Old 08-27-2014, 02:43 PM   #1
ThatManAnt
Drives: Whiteout FR-S 6spd
MPG
What i was told growing up was the higher the rpm, the more gas you use. But on our car, when you click the ODO button to switch it to see how many mpg your getting, it shows less the more you step on the pedal. So my question is, what uses more gas high rpms, more pushing on the throttle, or both are about the same? Just curious thanks
ThatManAnt is offline   Reply With Quote
Old 08-27-2014, 02:50 PM   #2
Akari
Drives: 2013 DGM BRZ
This isn't really a one or the other answer.
High RPM creates extra unnecessary rotating energy in the engine/transmission that results in lower MPG.
At the same time lugging your engine uses extra fuel and creates extra heat which lowers your MPG.
For the best MPG you want the lowest gear possible with very little throttle without lugging the engine. Remember, your pedal isn't a direct link to the amount of air/fuel being let into the engine, if the ECU has to intervene to keep you moving you're likely to get horrible MPG at that point.
I typically average ~31MPG while revving my car out to 7k+ at WOT many times a day. How? -I sit in the perfect optimal gear/throttle position while cruising on the highway.
Akari is offline   Reply With Quote
Old 08-27-2014, 02:53 PM   #3
FR-S Matt
Keep shifts under 3k rpms and don't push down far on the pedal. I lost MPG going to my 18X9.5 wheels but not very much. Granted even with flooring it and driving with shifts around 3.5k - 4k, I got 25 mpg my last tank of gas. I get 28 mpg if I drive like a grandma. Tradeoff isn't much really. This car gets great mileage even driving hard, but not everyone's car is the same.
Old 08-27-2014, 03:30 PM   #4
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
I am pretty easy on the gas pedal most of the time, generally shift from 3.5-4k and cruise around 2.1-2.6k. I'm averaging 29.3-29.8mpg depending on whether I've done much highway driving in a given amount of time. Most of my driving is on a major surface road, about 10-14 miles a day.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 08-27-2014, 05:49 PM   #5
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
A few 7k RPM pulls a week and I still maintain ~27-28 MPG. The trick? I shift around 3k-4k RPM and use 6th gear as much as possible.
Eurasianman is offline   Reply With Quote
Old 08-27-2014, 06:54 PM   #6
skyloran
Honeydew old ID
skyloran's Avatar
Drives: GT86
if you want good MPG, shift between 2.5k-3K, perfect for DD, also keep use 6th as much as possible.
Used to owned M3 and Lotus, but love my GT86 the most.
skyloran is offline   Reply With Quote
Old 08-27-2014, 08:40 PM   #7
Sypher
Sypher's Avatar
Drives: '13 Ultramarine FR-S M/T
i daily my car with mostly highway miles and i average 31 mpg. my trick at the beginning is to use the "fuel efficiency shift light" (or whatever its called) on the dash. coupled with easy throttle input. I usually shift at 3k-3.5k
Mod List:
FT86SF Catted header / Nameless combo pipe with cat and res/ FT86SF V1 CBE / GrimmSpeed Intake / OFT STG 1 GS Tune / Fortune Auto 500's
Sypher is offline   Reply With Quote
Old 08-27-2014, 09:05 PM   #8
nguyen_er
nguyen_er's Avatar
Drives: 2013 Raven FR-S
So let's say I'm going like 40 mph. Should I stay in 6th at 1800 rpm or 5th at 2300 rpm?
nguyen_er is offline   Reply With Quote
Old 08-27-2014, 09:24 PM   #9
fantah
fantah's Avatar
Drives: 2013 BRZ Premium Black
5th gear is better in this situation. Car struggles under 2k RPM. I'm getting 31.9 MPG. Lots of highway driving though.
fantah is offline   Reply With Quote
Old 08-27-2014, 09:39 PM   #10
nguyen_er
nguyen_er's Avatar
Thanks. Yeah I average 31. But I usually stay in 6th on the streets. I think I drive closer to 45 though.
Old 08-27-2014, 09:43 PM   #11
FR-S Matt
50 mph is a good spot for 6th gear. 40-45 mph on a flat road.
Old 08-27-2014, 09:53 PM   #12
troek
troek's Avatar
Drives: 2012 Toyota 86
i just do whatever i have to that lets me barely press the gas pedal. on the highway, i can easily get 400 MILES out of a tank.
Old 08-27-2014, 09:53 PM   #13
Kaotic Lazagna
Drives: GR Corolla
I shift around 3k rpm with light throttle input. If you can withstand going (legally) slow on the freeway, keep your throttle at 17% unless you dip below 50 mph. I've gotten 41 mpg on a tank before, and am averaging 36 mpg.
Old 08-27-2014, 09:55 PM   #14
Kaotic Lazagna
Drives: GR Corolla
http://www.yarisworld.com/forums/sho...postcount=2083
