Old 09-10-2014, 10:15 AM   #1
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
exhaust valves?
Literally, a valve in the exhaust. Doesn't appear to restrict flow much when open, and can create more backpressure when close (good for lower end tq?).
I know several BMWs and other cars have an active valve in their exhaust. I was wondering how effective these were, and has anyone though about getting this to work with a tune? o.O Would be pretty cool to go into "ninja-mode" whenever you want.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 09-10-2014, 10:35 AM   #2
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Well you technically cannot run the same tune with a valve in the exhaust or even a silencer for that matter. They cause so much backpressure that you get detonation running the same open tune when resteicted.
Now if you had an automatic valve that is in quiet mode under low load and opens up during wide open throttle or a different boost level you would be able to maximize the tuning in one map.
Thanks,
Phil Grabow
Element Tuning is offline   Reply With Quote
Old 09-10-2014, 11:15 AM   #3
aznatama
aznatama's Avatar
Yeah, that's basically what I was thinking. However, no way to have stock ecu support am output for an auto valve.
Ninja mode - I meant when in parking garage or quiet neighborhood at night while driving slow. Shouldn't affect an open tune, would it? Else just load different maps onto ecutek?
'14 BRZ LTD MT DGM
Old 09-10-2014, 01:08 PM   #4
Element Tuning
They make exhaust valves with an actuator built in. From what I remember they basically use a wastegate actuator so as you increase boost it automatically opens up.
Now if you're NA it could be reversed so at high vacuum it's closed. The electronic valves are too slow to use a TPS input however unless they've come out with some high speed versions.
Old 09-10-2014, 01:32 PM   #5
aznatama
aznatama's Avatar
I wonder if this is even worth tuning for... and if there's any tuner that would be willing to experiment with this...
In any case, if it'll silence the exhaust at low speeds, I might get one. Just hope the thickness won't be an issue.
'14 BRZ LTD MT DGM
Old 09-10-2014, 01:45 PM   #6
Dipstik-sportech
Dipstik-sportech's Avatar
Google a varex muffler
Old 09-10-2014, 01:55 PM   #7
aznatama
aznatama's Avatar
Seen something like that before, but I am looking for a solution that'll work w/ my planned exhaust system. I just need a solution that'll make the exhaust quiet for those nights when I have to drop someone off late at night... the tuning aspects are all just random interest.
'14 BRZ LTD MT DGM
Old 09-10-2014, 09:10 PM   #8
Turdinator
Señor Member
Turdinator's Avatar
I have had a similar idea in the back of my head for a while. I had been thinking along the lines of using one of the custom maps in ecutek to control it and maybe even linking it to the VSC system. ie quieter with all the nannies on and louder when its all off, with sport somewhere between. But that may make the tuning tougher.
1974 TA22 Celica
2013 86 GT
Old 09-14-2014, 06:47 AM   #9
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
Literally buy a perrin catback exhaust and whatever headers. It will be literally stock when puttering around town and wake up once you get in it. My mom / grandma / sister etc couldn't tell the difference between the catback and stock or between catback and the header. Or even cheaper just get headers with stock all else. Valve would be expensive and time consuming
"I love dinosaurs so much that I’ve based my life on burning as much black melted dinosaur flesh as I can on a daily basis...even the screaming sound of prehistoric reptilians being burnt through any of the classic Japanese four cylinders gives me great joy."
calmtigers is offline   Reply With Quote
Old 09-14-2014, 11:51 AM   #10
aznatama
aznatama's Avatar
That would defeat the purpose... want best of both worlds, need/want a solution.
'14 BRZ LTD MT DGM
Old 09-14-2014, 05:33 PM   #11
calmtigers
I thought the purpose you desired was something that was quiet normally but then woke up when you felt like it, otherwise it'll be fairly expensive. I dont expect this to be a sub-$1K system
Old 09-14-2014, 05:41 PM   #12
aznatama
aznatama's Avatar
Valve is like $100. Only used when slow driving in parking structure or quiet residential area. No need to tune for it, the tune was just a thought.
'14 BRZ LTD MT DGM
Old 09-14-2014, 06:48 PM   #13
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
There was a guy who did this custom exit exhaust with the help of @FT-86 SpeedFactory, but the thread escapes me
Sent from my OnePlus One
drewbot is offline   Reply With Quote
Old 09-14-2014, 07:29 PM   #14
df.dima
Drives: FR-S and Mazda 3 Sky
http://www.ft86club.com/forums/showthread.php?t=47080
df.dima is offline   Reply With Quote
Bleeder valves CB762 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 06-16-2022 12:38 AM
How Blow Off Valves Work ATSAaron Forced Induction 47 07-16-2014 07:38 PM
FS: Ferrea Valves Frs300 Engine, Exhaust, Bolt-Ons 23 01-04-2014 04:28 PM
Clamps and Check Valves for FI sw20kosh Forced Induction 1 12-17-2013 07:32 PM
