Old 09-07-2014, 08:37 PM   #1
muffinz
Drives: 2013 DGM BRZ Ltd
Need AutoX Build Advice
Hey everyone,
So I recently sold my Ducati M696 and spent most of the profits on parts to turn my 2013 brz ltd into an autocross focused but also trackday car.
Here is what I've recently purchased:
-17x9 et35 enkei rpf1 wheels
-245/40/17 MPSS tires
-APR studs w/ mishimoto lugs
-whiteline 22mm front sway bar w/ adj endlinks (still waiting for the endlinks due to some unknown shipping / packing / wtf issue)
-whiteline 18mm rear sway bar w/ adj endlinks and bushing mounting braces
-ST XTA coilovers that apparently have adj dampening and come with camber plates (haven't arrived yet due to some stocking count issue)
-forester oil cooler "diy kit"
Existing modifications to the car:
-p3 scan gauge
-oil pressure sensor wired into the p3 gauge
-mudflaps (they actually stop rocks from hitting the rear rocker panels lol)
I plan on having a shop corner balance the car and give me a baseline suspension setup and then I will tweak it myself as much as I can through the end of the 2014 season...or 2015 season if I don't get parts in time.
The end goal is to have phenomenal handling. I don't particularly care about power at this point - I have tracked spec miata's and kept up with gt3's and m3's thru the turns on road courses (bad driver, who knows? don't care to debate that) In the future I'll probably do a header back exhaust and a mild tune to gain maybe 15 hp at the wheels.
So my questions are:
1. what did i forget? (stainless brake lines & fluid probably - how important for autox though?)
2. am i stupid for getting a rear sway bar too?
3. what's going to break first with this aggressive suspension setup?
Appreciate all the advice I may or may not get
Thanks!
muffinz is offline   Reply With Quote
Old 09-07-2014, 08:57 PM   #2
ayau
Drives: Some rust bucket
What autox classing are you going to be in? Track classing? That will determine what parts you can buy.
Old 09-07-2014, 09:00 PM   #3
muffinz
welp I already bought all the parts soooo I'm pretty sure I'll end up in STX for AutoX
as for trackdays, I will only attend non competition / HPDE events.
I'm not really interested in competition against others versus competing against myself.
Old 09-07-2014, 09:32 PM   #4
Thrustin
Drives: 2014 BRZ Limited, 2013 Focus ST
I think the oil cooler will take you out of STX.
The axles are weak, and likely to be your first repair/replacement.
Thrustin is offline   Reply With Quote
Old 09-07-2014, 09:41 PM   #5
mla163
Overthinking it
Drives: BRZ in CS
Oil cooler will bump you out of STX.
Get better tires. I don't know why everyone thinks pilot super sports are good autocross tires.
mla163 is offline   Reply With Quote
Old 09-07-2014, 09:42 PM   #6
muffinz
the oil cooler uses all OEM parts for the fa20 engine block.
I thought OEM mods were allowed?
Old 09-07-2014, 09:45 PM   #7
muffinz
honestly its probably bc of the number of positive reviews on tirerack...
what tire do you recommend and what tires have you run? do you have datalogs comparing different tires? were your different tire setups on the same suspension setup?
Old 09-07-2014, 09:59 PM   #8
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
Oil Cooler not permitted in STX,
Sell the MPSS and get tires better suited to autocross. RS3/Rival, etc etc.
Do more research, it seems you haven't done much reading as you are missing some really critical things for Street touring (which your wheels bumped you too) yet you have no other supporting mods. Check the STX thread on this board for more info. You didn't start out very well.....
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 09-07-2014, 10:04 PM   #9
muffinz
OK let me state that I don't give a sh*t about what class I end up in.
I just want a well performing car.
If you don't have an answer to the 3 questions I asked in my original post then please don't reply.
Thank you.
Old 09-07-2014, 10:17 PM   #10
Thrustin
Thank you.
If you want a "well performing car", get appropriate tires . There are really only 4-6 tire options that are competitive. Those Michelins are not one of those tires.
Old 09-07-2014, 10:22 PM   #11
muffinz
admin please delete this thread
Old 09-07-2014, 10:29 PM   #12
knipple
Drives: 2013 Ultramarine Scion FR-S
Oil Coolers are not permitted in STX for the remainder of this year.
However, per the SCCA fastracks, oil coolers will be legal next year provided that they don't require a change to the radiator.
knipple is offline   Reply With Quote
Old 09-07-2014, 10:40 PM   #13
Thrustin
lol, why?
Old 09-07-2014, 11:21 PM   #14
fstlane
fstlane's Avatar
Drives: BRZ Limited
I'll attempt to answer your questions.
1. If you plan to track the car then swapping brake fluid is highly advised. For autocross you're fine with the stock parts and stainless lines are nice but unnecessary for either application. I would also recommend a better brake pad for track use.
2. A rear bar my be beneficial for the track but I would try running just the bigger front bar for autocross.
3. Your suspension doesn't appear overly aggressive providing you don't set the ride height too low. Without drag starts and extreme axle angles your cv joints should last a long time.
Note: Michelin PSSs are a great wet/dry extreme performance tire that will work well on the street and track/autox course. Although not a 200 tread rated ultra performance tire (R-S3, ZII, Rivels) you'll probably still be running better rubber than majority of the other cars at most club levels.
Have fun with your build!
fstlane is offline   Reply With Quote
BlaineWasHere's DD/AutoX FR-S Build Thread BlaineWasHere Member's Car Journals 152 03-20-2017 12:01 AM
need advice/new to autoX Blue14inTracy Tracking / Autocross / HPDE / Drifting 27 04-09-2014 04:53 PM
AutoX summary on STX build--NOW FOR SALE!!! GTB/ZR-1 Tracking / Autocross / HPDE / Drifting 164 12-12-2013 08:52 PM
Raven FR-S AutoX Build - Ontario, Canada that_guy Member's Car Journals 5 10-31-2013 02:05 PM
Dylan's FRS AutoX RTR Build DylanFRS Tracking / Autocross / HPDE / Drifting 9 09-09-2013 11:54 AM
