Old 08-23-2014, 12:02 AM   #1
KenTK808
Drives: White 2014 Scion FRS
12v Cigarette Lighter Wire Color
I just broke my multimeter and I need to know which wires on the center console cigarette lighter is the + one. I think its the white wire. I'm using it as the power to a switch I'm using for fog lights.
Your help is greatly appreciated
KenTK808 is offline   Reply With Quote
Old 08-25-2014, 01:22 AM   #2
greencounty
greencounty's Avatar
The cigarette lighter socket in the console has an all white wire for the +12V and the one in the glove compartment is white w/a black stripe.
Garage:
2013 BRZ Limited 6MT - Galaxy Blue
1994 Ford Probe GT 5MT - Red(some would argue pink)
1969 Mustang Fastback 4MT - Royal Maroon
greencounty is offline   Reply With Quote
Old 05-18-2019, 09:52 PM   #3
canyons
canyons's Avatar
Drives: 2013 Supercharged BRZ, E85, Ohlins
confirmed, the glove box lighter socket has +12v switched accessory power on the white wire w/black stripe.
I needed accessory power in the engine compartment, and it was fairly easy to vampire tap this wire and run a shunt wire through the nearby rubber grommet using a coat hanger. If you try this, i recommend you strip the insulation from the factory wire before applying the vampire tap. The factory wire coating is quite tough and the vampire tap may not puncture it.
Apologies for resurrecting a dead thread.
canyons is offline   Reply With Quote
Few things I found out on the BRZ - extra cigarette lighter outlet 86design BRZ First-Gen (2012+) — General Topics 42 04-15-2023 12:56 AM
BRZ antenna wire color? glorydays Electronics | Audio | NAV | Infotainment 0 05-23-2013 05:27 PM
Five Axis Design S5:F Gunmetal, anyone have these on a lighter color BRZ? OICU812 BRZ Photos, Videos, Wallpapers, Gallery Forum 0 03-30-2013 11:49 PM
Five Axis S5:F wheels "GUN METAL" on a lighter color FR-S or BRZ? OICU812 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 03-30-2013 11:38 PM
Power Ports/ Cigarette Lighter Issues Tanuki Issues | Warranty | Recalls / TSB 6 11-21-2012 05:59 PM
