Drives: 2013 DGM BRZ Ltd
Do I need a Strut Tower Bar?
Pretty sure the answer to the topic will be a resounding yes, but nevertheless allow me to describe my setup:
- 22mm whiteline swaybar w/ adj endlinks - ST XTA coilovers (not installed yet. will probably lower ~1" and run ~-2.5deg camber) - 17x9 RPF1's w/ 245 MPSS - APR Studs & Mishimoto lugs I plan on doing the hardest driving on track days with an occassional autox thrown in. My Questions: 1. Are the stock braces sufficient? 2. How noticeable is the difference? 3. Should I get one? 4. If I get the strut tower bar, should I get the TRD door braces too? Thanks in advance for the advice |
You would get more benefit from a few bushings instead. Front control arms especially.
- Andy |
#3 | |
How much would bushings and install cost? (I'd do it myself but I don't foresee that being an easy job & I don't have a lift) Also is there a downside to getting the strut tower bar and running it without new bushings? Will I wear out stock bushings faster with the tower bar? |
#4 | |
No downside with getting a strut tower bar first. They do make a slight difference, just IMO the bushings do more. - Andy |
#5 | |
So I did the math and the bushings you mentioned would be ~$250 plus install. I can get a strut brace for ~$150 and install it myself for free The bushings are a bit outside my budget right now. Now for the difficult questions: Would a strut top brace benefit my driving skill more or less than upgraded bushings? Would one complement the other? Would one put more stress on the car than the other? What are the appropriate steps - brace first then bushings, or bushings first then brace? |
Drives: 2014 BRZ MT (Sold); 2006 V70R
If you get a strut tower bat, get one w/ the MC brace... Also, you may need/want to get rear strut tower bar to balance out the car.
Take car to track right now, then decide what you want to change, and mod accordingly.
'14 BRZ LTD MT DGM
Its not a quantifiable upgrade on a street car. It's one of those devices that you can use to fine tune some steering feel after you have hard bushings on a car that is more stripped down. I'd say skip it unless you have money to piss away.
Drives: 2005 Toyota Camry
The answer is a resounding.... not yet.
Why? You have to ask yourself what is it about the chassis or steering feedback that you are lacking. If you are modding for the sake of modding, go for it. If you have specific goals, you need to look elsewhere. -alex |
Señor Member
Do you need one? No.
Is it a worthwhile mod? Maybe. Will you feel the difference with one installed? Probably. I would recommend the Grimspeed bar if you want one. They have a great thread on the design and testing of it. I wouldn't worry about a rear strut bar as we don't have struts in the rear. http://www.ft86club.com/forums/showt...ight=strut+bar
1974 TA22 Celica
2013 86 GT |
#10 |
Custom User Title
Drives: Asphalt FR-S MT
You don't need a bar that has a MCB. There are a few that can be installed separately. I personally can vouche for the GrimmSpeed bar (or any solid bar really). My logic would tell me to avoid anything with a hinge.
#11 |
Drives: Used to Drive:Grand-Am GS #54 E36M3
#12 | ||
my advice would be to spend money on something that is going to have a quantifiable difference instead of something like this. a track day will cost about that much money and it is probably going to make you faster than literally any other mod. tires, coilovers, superchargers included.
Drive upgrades. Don't buy them.
#13 | |
not playing cards
| "Strut" Your Stuff With A BeatRush Strut Tower Brace // DSG PERFORMANCE | Jason@DSG | Groupbuys | 14 | 12-31-2013 10:06 AM |
| WTB: Grimspeed strut tower bar in red | husker741 | Brakes, Suspension, Chassis | 0 | 10-25-2013 02:40 PM |
| Swift Strut Tower Bar | tonystewart | Brakes, Suspension, Chassis | 4 | 09-18-2013 03:34 PM |
| Rear Strut Tower? | swift996 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 11-26-2012 12:14 AM |
| FS: Tanabe Strut Tower Bar | whataboutbob | Brakes, Suspension, Chassis | 1 | 11-20-2012 01:53 PM |
