Drives: Subaru BRZ Limited
18x9.5 +45 fitment
Need some help, was just wondering is 18x9.5 +45 will have any fitment issues stock and/or dropped on springs 1 inch.
What else would i need to adjust to make these work if there are fitment issues. Thanks |
You should not have any fitment issues at all. However what size tires do you plan on running?
thinking 255/35, but iv read after that for the 57extremes 18x9.5 +40 all around will create issues in the front with the struts, wouldnt +45 (ssr gtv02) make it worse?
You will not be able to fit them without spacers or coilovers (smaller diameter spring). If you want a 9.5" you will need a +38 minimum.
It won't fit on stock suspension or lowering springs. We've test fitted both setups +40 and +45.
I just got 4 sets of 57xtreme in-stock yesterday and Im trying to move my last set of HKS Hypermax IV GT coilovers. Pm me and let see if we can make it work for you and eliminate all fitment issues you think you may have.
Drives: 2017 Brz Series Yellow
Drives: 13' Subaru BRZ Limited SWP 6MT
Those will clear the struts. Only issue is a good amount of poke in the front.
#9 | |
| Enkei Raijin Mesh Wheels - 18x8.5 / 18x9.5 in custom 5x100 FR-S / BRZ fitment | GuerillaRacing | Wheels and Tires | 193 | 05-26-2015 06:55 PM |
| TE37 reps. 18x9.5 +34 perfect fitment! 265/35/18 beefy tires! CHEAP!! | dOMEmE | Wheels and Tires | 18 | 05-12-2014 03:16 PM |
| Traklite Angle 18x9 FR-S BRZ Fitment $899 Shipped!!! | Dustin@Dynosty | Wheels and Tires | 77 | 12-09-2013 10:40 AM |
| Rota torque 18x9.5 +35 fitment | PB-GT86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 04-22-2013 09:08 AM |
| 18x9 wheel fitment and options? | epson1 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 07-31-2012 06:36 PM |
