Old 10-16-2014, 12:41 AM   #1
IAmNotTheDriftKing
IAmNotTheDriftKing's Avatar
Drives: I own an FR-S. . . whatelse!
New rattling sound at idle
This isn't the standard sounds the engine makes. Not sure how to describe it. It happens randomly, only at idle, and you hear it from the drivers side of the engine bay. I tried to listen to it with the engine bay open, but these engines make so many noises. Car runs fine, no bogging, backfiring, nothing. It is just this strange sound at idle.
Could it be too much oil? I took it to the dealership for a free oil change(it took 3 hours, totally not worth it), and I checked the levels today(granted it was hot oil) and it was over the second line. I am writing it the instant I noticed it. I am going back when the car has cooled, making a video, and checking the level again.
IAmNotTheDriftKing is offline   Reply With Quote
Old 10-16-2014, 02:25 AM   #2
civdaddy
Drives: Slow
When did the noise start?
civdaddy is offline   Reply With Quote
Old 10-16-2014, 03:48 AM   #3
IAmNotTheDriftKing
It started today, but since I noticed it, it hasn't done it since. I couldn't get a recording because it wasn't making the sound. Might have just been me...
Old 10-16-2014, 11:36 AM   #4
As informative as the forum is I think it can also cause us to look for problems that are not really there.
Once somebody posts about a noise or such we all start looking for it to happen to us so even "normal" things start to stand out and annoy.
Just yesterday I was sitting at a light and noticed that my exhaust tone seemed to go up and down. I immediately thought "OH god idle dip"! Looked at tach and it was steady as a rock on 700. Still could hear what I thought was my exhaust going up and down. Rolled down passenger window to listen and could tell right off that it was actually the truck beside me that was making the noise and it just happened to harmonize perfectly with my exhaust tone.
The point being, if I had not read about all the idle issues I would never have know and been paranoid that it was going to happen to me.
Old 10-18-2014, 01:16 AM   #5
wtrxprs007
wtrxprs007's Avatar
Drives: 2006 Toyota Prado 4.0V6
Try taking a video of it if you can
wtrxprs007 is offline   Reply With Quote
Old 10-19-2014, 01:38 AM   #6
swpbrz
Drives: swp brz limited
I have an idle rattle like that too sometimes. Only hear it from inside but sounds like its in the engine bay. If I pop the hood and listen I can't hear it.. No death yet.
swpbrz is offline   Reply With Quote
Old 10-19-2014, 02:50 AM   #7
tyrantcf
Drives: '16 WRX, CBR1000RR
Does this only seem to happen when the car is cold? I seem to have a similar sort of ratttling sound, but I'm not sure yet if I'm just imagining it, because it seems to go away.
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
Old 10-19-2014, 04:53 PM   #8
Shady195
Drives: '13 10 Series FRS #1203
Does it sound like this? Skip to just before the 18 second mark to hear the difference in sound.. Was told its a normal sound with the DI system.
[ame]http://youtu.be/J49X663XeKA[/ame]
Shady195 is offline   Reply With Quote
Old 10-19-2014, 10:29 PM   #9
ZZT86
ZZT86's Avatar
Drives: BR86
Sounds worse than those old Astron II motors from the 80's just like cement mixers :/
ZZT86 is offline   Reply With Quote
Old 10-23-2014, 02:03 PM   #10
IAmNotTheDriftKing
Hey guys! Here is the sound. It only happens on cold days, and only after the car has warmed up a bit. I am not sure if it is the direct injectors. I have only done headers and OFT as mods, oh and a catback. . . but that isn't too major. You can't hear it on the outside, only inside.
[ame="https://www.youtube.com/watch?v=cK5Fvh-lvBw"]Scion FRS noise - YouTube[/ame]
Old 10-23-2014, 03:39 PM   #11
FRZ
FRZ's Avatar
Drives: Subaru BRZ
I think I have that noise too. Kind of sounds like a diesel engine and only happens after the car warms up and on idle. Sound disappears immediately when you step on the gas.
I think its the dreaded crickets caused by the defect in the fuel pump. If you open your hood and listen, you'll probably hear the high pitched cricket noise.
FRZ is offline   Reply With Quote
Old 10-23-2014, 04:14 PM   #12
Shady195
Sounds like the DIrect Injection, however it sounds awfully fast/loud
Old 10-23-2014, 05:45 PM   #13
aagun
Drives: 86
Press the clutch !! The sound is gone
aagun is offline   Reply With Quote
Old 10-23-2014, 07:25 PM   #14
IAmNotTheDriftKing
OFT does increase the idle to about 800 instead of 600, which might explain why it is faster. The sound is pretty much gone after 1000rpms.
Rattling sound on passenger side window G8mou BRZ First-Gen (2012+) — General Topics 7 10-17-2014 01:28 PM
Metallic Rattling sound past 4k J-Money Issues | Warranty | Recalls / TSB 2 05-05-2014 10:59 AM
Rattling Engine Noise (Video with sound) mystic Southern California 21 12-28-2013 05:11 AM
Torque dip sound: rattling / vibrating mike_ekim1024 Software Tuning 6 11-06-2013 03:17 PM
clanking sound with idle wallace03 Issues | Warranty | Recalls / TSB 4 05-08-2013 06:19 PM
