Old 09-20-2014, 12:13 PM   #1
Astroboy
Astroboy's Avatar
Drives: None
Where should my rpms be while cruising in a turbocharged frs
I read somewhere that these cars detonate/knock between 1500-3500rpm. So my question to you guys is, where should my rpms be while cruising?
Astroboy is offline   Reply With Quote
Old 09-20-2014, 12:15 PM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
What? You heard? from who?
Old 09-20-2014, 12:50 PM   #3
Dipstik-sportech
Dipstik-sportech's Avatar
Cruise just as it would stock. It will only detonate if you have an fa20club tune
Old 09-20-2014, 01:44 PM   #4
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Crusing rpm is typically 10k. Anything below that is just absurd.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 09-20-2014, 01:48 PM   #5
dabocx
dabocx's Avatar
Drives: Scion FRS
dabocx is offline   Reply With Quote
Old 09-20-2014, 01:57 PM   #6
stonenewt
Drives: BMW 120d
As Dipstik-sportech said, if you've got detonation at low but not at high rpm at low rpm then, assuming the turbo is holding boot, it's an issue in your ECU maps.
stonenewt is offline   Reply With Quote
Old 09-20-2014, 02:50 PM   #7
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by dabocx View Post
Why the long
Old 09-21-2014, 03:59 AM   #8
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
That range is where the motor is most "knock-prone" under load. A good tune will minimize or eliminate it. This won't be a problem on cruising unless your tune is really REALLY bad.
zkv476 is offline   Reply With Quote
Old 09-21-2014, 09:59 AM   #9
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
You should be able to cruise at any reasonable RPM; it really depends on how fast you want to go and how often you want to gas up. I drove my car from Nebraska to Minnesota on Friday for a car show today and I usually cruise at ~3K RPMs in 6th gear on the hwy.
As for the turbo spooling, I usually watch my PSI/vacuum to keep it under zero (0). Usually when cruising your turbo shouldn't spool unless you additional modifications that could cause that. Overall, I have no problems doing ~400miles with temps, oil pressure and gas mileage. I think I get about 200 miles on my E85 with a 10:1 compression. I'm actually very happy since I'm pushing 20psi lol. whoop whoop.
Best of luck and hope this helps
shiro is offline   Reply With Quote
Old 09-21-2014, 10:48 AM   #10
radroach
Drives: car
I've heard on another platform, MS3, that it was bad for the engine to build boost at low RPM. I'd guess the same would apply on this engine.
Old 09-21-2014, 01:33 PM   #11
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
I would replace bad with potentially hard on the motor. If your engine wasn't designed for boost then "lugging" it at low rpm under boost could cause very high internal forces/cylinder pressures that could be problematic. But, if it's designed and tuned to take it it's not "bad".
SubieNate is offline   Reply With Quote
Old 09-21-2014, 01:47 PM   #12
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
This thread hurts my head. RHYMES
anyway, I cruise at the same RPM's as before, just don't punch it at 1,500 rpm while in 6th gear. One, you will go no where, two, heavy low for low rpm, not good.
Old 09-21-2014, 01:50 PM   #13
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
If your tune causes detonation in the rpm range the engine experiences for 80% of its lifespan, you have bigger problems than FI choice...
Whatabouteggs is offline   Reply With Quote
Old 09-21-2014, 02:06 PM   #14
Fastbrew
Drives: 2014 Pearl White BRZ
Knock knock.
Who's there?
Cruising Speed!
Cruising Speed Who?!
Because Knock Knock...
Fastbrew is offline   Reply With Quote
You may see me cruising, Illinois plates ramosryan Northern California 8 08-25-2014 04:16 PM
Highway cruising gear Spartacus BRZ First-Gen (2012+) — General Topics 95 03-15-2014 04:42 PM
High rpm cruising in 6th abutterman Issues | Warranty | Recalls / TSB 12 03-22-2013 08:38 AM
Fr-S w/ Evo X cruising in SoCal NGabriel89 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 09-12-2012 07:19 PM
Cruising Range? skoodge Scion FR-S / Toyota 86 GT86 General Forum 4 05-25-2012 03:31 AM
