Old 10-12-2014, 05:40 PM   #1
KungFuWaffle
KungFuWaffle's Avatar
Drives: Whiteout
CEL and hard downshift to 1st(AT)
I made a muffler delete just as Berk's was made. Sounded great but he drone started to get to me. So I put a resonator in the middle between the two tips similar to Work's exhale AB-R exhaust. After I left the shop it was fine and everything sounded perfect barely any drone. By now the next day after install I have a CEL and when I downshift from 2nd to 1st its like a small jerk (Automatic transmission). This happened before, when I put in a K&N drop in filter but the symptoms were right away, But went away the next day. Any ideas on whats going on? I barely have 6000 miles.
KungFuWaffle is offline   Reply With Quote
Old 10-12-2014, 05:53 PM   #2
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Did you try pulling the code?
Tye300 is offline   Reply With Quote
Old 10-12-2014, 06:08 PM   #3
KungFuWaffle
Drives: Whiteout
I would've but don't have a device or anything to pull it.
Old 10-12-2014, 06:10 PM   #4
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Just don't initiate a downshift to 1st unless you're moving above 20 mph
drewbot is offline   Reply With Quote
Old 10-12-2014, 06:14 PM   #5
KungFuWaffle
Drives: Whiteout
Its whenever I come to a stop under (10-15 ) mph like a stop sign or a light.
Old 10-12-2014, 06:53 PM   #6
Krovi
Krovi's Avatar
Drives: '14 Midnight Purple FR-S
Well...
Krovi is offline   Reply With Quote
Old 10-12-2014, 07:08 PM   #7
steve99
neither a drop in filter or catback exhaust changes should cause cel code. unless something was damaged or dislodged during install ie maf sensor or hoses causing air leak or connections , O2 sensors are miles away from catback.
you need to get the code it may be totally unrelated to your mods. but car should not be getting cel light, put it back to stock tak it back to dealer
Old 10-12-2014, 07:32 PM   #8
KungFuWaffle
Drives: Whiteout
But wouldn't the CEL go on right after the install of the resonated muffler delete? Not a day later?
Old 10-12-2014, 08:02 PM   #9
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
This is a useless downshift. Let the tranny and TQ converter do it for you with less jerkiness.
-fellow AT driver
Sent from my OnePlus One
Old 10-12-2014, 08:09 PM   #10
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Why are ppl trying to downshift into 1st is beyond my....
Old 10-12-2014, 08:13 PM   #11
KungFuWaffle
Drives: Whiteout
I'm not downshifting it, the transmission downshifts it.... I'm not using the manual mode( or whatever the thing is called). When I approach a stop around 5-10 it'll go into 1st I'm assuming and I feel that jerk
Old 10-12-2014, 08:58 PM   #12
KungFuWaffle
Drives: Whiteout
Update its 2nd gear my bad
Old 10-12-2014, 09:18 PM   #13
steve99
not necessarily for example the cat efficiency cel code P0420 can take a week to appear as the ecu compares reading from the two 02 to determine if cat is working to spec. Maf cels can be like that as well its got to be outside certain limits for a period of time.
it may also be a transmission code, or cam actuator code who knows but best to get it sorted before any damage done its under warantee take it to dealer (remove your mods first)
Old 10-12-2014, 09:45 PM   #14
KungFuWaffle
Drives: Whiteout
So unbolt my muffler delete put OEM back and should I take out the k&n filter or just leave it
Rev match downshift possible with OFT Simon99 Software Tuning 24 08-17-2014 05:20 PM
downshift to first swpbrz Engine, Exhaust, Transmission 13 05-07-2014 09:33 PM
6th to 5th Downshift Crunch jcat5150 Issues | Warranty | Recalls / TSB 1 04-17-2014 04:41 PM
Rough Downshift (bog?) from 3rd to 2nd... enwave Issues | Warranty | Recalls / TSB 8 08-29-2013 01:01 PM
Downshift rattle?? driftartist Issues | Warranty | Recalls / TSB 17 08-03-2013 11:00 AM
