Drives: Scion FRS
Tomei UEL Header Installation Tips
Just purchased a Tomei UEL header and overpipe. Any of you guys had any tips when it comes to the installation of these items. I'm going to schedule an appointment next week to rent a lift and get these items installed. Please advice.
#2 | |
Drives: '13 10 Series FRS #1203
Patience, heat and some PB Blaster/WD 40. |
Drives: Scion FRS
Drives: Whiteout FRS
Have another person there to hold the headers during install so it won't fall on your face. I think everything else you can pretty much do by yourself.
Yesterday I was removing my headers to install my turbo kit, and I tried to hold it up myself by pressing my arm against it while unbolting it... but it still kinda swiveled down and hit my face a little LOL. Maybe I will figure out a 1 man install version eventually. |
Drives: Scion FRS
Lol. I hope you're alright. I'm going to be bringing my brother to help me out.
Drives: 2014 BRZ MT (Sold); 2006 V70R
FIRST THING is to PB Blast the bolts connecting the header to the overpipe. More than one person has snapped a bolt taking it off as the nut may be seized or bind halfway. Other than that, a deep socket is needed for engine side bolts is required. Not much else, and pretty simple. A u-joint would help too.
'14 BRZ LTD MT DGM
#7 | |
Drives: Scion FRS
Thanks for the tip. Also, where you able to torque down the engine bolts? I've heard some header bolts are hard to tighten down because of the weird position they're in. Sent from my iPhone using Tapatalk |
Depends on the design of the pipes. If it covers the bolt, then you'll have to guesstimate the tq for that bolt. I had to use a u-joint for at least one bolt on my P&L header install, but ensuring held up fine, no issues. Hardest part is that one top bolt on the overpipe.
'14 BRZ LTD MT DGM
#9 | |
Drives: 2014 BRZ Limited SWP 6MT
When bolting on the headers and overpipe try to get as much clearance on the passenger side of the overpipe as possible, so when tightening the screws try to push it as much to the driver side and more towards the back of the car as possible because i had clearance issues with my overpipe touching the passenger side of the engine bay and would rattle so had to reposition. When bolting the exhaust back on screw everything lightly, then start tightening from the header and back. Also great thing about these Tomei header is they come with all 3 new gaskets and also a nice heat wrap for the oil pan which is actually amazing. Other than that there's not much else to it, make sure you tighten everything properly to avoid exhaust leaks, and enjoy your headers
#10 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
I have a Tsudo UEL header but I'll share tips from my install:
Good luck Last edited by B-R-Z; 08-31-2014 at 10:01 PM. |
#11 |
That reminds me. Disconnect the o2 sensor plugs, remove header, then unscrew o2 sensors. Much easier.
'14 BRZ LTD MT DGM
#12 |
Drives: 2014 FR-S
I lifted the engine for the stock op to come out and also to put the new one in
#13 |
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
Easy enough to do on a set of ramps?
#14 |
Drives: 2014 FR-S
| Evasive Tomei Header Group Buy | Evasive Motorsports | Groupbuys | 424 | 08-05-2018 01:55 PM |
| *Groupbuy: Invidia N1 and Q300 Cat-Back Exhausts (SS tips, T.I. tips) -fteightysix* | 86SPEED | Groupbuys | 74 | 11-09-2016 02:45 PM |
| Quick tips for Remote Start installation | trueno86power | DIY (Do-It-Yourself) Guides | 12 | 12-07-2014 04:47 PM |
| Tomei Exhaust with Tomei Straight Pipe | leech | Engine, Exhaust, Transmission | 10 | 01-07-2014 11:42 AM |
| FS: Tomei UEL Header (WRX) | [deleted] | Miscellaneous | 0 | 03-19-2013 10:58 PM |
