Old 09-26-2014, 04:37 PM   #1
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Supercharger + Lightweight Crank Pulley?
I am about to install my HKS V2 supercharger kit and thinking whether to keep my lightweight Go Fast Bits crank pulley or put back the stock one which is almost 2.5 times heavier? Your thoughts / experience / arguments are appreciated!
Efferalgan is offline   Reply With Quote
Old 09-26-2014, 06:11 PM   #2
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
since the supercharger will add some parasitic load/loss in the lower RPM range I would definitely leave the lighter pulley to compensate some of that loss..
I was planning to add a lighter crank pulley after I added my supercharger kit but since the Kraftwerks kit uses an adaptor that is designed for the OEM crank pulley I couldn't install an aftermarket one..I will get a lighter flywheel (probably an Exedy clutch kit) so it will be easier for blipshifts/revmatching
I am not sure about the Vortech kit though
glamcem is offline   Reply With Quote
Old 09-26-2014, 11:24 PM   #3
alpax
alpax's Avatar
Drives: 2013 Subaru BRZ AT JRSC
Exactly my thought!
I do feel that loss in the lower RPM range after installing JR SC kit, and hope a lightweight crank pulley would compensate that a bit.
Would be interesting to learn from those who had this experience.
alpax is offline   Reply With Quote
Old 09-26-2014, 11:37 PM   #4
J.C.
Drives: '13 Raven FR-S
I have the full Perrin setup (LWCP + accessory pulleys) with my Innovate SC. Before adding the SC I already felt a slight improvement in throttle response with the crank pulley. IMO it wasn't worth the cost to add the other pulleys but I guess I just wanted to complete the set.
Now I'm looking into aluminum/CF driveshafts. You'll get more gains for your money with those.
J.C. is offline   Reply With Quote
Old 09-27-2014, 12:10 PM   #5
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Aftermarket with our @KraftWerks SC would be great. Maybe @KraftWerks can whip us a billet crank pulley from Skunk
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 09-29-2014, 12:23 PM   #6
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
From what I have read, light weight crank pulley + light weight flywheel = not a good idea.
One side or the other; not both. is what I was told.
*If you are considering or have done a light weight flywheel that is.
-Jack Burton
Lightweight crank pulley Vlady Engine, Exhaust, Transmission 112 01-09-2014 10:28 PM
Lightweight Crank Pulley Vlady Want-To-Buy Requests 3 01-02-2014 12:31 PM
FS: Perrin lightweight crank pulley tmccoy33 Engine, Exhaust, Bolt-Ons 1 09-12-2013 05:52 PM
FS: Kartboy Lightweight Crank Pulley OrbitalEllipses Engine, Exhaust, Bolt-Ons 6 03-21-2013 09:21 AM
My lightweight crank pulley experience WolfsFang Engine, Exhaust, Transmission 22 11-29-2012 03:15 AM
