Drives: BRZ Pearl White
Suberman's guide on how to make the car fix his inability to drive correctly.
First, cut one half inch or so out of the rear bump stops. I cut this out of the hard end between the taper matching the shock dust boot and the middle section. Doing it again I'd just cut off the soft end. Once you do this your rear suspension will more or less stop hitting the rear bump stops in normal fast street driving which will make your BRZ/FRS much quicker in the corners.
Second, and if you can combine this with the above for economy since you need to take out and dismantle the rear coilovers to cut the bump stops, fit better rear shocks. I recommend Bilstein B6 (HD in North America). You don't have to do the fronts as well, as more than 75% of the improvement in grip will happen at the rear of the car. Third, fit better front struts. I like the matching Bilstein B6. These inverted struts firm up the steering feel and front suspension rigidity in corners. Koni makes a good one also that will fit the stock suspension travel. There is no need to increase the spring rate or shorten the springs because this chassis has lots of grip on stock springs and with stock ride height. Fourth, if you don't like the idea of reducing the rear roll stiffness then fit a slightly larger front bar instead, though I'd cut the rear bump stops and fit the correlating 16 mm rear bar as well if it were my car. Finally, get better tires either in 215 or 225 width on stock sized rims or maybe 17 x 7.5. I fit Michelin Pilot A/S 3 but there are lots of choices out there, many of them much cheaper than Michelin especially if you don't need cold weather grip. If you want maximum grip buy the best high performance summer tires you want to afford but any improvement in tire grip improves the feel of this car. Don't do any of this if you like to drift this car. Last edited by Ubersuber; 08-08-2014 at 07:58 PM. |
@CSG Mike @Racecomp Engineering @ZDan
Thoughts gentlemen?? For everyone else, I wouldn't go cutting your bump stops on stock springs. This guy claims to know more than the suspension engineers at Toyota. There is absolutely NOTHING wrong with cars using the bump stops as part of the effective spring rate, especially when they're designed to do so. Most cars on the road are designed like this because it gives a more comfortable ride. He also contradicts himself, even in this thread. He claims you need to cut the bump stops to reduce rear spring rate, but then suggests adding a stiffer rear bar.
Lacking brains
Drives: frz
Tires first, second, third, fourth
Because compromise ®
Drives: Red Herring
Frosty Carrot
Drives: The Atomic Carrot
![]() I've cut bumpstops before. It's not a terrible option, if your budget/willpower/available aftermarket options are limited. The main difference you'll notice is with the transition from spring-controlled to (spring+bumpstop)-controlled. Instead of having a progressive transition... it will be more "flop and plant" operation. I noticed it most when doing slaloms. Weight transfer was not exactly smooth. Effective, but not elegant.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club |
I use the bump stops as part of the rear spring rates. The car is designed to do so from the factory (yes, we know there is short travel, and so do the Subaru engineers... hence why the bump stops are part of the suspension).
This is also why the spring rates seem so "off" from the factory; the springs alone don't tell the whole story. |
Maximum puntential
Drives: 2013 DGM BRZ 6MT LTD
Clutch grab adjustment should be one of the first mods done.
Drives: Strangely.
Senior Addict
Drives: 86 GT
The OP should go to Toyota or Subaru and teach all those engineers a thing or two about suspension tuning. Maybe even Bilstein since they designed the B6 and B8 dampers to be used with full length bumpstops. Guess they were wrong too.
#10 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
Suberman is that you????
Sent from my Nexus 5 using Tapatalk |
#11 | |
Site Moderator
Drives: Stuff
^^ this. The bumpstops are part of the suspension. They are there partly to protect the damper but also to increase spring rates when the coilover assembly compresses enough. They are even progressive for that reason. Hell aftermarket spring companies design specific bumpstops in some cases and even include that in their spring rate calcs with a specific deflection %. I've cut them *when needed* but I wouldn't on the stock rates/stock springs. The OEM dampers are also quite good for street driving. They aren't perfect but they are fairly well matched to the stock springs, which is the point... They don't have fancy valving, but neither do Bilstein HDs (and I like the Bils). Then to suggest those tires... when tires make the most difference.. I guess he never specified what difference he was trying to achieve though.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#12 |
It most definitely is.
#13 |
Drives: Red Herring
Thanks!! That made me laugh out loud.
#14 | ||
Off Topic
Then replace the front struts. Didn't you just tell us not to replace them? And why replace the struts at all? The OEM struts are fine. Replace the springs and keep the OEM struts. Quote:
Stop trying to reinvent the wheel, dumbass. There are plenty of people who know a whole lot more than you who have already designed much more effective systems that don't require hacking bits of the OEM suspension off or replacing two out of four struts at a time. Quit trying to sound like the authority when you have no idea what you're talking about. |
| Tags |
| 225 width perf snow tires, 7thgear haz flair, i'm afraid of the snow, lawyers can't drive, magical suspension expert, my first period, überstupid |
| How to do E85 correctly? | Anthony | Engine, Exhaust, Transmission | 95 | 12-11-2017 05:06 PM |
| Perrin 3" CBE - did I install correctly? | 1Cor10:23 | Engine, Exhaust, Transmission | 14 | 12-08-2014 01:29 PM |
| Boost gauge not reading correctly | Pneub | Forced Induction | 11 | 10-30-2013 01:39 PM |
| Drive Away prices on Toyota Website. Make sure you are not getting Ripped Off! | Aventador87 | AUSTRALIA | 8 | 06-17-2012 08:35 AM |
| Toyota 86 first drive review (Car Guide) | a6ela | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 03-14-2012 01:34 PM |
