Old 11-09-2014, 11:34 PM   #1
Subi-Subi-Ruu
Drives: 2014 BRZ
IN: 05 GTO (built motor and rearmount turbo)
For Sale: $18500 OBO. 05 Pontiac GTO. Built 5.1L gen. 3 motor with rear mount turbocharger and manual transmission. Less than 28,000 miles and only 2 owners. Located in Elkhart Indiana.
Feel free to ask me anything. Make an offer, worst I can say is no.
[ame="https://www.youtube.com/watch?v=hlJ8nhjxKu8"]05 Pontiac GTO - YouTube[/ame]
Engine: Less than 1000 miles. Gen3 LS iron block. It is about 5.1L. Factory 4.8L crank, Eagle rods, Wiseco pistons, King bearings, Comp Cam's camshaft, push rods, and rocker trunnion kit, LS7 lifters, ported factory heads, scorpion valves, Lunati dual valve springs, Cometic head gaskets, ARP Main, rod, and head bolts, Melling oil pump, JP double roller timing set, Underdrive pulley, Poly engine and transmission mounts.
Drivetrain: ACT twin disc clutch(Less than 1000 miles) , Tick master cylinder kit, Tick speed bleeder, Driveshaft Shop single piece aluminum driveshaft, MGW-P short shifter.
Turbo setup: Professional Products intake manifold, Coated Kooks 1 7/8 long tube headers and cat-less mids, Single 3 in. wrapped pipe from mids to turbocharger, Godspeed Turbo, Wastgate, Blow off valve, intercooler, and boost controler, Fragola oil lines, Engine Gear oil pump with turbo timer wired to run pump longer after the car is shut off, 4 in. Cherry Bomb glass-pack.
Fuel system: Deatschwerks 72LB(on 3Bar) injectors, Professional Products fuel rails, Walbro fuel pump, Kenne Bell Boost-a-pump.
Exterior: Yellow with black stripes, Holden front bumper with badges, Misc Holden badges around car, Cherry Bomb exhaust tip, 2006 GTO tail lights.
Interior: Duel upper dash gauge pod with one gauge in it. AEM wideband O2, Billet aluminum floor mat clips.
Suspension: BC coil- overs and sway bar end-links, Whiteline radius rod, strut top, strut bearings, and shock bushings.
Brakes: Rotara slotted rotors, Hawk pads.
The bad: A few paint chips here and there. Turbo leaks a little oil in exhaust side, nothing that will show on the dipstick, it has no play. Tuning could use a little polishing but it is safe, ran out of nice weather to finish polishing it. Could use tires soon, but what GTO doesn't?
The whole car is in great condition and has very low miles for the year. The Interior is perfect although it is about time for a vacuuming as seen in the pics. All fluids swapped to synthetics. Garage kept and has never seen salt or snow. The sound of the exhaust is unique to the car. I have fallen out of love with the car so it is time for a new project. I enjoy building cars more than driving them. Looking for 18500 OBO. More details for serious shoppers, I did not want the ad to be overwhelmed with specs. Come check it out if your serious. Stories about not having the money or wanting to trade for your Honda econo-van are frowned upon. I am sure that I have missed a lot of other parts in this ad, just too much to remember.
So far it looks like the motor gets about 13 mpg in the city and 30+ on the highway. 99.5% streetable, Might be a little loud for your local PD. A/C and all other creature comforts still work.
Might take partial trade with a nice 5-10K dollar car. Must a be a nice FUN car. No mini vans, etc...
Call or text(text preferred) 574-226-7005
Subi-Subi-Ruu is offline   Reply With Quote
Old 11-13-2014, 06:26 PM   #2
Subi-Subi-Ruu
Drives: 2014 BRZ
Price drop. Looking to move on with my projects.
Old 11-21-2014, 08:42 PM   #3
Subi-Subi-Ruu
Drives: 2014 BRZ
Bump
Old 11-28-2014, 11:11 AM   #4
Subi-Subi-Ruu
Drives: 2014 BRZ
Bump black Friday price drop.
Old 12-14-2014, 09:59 PM   #5
Subi-Subi-Ruu
Drives: 2014 BRZ
Bump
Who has a built motor? Fabron757 Forced Induction 77 11-19-2020 11:04 PM
Frs300 Fa20club built motor and turbo build Frs300 Member's Car Journals 32 01-18-2014 06:27 AM
which built motor? Fabron757 Forced Induction 82 11-26-2013 11:08 AM
Crawford Limited Turbo BRZ - built motor Mrqb22 Forced Induction 8 11-11-2013 02:34 PM
Built motor over 600hp Fabron757 Forced Induction 19 11-02-2013 05:54 PM
