Old 08-30-2014, 02:58 AM   #1
bobsacamenoh
Drives: 2014 Scion FRS
Switching back to 17" Wheels from 18" for acceleration feel?
Anyone do this switch? I recently switched from the stock wheels to an 18 x 8.0 wheel with 225/40/18 Pilot Super Sports. The grip is awesome, but the acceleration "feel" is noticeably less quick. The 18"s have only been on for a day and already thinking of switching to a lighter weight 17. Should I just wait out the adaptation period for my senses to get used to it? How long did it take you to get used to the feel or did you never get used to it and just switched back?
Thanks
bobsacamenoh is offline   Reply With Quote
Old 08-30-2014, 03:35 AM   #2
br@ndon
br@ndon's Avatar
Drives: 2014 Monogram FR-S
Did you get an alignment?
br@ndon is offline   Reply With Quote
Old 08-30-2014, 03:43 AM   #3
bobsacamenoh
Not yet. Was waiting for my coil overs to be installed before doing that. Should I get the alignment now or just wait? Might be a couple more weeks until I get the coil overs on. Sorry, I'm a noob to all this.
Old 08-30-2014, 03:51 AM   #4
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Are the 18 inch wheels heavier than the stock 17s? It could just be the extra weight from the wheels.
N1rve
Old 08-30-2014, 04:03 AM   #5
bobsacamenoh
The wheels are about 0.25lbs heavier. Not sure about the wheel + tire weight vs. stock tho.
Old 08-30-2014, 04:59 AM   #6
abraxis
Drives: many
Even if you kept the weight the same, it would still feel slower going to 18s. You've moved the mass further out.
abraxis is offline   Reply With Quote
Old 08-30-2014, 04:23 PM   #7
skyloran
Honeydew old ID
skyloran's Avatar
Drives: GT86
alignment will help.
Used to owned M3 and Lotus, but love my GT86 the most.
skyloran is offline   Reply With Quote
Old 08-30-2014, 04:30 PM   #8
stonenewt
Drives: BMW 120d
My BMW seemed to accelerate slower on PSS than Efficient Grip Performance. This is at odds with a g meeter says that the PSS are oh-so-slightly faster in 1st & 2nd. Just saying.
stonenewt is offline   Reply With Quote
Old 08-30-2014, 05:21 PM   #9
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Why will this help?
dradernh is offline   Reply With Quote
Old 08-30-2014, 05:33 PM   #10
pantdino
Drives: Firestorm 2013 FR-S
Thanks
I have never read anywhere that the weight difference with a +1 change will make a noticeable difference in acceleration or throttle response, despite the increased angular momentum from having more weight further from the axle .
Increased unsprung weight and shorter sidewalls will give you a harsher, possibly less well controlled ride
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 08-30-2014, 08:30 PM   #11
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Why are people talking about alignments for straight line acceleration, when no suspension has been changed!!
The stock 17's are super heavy pieces of shit. 18's that are even heavier have more weight further away from the wheel center as abraxis stated. Further, both the 16 and 17" oem tires have fairly light sidewalls, so wider tires put even more weight away from the wheel center.
As far as I know even if you have a BBK you don't need 18's except for looks.
Looks =/= performance.
It's good that you noticed immediately that the car is sensitive to rotating mass. The oem suspension is sensitive to unsprung mass too. You have more tire grip which you noticed but likely have less mechanical grip right now. It works better the lower weight your wheels and tires are. That won't matter when you switch to stiff coils though.
Old 08-30-2014, 08:35 PM   #12
stugray
Drives: 2013 GBS BRZ Limited
If you increase from 17 to 18" tires and keep the same tire aspect ratio, then the circumference of the tire will increase.
A larger tire circumference will mean less available torque at the contact patch than before.
This would result in lower acceleration.
What size tire did you have before and what size tire after?
Simple Sound Tube Switching "on/off" Tech DIY (Do-It-Yourself) Guides 266 03-10-2021 05:12 PM
If I'm na and going e85 would switching from a 2.5" exhaust to 3" make a noticeable Anthony7515 Engine, Exhaust, Transmission 4 04-18-2014 02:16 PM
"Buzzing" From behind the steering wheel under hard acceleration husker741 Issues | Warranty | Recalls / TSB 13 06-30-2013 02:18 PM
Steering wheel/dash "rattle?" upon heavy acceleration? brett_g Issues | Warranty | Recalls / TSB 2 08-04-2012 05:52 AM
Switching stereo from TC to "FR-S" mode frsinpa Electronics | Audio | NAV | Infotainment 8 06-21-2012 11:48 PM
