Old 08-12-2014, 01:15 PM   #1
Apex_BRZ
Drives: 2013 Subaru BRZ Limited (WRB)
Track Mods - Plan
Trying to decide where to go from here on modifying the car to be "better" and more reliable at the track. Here is the short list of what I have on the car so far:
Engine/Cooling
Stock
Brakes
Carbotech XP10/XP8
StopTech Braided Lines
Touge Factory Front Brake Duct Kit
KNS Titanium Brake Pad Shims
Porsche GT3 Lower Air Guides
GrimSpeed MC Brace
Motul RBF600
Suspension/Steering/Tires
Perrin Solid Steering Rack Mounts
Bridgestone RE-11A Tires (215/45/17)
Enkei RPF1 Wheels
-1.4* Front Camber
At this point, I'm not sure where I want to go next. Things in mind are brake ducting/cooling, oil cooler, and RSR Coilovers. I'd really like an oil cooler, but nervous about warranty issues should I run into a problem. I know there are a million swaybars and braces available, but I haven't seen any hard convincing data that they are worth my time. The RSR Coilovers seemed promising and designed exactly for what I'm interested in. I haven't seen any brake fade yet at tracks like Autobahn or Road America, but as I learn to drive harder/faster...I'd like to be on top of the brake setup and head off any potential issues.
I'm very particular about the parts I put on the car and try not to hurt the balance or put on unnecessary braces, sways, etc. Willing to discuss this if there is good information out there from more experienced folks.
What do you guys think?
Apex_BRZ is offline   Reply With Quote
Old 08-12-2014, 02:49 PM   #2
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Originally Posted by Apex_BRZ View Post
Trying to decide where to go from here on modifying the car to be "better" and more reliable at the track. Here is the short list so far:
Engine/Cooling
Stock
Brakes
Carbotech XP10/XP8
GrimSpeed MC Brace
ATE SuperBlue (switching to Motul RBF600)
Enkei RPF1 Wheels
I wouldn't worry about the SS brake lines. Also I would definitely use a separate set of pads/rotors and better pads (Raybestos ST43 or ST42 pads and Centric Premium blank rotors are good options) and add some sort of brake ducting.
Also what size of RPF1 are you planning to get? 17x9 +35mm is way to go since in future you may fit wider tires on to them
glamcem is offline   Reply With Quote
Old 08-12-2014, 02:56 PM   #3
I'd recommend Speigler lines over Stoptech.
I'd also recommend the same brake pad compound front/rear.
The oil cooler won't affect warranty. If you're REALLY worried, use the OEM FA20DIT oil cooler. It's not enough, but it's far better than nothing.
Old 08-12-2014, 03:08 PM   #4
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Use Torque RT700 brake fluid
Use Yokohama Advan AD08R 225/45/17
Must have an oil cooler - recommend Jackson Racing
Recommend RaceSeng front top hat and SPL Pro rear LCA with eccentric lockout bolt
Contact CSG for a package deal, they know their sh#t
Use stock suspension - superior than 99% of the coilover out there
Use stock sway bars - perfectly balanced
No need brake cooling ducts
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 08-12-2014, 03:27 PM   #5
Not everyone is willing to commit to the pads we use...
Old 08-12-2014, 03:28 PM   #6
RehabJeff86
hey i use 999 mang.... still no need brake cooling ducts
Old 08-12-2014, 03:57 PM   #7
Apex_BRZ
I should clarify that the list above is what's already on the car.
Just looking to see what's best from this point forward. Sounds like brake ducting and oil cooling is the next step.
Old 08-12-2014, 04:20 PM   #8
Oil cooler would be the next step I recommend.
Old 08-12-2014, 04:42 PM   #9
Apex_BRZ
Any particular setup? I've seen other threads with recommendations ranging from an OEM style sandwich plate to an independent cooler. Then there are the amount of rows. Car will stay N/A.
EDIT: Interested in the Jackson Racing cooler. I imagine installation is simple, since it uses factory mounting points.
1. Any kind of oil pressure drop?
2. Does it affect coolant temps at all being in front of radiator?
Old 08-12-2014, 04:54 PM   #10
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
I really enjoy my RSR's (Sports-i). The I use 9 clicks up front and 6 in the rear, starting from full soft. Up to this point I have not adjusted camber. I will be adjusting to the 1.5 degrees camber soon (only two settings, 0 and -1.5). They have optional pillow-ball top hats for more camber adjustments if needed. However, I most likely won't be purchasing those.
rb6freak is offline   Reply With Quote
Old 08-12-2014, 04:57 PM   #11
Apex_BRZ
Have you used them on the track? If so, what are your thoughts between stock track and RSR track experience.
Old 08-12-2014, 05:10 PM   #12
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Yes, 5 times so far. RSR USA let me test drive their FRS shop car to test the suspension before I purchased. I like companies that are willing to go out of their way to let you test their products. I like the simplicity and the urethane bushing are super comfortable and quiet. I have more grip on low/medium speed turns and with uneven payment no doubt. Not yet tested high speed turns on the track > 50mph. I will be on the big tracks a few times before the end of the year.
I never tracked with full stock - However I did one time with just Swift springs (BRZ). Huge difference with any adjustable coilovers. Daily driving is more comfortable in my opinion than when I had lowering springs.
Old 08-12-2014, 05:12 PM   #13
We prefer the Jackson Racing setup as it uses the largest oil cooler core, and uses factory holes (no cutting/drilling). One difference is that it uses its own bracket to support the oil cooler.
Old 08-12-2014, 08:34 PM   #14
Apex_BRZ
Along with an oil cooler, would it be wise to install a catch can or air/oil separator? My other car is a supercharged V8 and it was essential to add a catch can due to excessive blow-by.
Is it still wise to have one on an N/A BRZ?
Backup plan when stuck at the track ayau Tracking / Autocross / HPDE / Drifting 39 07-26-2014 05:44 PM
Keeping track of mods, plans zinzan Other Vehicles & General Automotive Discussions 20 03-06-2014 03:27 PM
When do you plan to get your BRZ? switchlanez BRZ First-Gen (2012+) — General Topics 33 08-16-2013 02:25 PM
Do you plan to track your car? gmookher Tracking / Autocross / HPDE / Drifting 28 12-13-2012 09:57 PM
Maintenance Plan? ngabdala BRZ First-Gen (2012+) — General Topics 11 08-11-2012 06:39 PM
