Old 08-03-2014, 07:57 PM   #1
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
Koni/GC Suspension, SPC LCA's, Wilwood BBK, OEM Camber Bolts
Hi guys,
My car went back to pretty much stock this weekend, so I've got parts for sale. Local pick-up around Chicago is preferred, but I can ship for additional cost. Reasonable offers will be entertained.
1) Koni's & Ground Control Coilovers w/ GC Camber Plates. First of all, this is not the set-up you purchase directly from GC, this was custom built using off-the-shelf Koni Yellow's, GC sleeves, Eibach springs, and GC camber plates. Secondly, these won't slam your car, so this is not a solution for going low. This combination has worked well for me on and off the track, and is easy to customize with the variety of 2.5" diameter springs available from Eibach, as well as get the desired camber adjustment with the camber plates. I've also trimmed the bumpstops by 1/2 inch, as per GCAdam's recommendation. Used on the car for approximately 10k miles.
The current spring specs are : Front: 5"/2.5"/425lbs, Rear: 6"/2.5"/440lbs
All of the struts are solid (not blown), with no leaks or adjustment issues. The collars on the coilovers spin freely, and all the joints and bearings on the camber plates are in working order.
The only issue, if you can even call it that, is the fact that I've ran them the entire winter, and certain non-treated/anodized parts (camber plate mounting bracket, lower front strut bolts, and rear struts) have developed some corrosion from the salt, which only affects the aesthetics. I've tracked the car with these before and after the winter, and noticed no difference in performance.
Also, I have an extra front Koni insert (not blown, but broken adjuster nipple), and a bunch of extra hardware that will be included. I'll also provide the original purchase receipt and my contact information to the buyer, so he/she can claim warranty, if needed.
SOLD
2) Used SPC Rear LCA's with New Toe Bushings. Version 2 LCA's which give you up to -2.5* camber in the rear. Solid design and easy to adjust. Come with toe bushings that I've never installed. Minor surface corrosion from the winter salt.
SOLD
3) Used Wilwood 6-Piston Front BBK. This is a WRX kit that I got from NASIOC, and it fits the FR-S/BRZ. In fact, the only difference between this kit and the FR-S/BRZ specific kit from Wilwood, is the type of caliper mounting (lug vs. radial; see links below to compare for yourself).
This kit (140-7005): http://www.wilwood.com/BrakeKits/Bra...temno=140-7005
FR-S/BRZ kit (140-12870): http://www.wilwood.com/BrakeKits/Bra...emno=140-12870
What's included with the kit:
- Both front calipers and mounting brackets with hardware
- Both front rotors and hats
- Stainless steel brake lines with an additional brand new line
- 2 spare bleeder screws (new)
- Brake pads are NOT included
Overall, the kit is in perfect working condition, but I will note a few things. One of the rotors has a "groove" in it (see picture below), so I would replace the rotor rings if I were to track the car. One of the lines rubbed on something and rubbed through the steel braiding, but I'm including a brand new replacement line with the sale. Lastly, this kit was used on multiple tracked vehicles, so it does have chips and scratches in the powdercoat on the calipers from removal/intallation. I touched it up a little, but if you want to put this on your show car, I would recommend getting them repainted or powder coated.
SOLD
4) Brand New OEM Camber/Crash Bolts. (Cusco knob is sold)
SOLD
Feel free to PM me with any questions or additional picture requests.
Thank you!
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 08-03-2014, 10:54 PM   #2
boxer_boy
Drives: 2014 SWP BRZ Limited
PM sent.
boxer_boy is offline   Reply With Quote
Old 08-03-2014, 11:36 PM   #3
SportInjected
PM replied
'13 Argento FR-S
Old 08-04-2014, 01:34 AM   #4
KenTK808
Drives: White 2014 Scion FRS
Pmed
KenTK808 is offline   Reply With Quote
Old 08-04-2014, 11:13 PM   #5
SportInjected
^ right back at ya
'13 Argento FR-S
Old 08-05-2014, 05:05 PM   #6
xlonelydrifterx
Drives:
Do you still have the gc/Koni for sale?
xlonelydrifterx is offline   Reply With Quote
Old 08-05-2014, 08:48 PM   #7
SportInjected
Yes, everything listed is still available. I'll update as parts get sold.
'13 Argento FR-S
Old 08-06-2014, 04:27 PM   #8
carlossanchez89
2Supras1FR-S
Drives: 13 Scion FR-S, 87 Supra
PMD
carlossanchez89 is offline   Reply With Quote
Old 08-06-2014, 04:48 PM   #9
s13kid989
Drives: 2013 Whiteout Frs
hmm.. Do you know if the Wilwoods will fit behind a set of 17x9 +45 RPF1's?
s13kid989 is offline   Reply With Quote
Old 08-06-2014, 06:25 PM   #10
carlossanchez89
2Supras1FR-S
You will need 18's to clear BBKs
Old 08-07-2014, 09:23 AM   #11
SportInjected
They should clear 17" wheels, but I'm not sure about the +45 offset. May need a spacer.
'13 Argento FR-S
Old 08-12-2014, 10:11 PM   #12
SportInjected
Anyone need some oem camber bolts?
'13 Argento FR-S
Old 08-21-2014, 09:44 AM   #13
SportInjected
Bump for the bolts. Let's clean this thread up!
'13 Argento FR-S
Old 08-22-2014, 09:52 AM   #14
SportInjected
All gone! Thanks everyone!
'13 Argento FR-S
Camber bolts: Max camber tricks bfrank1972 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 06-03-2014 11:01 AM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
H&R Camber Bolts deedz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-08-2013 10:00 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-28-2013 12:38 AM
