Drives: BRZ in Europe the socalled "Sport"
I rarely turn off my traction/stability control, but I think I've read that turning it off might improve acceleration (slightly.)
But in dry weather, driving at slow speeds in stop and go traffic around a small town, I don't think I actually need it. Question: Could turning it off also result in a slight improvement in fuel efficiency?
"A journey of a thousand sites begins with a single click." |
I stopped eating for a few days, mpg went up by 2.
Thought of that, but there is a trade-off. BMs will go down by the same factor.
"A journey of a thousand sites begins with a single click." Last edited by Euro; 10-04-2014 at 12:04 PM. |
Win win then.
We have to be careful, or we run the risk be being full of ...
But seriously, the traction control seems superfluous for stop and go traffic. I wonder if there is any advantage to turning it off besides drifting for fun?
Thanks
is this real life?
"Logic will get you from A to B. Imagination will take you everywhere." Albert Einstein
According to Edmund's
"For instance, with the traction control on, the manual transmission car uses 2.8 seconds to run from 45 mph to 60 mph, while under the same conditions it takes the automatic car 2.6 seconds to perform the same trick. Meanwhile, with traction control turned off, both the automatic and manual cars need 2.5 seconds to get from 45 mph to 60 mph." So turning off the TC affects acceleration. Might it also affect fuel consumption?
Boosted Member
I think you might want to research more how the traction control systems work and then you will realize why your question is pretty silly.
Unless you are cruising around town with constant wheel spin and traction control kicking in (driving like an asshole, in which case MPG is out the window anyways) then traction control is not going to come into factor with MPG.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG 2011 Honda CBR1000RR 2010 Subaru Impreza WRX PRM SSM |
I did indeed read a bit about this:
http://www.edmunds.com/car-safety/traction-control.html "The traction control system instantaneously kicks in, sensing that the wheels have begun to slip. Within a fraction of a second, this data is fed back to the control unit, which adjusts throttle input and applies braking force to slow the wheels (some older systems also retarded engine spark). The wheels are thus prevented from spinning and the car maintains maximum traction." I don't claim to know anything about the electronics involved, but from that explanation I don't see why turning it off would increase acceleration in a FR-S/BRZ going from 40 to 60. On a dry surface there is no "noticeable" wheel spinning at that speed (in my experience.) I searched in vain for an explanation for this increase in acceleration. So I also wondered if these constant throttle inputs might have a "slight" effect on mileage.
#10 |
In what way do you think it could improve mpg based on your research?
#11 | |
Drives: BMW 120d
#12 |
The Edmund's article was the most information about TC that I found, but other than the wet leaves explanation it didn't really give me a true understanding of what might be going on with all the computer input and sensors constantly feeding information.
The only thing that hit me is that I never considered turning it off in typical safe everyday driving situations. So maybe now I'll hold the button down routinely for 3 seconds. Truth be told, I'm glad to have TC on the mountain roads, but around town I think I may give it up (at least when I happen to think of i;-)
#13 |
Again, why do you think it'll improve your mpg?
I am trying to understand what you are pitching here.
#14 | |
In a traffic light environment,with straight roads on a dry day, does the TC even make sense??? Just asking, I really don't know.
| Tags |
| mileage, mpg, traction control |
| How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely | Sigh-on-Rice | DIY (Do-It-Yourself) Guides | 58 | 03-02-2015 02:48 PM |
| Traction Control vs. Stabilization Control vs. Sport Question | MurderRider | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 08-07-2014 01:56 PM |
| Why does my BRZ have LESS traction with traction control on??? | BRZnut | BRZ First-Gen (2012+) — General Topics | 19 | 12-16-2013 04:28 PM |
| CEL Traction Control ON then OFF | HATED1 | Issues | Warranty | Recalls / TSB | 5 | 09-24-2012 08:11 PM |
| Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely | BabyGodzillaGTi-R | BRZ First-Gen (2012+) — General Topics | 40 | 04-25-2012 12:20 PM |
