take it too a shop, but I kinda wanted to do it myself and I would rather not pay someone 40 to 50 bucks to, for the most part take off 2 bolts :/
Autocon is offline   Reply With Quote
Old 07-31-2014, 03:50 PM   #2
Luis_GT
lots of PB Blaster
Old 07-31-2014, 03:52 PM   #3
NickDC88
NickDC88's Avatar
WD-40 and a breaker bar. There's been a few posts with people having the same problem. Mine was easy though. Didn't even need a breaker bar.
NickDC88 is offline   Reply With Quote
Old 07-31-2014, 03:54 PM   #4
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
lefty-loosey righty-tightey :P
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 07-31-2014, 03:59 PM   #5
ToyoburuBRZ
ToyoburuBRZ's Avatar
Drives: Black BRZ
WD-40 and good ratchet. I ran into the same problem but WD-40 freed it up. Still required a good amount of force with just a ratchet
ToyoburuBRZ is offline   Reply With Quote
Old 07-31-2014, 03:59 PM   #6
fenton
Suggest loosening while not on jack stands if you can...leave it on the ground until you break them. PB blaster will probably all you need though...stuff works magic.
fenton is offline   Reply With Quote
Old 07-31-2014, 04:04 PM   #7
MstrSHAKE
MstrSHAKE's Avatar
Drives: 2014 SWP BRZ
Damn, perfect thread to view at work before I head home to install my Nameless AB. Question to the OP, what was the mileage on your car?
also loosen the bolts while car is planted sounds like a good idea, ill try this.
good luck to OP
MstrSHAKE is offline   Reply With Quote
Old 07-31-2014, 04:08 PM   #8
tomaszjanczak
Drives: Silver Subaru BRZ
I had to use a breaker bar and my car only had 4800 miles when I was installing the exhaust.
tomaszjanczak is offline   Reply With Quote
Old 07-31-2014, 04:08 PM   #9
J_kennington
Drives: 2013 asphalt scion FRS
There's no reason to lift the car at all for an AB. Even my 300 lb friend did his without lifting it. Keep it on the ground, use a breaker bar. If you don't have a breaker bar. Rip a fence post out of the ground and use it.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 07-31-2014, 04:10 PM   #10
Shady195
Drives: '13 10 Series FRS #1203
WD-40/PB BLaster and MAP Gas torch.
Seriously invest in a map gas torch. Can't tell you how many times it's saved me with broken exhaust bolts. Best 50 bucks ever spent. Especially if you like to burn things LOL
Also 2 Piece Floor jack handles make excellent breaker bars.
Or if possible use the double wrench method.
Shady195 is offline   Reply With Quote
Old 07-31-2014, 04:11 PM   #11
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
My exhaust came off at 22miles, so i had no need for any of that -- but wd-40 and pb-blaster is very useful.
CamryDS is offline   Reply With Quote
Old 07-31-2014, 04:16 PM   #12
jason.h
Drives: Silver BRZ Limited
Had to use PB Blaster and a torch for mine as well. This is after only 5 months too. I replaced the bolts with SS ones and used some anti-seize.
jason.h is offline   Reply With Quote
Old 07-31-2014, 04:22 PM   #13
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
If the car is lowered, it can get impossible to do it without lifting car.
Old 07-31-2014, 04:23 PM   #14
Shady195
My old man used to rag on me about using anti seize all the time. It took a few knuckle breaking moments that could have been easily avoided had I used anti seize... I now use it religiously.
Still impossible to get RED as a colour for the BRZ? DarthNads CANADA 10 08-27-2013 07:12 PM
Ideal resonator placement to remove drone on muffler deletes? CaptainSlow Engine, Exhaust, Transmission 22 05-20-2013 10:34 AM
Objective Choice Of Coilovers Impossible Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 37 05-14-2013 07:24 PM
Is my game Impossible Shoota challenging enough mechaghost Off-Topic Lounge [WARNING: NO POLITICS] 4 02-01-2013 05:12 PM
will polishing your car to remove swirls remove opti-coat? bacon_cheese_beer Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 10-25-2012 11:41 PM
