Old 10-26-2014, 01:11 AM   #1
Ultramaroon
not playing cards
Ultramaroon's Avatar
Does the clutch fake you out?
I've driven nothing but manuals as well as ridden all kinds of bikes my whole life. I have easily had clutches last over 100K miles.
The travel between touch point and full engagement on this clutch feels like it just goes on forever. I sometimes, too often for my comfort, find myself rolling on the throttle before fully engaging the clutch. So right at the worst time, when it's almost engaged, I slip and then have to either back off the throttle or dump the clutch. Either way, I cringe because it's a disaster waiting to happen.
I've adjusted it to get the touch point as low as reasonable but it's ridiculous. I know it's not me.
Has anyone played with different cylinder bore ratios to decrease the mechanical advantage of the system? Part numbers?
Edit: Also, what's this talk about a clutch delay valve? I'm not buying it.
Old 10-26-2014, 03:41 AM   #2
humfrz
Welp, I've driven clutched vehicles for over 65 years ...... and I still "kill" my FR-S on startup, from time to time.
I reckon the clutch just takes some getten used to .....
humfrz
Old 10-26-2014, 03:57 AM   #3
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
The clutch delay valve isn't something you buy.. it's already on the car. Many newer manual cars have them. It's part of manufacturers dumbing down the driving experience IMO.
Here is a post on how to remove the valve in an STI: (fwiw)
http://www.iwsti.com/forums/diy-mods...post-pics.html
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 10-26-2014, 04:09 AM   #4
Ultramaroon
not playing cards
No, sorry, I mean I'm not buying into the idea that there's some kind of clutch engagement delay valve in this thing. If you want to dump the clutch, boom - it drops.
The long throw drives me insane. I think it's what others have called the "lack of feel." I'm just used to a MUCH shorter distance between that first bite and full engagement.
Old 10-26-2014, 04:23 AM   #5
nguyen_er
nguyen_er's Avatar
Drives: 2013 Raven FR-S
Removing the clutch return spring really helps make it feel like real clutch again. It's amazing. I'll never go back.
nguyen_er is offline   Reply With Quote
Old 10-26-2014, 01:29 PM   #6
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
Yes it drives me crazy. The clutch is like this
floor|--------------------Half engaged|<|Full engaged
I feel like an idiot half the time because i'm easing off and it feels like it slaps on there at the beginning of the engagement point. You have to make an actual effort to move your foot what feels like 5" and then stop, then ease it in like a real clutch. It's like they built the throwout bearing for a clutch 5 times thicker.
Whatabouteggs is offline   Reply With Quote
Old 10-26-2014, 02:32 PM   #7
Ultramaroon
not playing cards
I know, right?! You describe it perfectly.
Old 10-26-2014, 02:36 PM   #8
Ultramaroon
not playing cards
Did you do the trick with pulling the pin? That leaves some parts just hanging up against the firewall, no? If you had to, do you think you could put it back together?
Old 10-26-2014, 02:39 PM   #9
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
It's not too bad putting it back in.
I just compressed the spring with a few zip ties, stuck it in place and then cut the zip ties.
I only put it back in because I was considering selling the car. I've since pulled the spring back out. Makes driving a lot better but it's still somewhat vague.
Old 10-26-2014, 03:07 PM   #10
stugray
Drives: 2013 GBS BRZ Limited
I hear people talk about the "long throw" in this car and I am confused.
Mine is fully disengaged after pressing it down only about 2 inches
Other people have commented on how soon it disengages.
The only time I have to push it more than a~3 inches is to start it.
I bought it used, so I am assuming that the PO adjusted it?
Old 10-26-2014, 03:11 PM   #11
Andrew025
Andrew025's Avatar
I'm assuming most people push the clutch to the floor. That's what I do.
Old 10-26-2014, 03:14 PM   #12
Ultramaroon
not playing cards
Yikes! Glad it worked out for you.
Ok, spring comes out today but I don't think I'll be finished there.
Old 10-26-2014, 03:20 PM   #13
Ultramaroon
not playing cards
Fully? Wow.
I adjusted mine within a couple weeks of driving it. The touch point is maybe an inch off of the floor.
Old 10-26-2014, 04:14 PM   #14
White64Goat
I've been driving clutch cars since I started driving with my 73 Vega GT and I have stalled this car more times than all the cars combined I have owned with a clutch, and that's a bunch of them.
Are these fake? shu5892001 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 04-11-2013 01:57 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 01:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 01:06 PM
fake Bugatti anyone? bofa Other Vehicles & General Automotive Discussions 16 07-18-2011 03:20 PM
