Old 05-31-2012, 04:45 PM   #1
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
DIY DIRECTORY
BASICS
Jack/Support Points and Methods
Jack Buddies $10
Factory Service/Repair Manual (FR-S Only)
COSMETIC/EXTERIOR
86 Badge Painting
Debadging
Five Axis spoiler install video
Front Bumper Removal #1
Front Bumper Removal #2
Front Bumper Hole Drilling
Front License Plate Center Mount (FR-S Only)
Taillight Gasket Replacement
Vinyl Wrap Tutorial
ENGINE/DRIVETRAIN
Accessory Belt Removal & Replacement
Clutch Engagement Adjustment
Coolant Check and Replace
Crank Pulley Installation
Exhaust & Manifold Removal
Exhaust Installation, ISIS Cat-Back
Fuel Pump Upgrade
Intake & Noise Generator Delete
Intake, Airaid with Snorkel Delete
Intake Inlet Pipe, AVO Silicone Replacement
Oil Change
Radium Catch Can
Transmission and Differential Fluid Change
TRD Sound Changer
INTERIOR/AUDIO-VIDEO
Airbag Warning Light Deactivation
Alarm Activation (BRZ Limited Only)
Armrest Fabrication
Blocking your TPMS Light (FR-S only / BRZ maybe?)
Changing Clock/HVAC LEDs (FR-S Only)
Customizing Nav Unit Start-up Screen (BRZ only)
Dash Cam Installation, Blackvue DR400G-HD
Dome Light & License Plate Light LED Replacement
Gauge Cluster Hood Install by JPM Coachworks
Kartboy Short Shifter Installation
Knee Pad (JDM) Installation
Nav Install with e-Brake Bypass (FR-S only / BRZ maybe?)
Parking Brake Boot, Adding Red Stitching (FR-S Only)
Parking Brake Boot, Swapping to BRZ Version (FR-S Only)
Pioneer AVIC Z150BH Aftermarket Head Unit
Rearview Mirror Removal to Add Radar Detector
Rearview Mirror, JDM Frameless Upgrade
Rear Deck Panel Removal for Tinting
Steering Wheel/Airbag Removal
Sound Tube Switcher
Throttle Controller, AVO DBW Setup
Trunk Liner (BRZ) Installation (FR-S Only)
Trunk Mat Conversion to Rubber Liner (FR-S Only)
LIGHTING/ELECTRICAL
Alarm Installation Wiring Diagram
Battery & Tray Upgrade
Blacking Out Headlight Reflectors (FR-S Only)
Daytime Running Light (DRL) Delete (FR-S Only)
EasyGo Push Start Button Install
FR-S fogs using BRZ Stalk
HID Conversion/Installation (FR-S Only)
Hella Horns
Horn Upgrade, Hella Supertone
JWMotoring LED turn signals
Projector Headlight Bixenon Conversion (FR-S Only)
Rear Fog Light Enable
Rear Fog Light With Brake Light
Replacing Amber Signal Bulbs with Chrome Bulbs (BRZ only)
Replacing Amber Signal Bulbs with Chrome Bulbs (FR-S only)
Sidemarker JDM Clear Swap #1
Sidemarker JDM Clear Swap #2
Sidemarker Turn Signals
Tail Light Housing Blackout w/ Dremel
Tail Light Housing Blackout w/ Soldering Knife
Tail Light Lens Smoking or Redding
Traction Control Override Switch
SUSPENSION/HANDLING
Brake Pad Upgrade/Changing
Caliper Removal and Paint
Coilover Installation
Lowering Spring Installation
Perrin Master Cylinder Install
Rear Stabilizer Reinforcement Bracket
Strut Bar (rear) Installation, Cusco
Strut Removal & Replacement
Sway Bar (Stabilizer Bar) Install
Suspension Options List
WHEELS/TIRES
FT86Club Wheel Directory
Wheel 101
MISCELLANEOUS
License Plate Picture Frame
WingsofWar is offline   Reply With Quote
Old 05-31-2012, 04:45 PM   #2
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
reserved for future expansion
Old 05-31-2012, 04:53 PM   #3
SpeakBeck
Drives: SRT4
We are doing a write up on the audio portion of the FRZ/BRZ. Should have it posted by next week.
SpeakBeck is offline   Reply With Quote
Old 05-31-2012, 04:54 PM   #4
DarrenDriven
NW Region Moderator
Sweet!
Old 06-01-2012, 12:10 PM   #5
DarrenDriven
NW Region Moderator
Added Ishii Motors DRL Delete DIY.
Old 06-01-2012, 12:57 PM   #6
ESBjiujitsu
MUST HAVE MORE 86 ! ! !
ESBjiujitsu's Avatar
Drives: Mazdaspeed 6 2.3 AWD Turbo
i will be spending a lot of time adding things here in the future i love me some DIY!
WISH LIST: Whiteout FRS- Bronze 18' race rims, Cooper Zeon RS3-S tires,
Cusco Coilovers, Cusco 6 point cage, CF Lip spoiler, CF F1 Mirrors, HKS GT-86 SC
92 carmy -> 86 corolla-> Honda S2000 -> Audi TT -> Mazdaspeed6 -> NEXT UP TOYOTA FT-86!!!!
ESBjiujitsu is offline   Reply With Quote
Old 06-03-2012, 12:25 PM   #7
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Just threw this together this morning! Custom BRZ/FR-S Start Up Screen walkthrough.
http://www.ft86club.com/forums/showt...243#post238243
- Matt
GrimmSpeed is offline   Reply With Quote
Old 06-03-2012, 01:49 PM   #8
DarrenDriven
NW Region Moderator
Awesome, added it to the list.
Old 06-06-2012, 01:33 PM   #9
GrimmSpeed
GrimmSpeed's Avatar
Intake removal, air filter replacement, noise generator delete!
http://www.ft86club.com/forums/showt...529#post244529
- Matt
Old 06-06-2012, 03:02 PM   #10
DarrenDriven
NW Region Moderator
Gotcha!
Old 06-07-2012, 06:42 PM   #11
GrimmSpeed
GrimmSpeed's Avatar
Exhaust System/Exhaust Manifold Removal and Replacement
http://www.ft86club.com/forums/showt...189#post247189
Thanks for organizing this!
- Matt
Old 06-08-2012, 02:37 PM   #12
DarrenDriven
NW Region Moderator
Added it! Thumbs up to the writeup!
Old 06-10-2012, 04:33 PM   #13
Lil Abner
Drives: 2013 FR-S, 6MT, Ultramarine
Changing Clock/HVAC LEDs on FR-S
http://www.ft86club.com/forums/showthread.php?t=8336
Replacing Rear View Mirror/Hardwire Radar Detector
http://www.ft86club.com/forums/showthread.php?t=8334
Lil Abner is offline   Reply With Quote
Old 06-11-2012, 12:13 PM   #14
DarrenDriven
NW Region Moderator
Added these two topics to the directory, thanks!
brz diy, fr-s diy, frs diy, scion fr-s diy, scion frs diy, subaru brz diy
FR-S / BRZ Wheel Directory, Gallery and Fitment Guide Chart DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 632 12-22-2023 09:49 AM
NW Shop Directory: Tuners, Tinters & Audio DarrenDriven Northwest 129 10-14-2022 03:29 AM
