Drives: FR-S Firestorm 2013
How much difference will -5lbs make?
I want to get RP-F1s and they are approximately 5lbs less than the stockers -- how much difference will it make in handling and road feel?
I'm also considering PF-01s which are a little heavier, would I even notice a 3lb. weight reduction? Both scenarios would use stock tires for now... |
Drives: DGM BRZ 6MT
I don't know too much about it, but they say every 1lb of unsprung weight is equivalent to ~10lbs sprung weight.
In a drag race against an otherwise equivalent car? More than power bolt-ons will do.
You know you want it.
Drives: '13 FR-S
-5 is per wheel is pretty substantial. As Mike said you'll mostly notice the difference (granted it would be fairly small) in acceleration and to quite a lesser extent, braking.
The Following User _________ Stay_Puft(09-13-2014) Says Thank You to MmmHamSandwich For This Useful Post: |
You have to factor in the weight of the tires as well.
Drives: Used to Drive:Grand-Am GS #54 E36M3
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Stock tires = no change in weight...
You will not really notice a big acceleration/deceleration increase with a 5lbm unsprung weight drop, but what you will notice is a better ride quality with a more planted and secure feeling (because you have less mass trying to upset the suspension, allowing the suspension to do it's job with increased efficiency.) If you want to feel a more noticeable change in acceleration and engine response, drop down to a 205/45-17 (.3" shorter) tire... or both drop the unsprung mass 5lbs and decrease the tire diameter for the best results.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Drives: 2012 Toyota 86
i have 205/55r16 R-S3 on 16x7 rpf1s right now and it feels amazing. i would have loved 205/50, but it wasnt available in the r-s3 sadly. its only about 2lbs less per wheel, and 2 lbs less per tire than previously, but i can realy feel the difference in the suspension responding to bumps at speed. it was a bit sloppy before(mostly im assuming in part to the bulgy soft tires i had on).
#9 | |
Yeah, this is what I was thinking too. Less weight to throw the rest of the car around, and should be more responsive to turning due to lower gyroscopic effect? |
#10 |
Senior Addict
Drives: 86 GT
I recently installed 2-piece front rotors that shaved almost 8lbs in total, and I'm certain the improved ride was no placebo effect. I'm now waiting for my new wheels to arrive which will knock off another 20lbs so that's going to be interesting to see.
#11 |
Drives: Really slow
From Enkei themselves:
"Every pound of unsprung weight savings has the effect of reducing overall vehicle weight by 20lbs." http://www.enkei.com/rpf1.shtml |
#12 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
What's the stock wheel and tire combo weight again?
Edit: disregard found 42lbs, my wheel and tire combo is 45.8 lbs inflated with nitrogen. I guess it's a small price to pay for 18x10's and 265/35's
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#13 | |
Drives: Toyota
VERY interested in this setup. Have any pics please???? ![]() From what I have gathered: 16x7 +35 5x100 = 13.7-14.3 lbs (weight for this exact wheel spec isn’t listed on enkei, but these are the weights of the other wheels in diff spec but in the same size) RS3 205/55 = 22 lbs Total = 35.7-36.3 lbs Total weight reduce per wheel (41.4 lbs stock) = 5.7-5.1 lbs !!!
#14 |
So if I drop 15# per corner, that's an effective 1200# total reduction for the car, and I now have, effectively, a 1550# car...instead of a 2750# car. Gadzooks!
| Does the overpipe really make a difference? | Wise | Engine, Exhaust, Transmission | 66 | 03-02-2014 05:41 AM |
| Tires Make a Big Difference | poudre | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 08-16-2012 11:58 PM |
| Little details . . . make a difference | avusblue | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 08-10-2012 09:53 AM |
| Do intake systems really make a difference? | Echo | Engine, Exhaust, Transmission | 36 | 07-26-2012 08:09 PM |
| Little details . . . make a difference | avusblue | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-21-2012 01:00 PM |
