Old 09-18-2014, 07:53 AM   #1
Manji
Toyotas don't have boxers
Manji's Avatar
Drives: GTV86, ISF, TE27
Lexus V8 ( 1uz-fe ) into gt86
Have been gathering up parts for my conversion over the last month. Mostly waiting on Toyota as I've only been buying new parts - apart from the motor.
Finally got stuck in today.
Did up a quick slide show here...
[ame="https://www.youtube.com/watch?v=RU0wPr28trM"]Beginning of my 1uz-fe V8 GT86 project - GTV86 - YouTube[/ame]
Manji is offline   Reply With Quote
Old 09-18-2014, 08:40 AM   #2
s2d4
s2d4's Avatar
What's your goal with it?
I would be happy with your skill level on the 86 but I am a noob so yeah.
Keep up the good work.
Old 09-18-2014, 08:58 AM   #3
Manji
Manji's Avatar
I want it to effortlessly break traction at any rev point in 3rd gear, and be able to hold 4th if I hit it. (It'll easily do both of those things)
I also want it to be bullet proof. Not these 150hp grenades with 400hp turbos attached to them for dyno numbers / highway pulls / forum wank fests. I'm talking rape it for a 90 minute session at the track over and over, then drive home, reliable.
And I also wanted a motor that could do both of those things, and also be cheap to replace should it need to be.
They're my main goals. Means I can do what I want to do in the car, and do it without mercy, but also look forward to using it on a daily basis when I'm just puttering to work and back.
Old 09-18-2014, 09:11 AM   #4
Should be interesting. I am sure you will keep us updated.
Old 09-18-2014, 10:55 AM   #5
sato
sato's Avatar
Drives: Dodge Patitas
Love these crazy build threads... sexy!
Old 09-19-2014, 11:03 AM   #6
Ammonia
Ammonia's Avatar
Drives: Whiteout FRS, Audi A4, 135i (sold)
What was the reason for picking the Lexus engine over an LS?
Can't view the pics/video at work but kudos for what I'm sure is an amazing build
boooooooooooooooooost
Ammonia is offline   Reply With Quote
Old 09-19-2014, 11:18 AM   #7
53Driver
T64-416Ax3=13,140shp
53Driver's Avatar
Drives: 2002 AP1 and 2015 F-150 EB (DD)
Possibly trying to keep it all Toyota?
53Driver is offline   Reply With Quote
Old 09-19-2014, 11:32 AM   #8
evomike
Drives: frs
he doesnt like HP
evomike is offline   Reply With Quote
Old 09-19-2014, 11:46 AM   #9
extrashaky
Drives: 2014 BRZ Limited
Considering that it's built by Subaru, that reason would seem a little silly.
Old 09-19-2014, 11:49 AM   #10
53Driver
53Driver's Avatar
True, my statement does seem a little silly now that I think about it. I'll chalk that up to this being the first time in my life where I bought car from one manufacturer that had someone else's engine in it.
Old 09-19-2014, 05:59 PM   #11
NetMagi
NetMagi's Avatar
Drives: 13 Firestorm FR-S
Because the 1UZ sounds like PURE SEXXX. At least that's why I would do it.
I very excitedly clicked on this thread, because I had this same swap in mind.
Current: 16 Porsche Cayman, 09 Tacoma 4WD, 13 Highlander 4WD, 12 Yamaha WR250R
Past: 13 10-Series FR-S, 13 FR-S, 11 S4, 07 Corolla, 98 Tacoma 4WD, 03 Corolla, 89 Camry, 90 Celica GT-S, 87 Celica GT-S
NetMagi is offline   Reply With Quote
Old 09-19-2014, 06:26 PM   #12
gramicci101
Off Topic
How much weight does the V8 add to the front of the car?
Old 09-19-2014, 06:40 PM   #13
Manji
Manji's Avatar
About 45kg is my estimate. But I've taken corner weights and will do so again once the conversion is complete.
That might sound like a lot, but keep in mind that a turbo or supercharger is adding 20 - 30kg, depending on the kit.
To get some of that weight penalty back, a smaller battery saves 10kg, decent wheels save another 8kg, two piece brake discs another 8kg.
So you're left with 10kg, maybe 20kg at most of additional front weight over the front compared with a stock 86. Which is nothing.
Its about the same as a stock 86 thats got 18x9.5 rotas with 265 tyres on the front.
Old 09-19-2014, 07:10 PM   #14
gramicci101
Off Topic
That's really not bad, actually. Maybe when putting in a small battery, you could relocate the battery to the trunk to help to balance the added weight from the block. There might be more at the front that you could relocate to the rear, as well.
Lexus RC-F GT86 with a V8? Jakeedaman21 FR-S / BRZ vs.... 12 12-18-2017 04:53 AM
Lexus IS-F or GT86 Moe AFRICA 35 11-10-2013 11:57 AM
Lexus RC Coupe based on GT86/BRZ? Getagrip Scion FR-S / Toyota 86 GT86 General Forum 32 11-06-2013 08:07 PM
Crazy question - will the FR-S/GT86 take a Lexus badge? egraphic Cosmetic Modification (Interior/Exterior/Lighting) 40 01-11-2013 03:15 PM
New Lexus ES leaked. Who said it's Camry of Lexus? Dark Other Vehicles & General Automotive Discussions 25 02-24-2012 02:34 AM
