Old 12-06-2014, 07:57 PM   #1
HMX-92
Drives: 2015 FR-S Ultramarine
Can't downshift while warming up
Heya
I got a 2015 FR-S a couple of months back, and I live in Eastern Canada where it's getting rather chilly as winter is coming quick. I go to work around 8am every morning, and I've noticed a few transmission quirks(I Hope) on the drive in to the city. I can shift into Reverse, and shift up normally, but I cannot down shift at all while the car is still warming up? In the morning I generally let the car idle for a minute or two before I set off, but once I hit third, it's absolutely impossible to downshift into second unless I come to a complete stop. Is this a normal issue while the transmission is warming up, or is this something I should be taking it to the dealer about? After about 5-6 minutes of driving everything goes back to normal, and it doesn't seem to happen in the evening (yet anyway, it's still warmish for now)
HMX-92 is offline   Reply With Quote
Old 12-06-2014, 08:04 PM   #2
kodyo
Drives: Scion FR-S
It's normal. Try double clutching and replacing OEM fluid, I use Motul 300. Also make sure you are rev matching on down shifts.
kodyo is offline   Reply With Quote
Old 12-06-2014, 08:08 PM   #3
HMX-92
Yeah I read about changing the transmission/dif fluid right after I got it, guess I should stop procrastinating on that like an idiot. Good to know it's not a serious issue
Old 12-06-2014, 08:35 PM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
Great time to learn to double-clutch. With OEM gear oil, the tranny will break in nicely at around 8000-10000 Km. ...really nicely. I love mine.
Old 12-06-2014, 09:17 PM   #5
wheelhaus
wheelhaus's Avatar
I second the above posts (I live in Denver, CO) and the only things that can alleviate it are double clutching and quicker shifting (not more forceful). I'm now past 15k miles, and the tranny continues to improve little by little as the miles rack up.
wheelhaus is offline   Reply With Quote
Old 12-06-2014, 10:14 PM   #6
juliog
juliog's Avatar
Drives: 86
juliog is offline   Reply With Quote
Old 12-09-2014, 11:04 AM   #7
kthxbai
kthxbai's Avatar
Drives: '13 Whiteout FR-S M/T
I've had to experience this more and more now that I've moved to Atlanta from Central Florida. Does anyone know if there is any harm in shifting through all the gears (with the clutch in the entire time of course) after the car has initially warmed up? Would this help distribute some of the warm gear fluids before setting off on your drive?
kthxbai is offline   Reply With Quote
Old 12-09-2014, 11:40 AM   #8
frslee
Just drive it
Drives: 13' FR-S
Sounds normal for me. As long as you don't feel any grinding, you're fine. I think stock fluid gets pretty thick when it's cold, so I ended up replacing with thinner oil and shifting improved.
frslee is offline   Reply With Quote
Old 12-09-2014, 12:37 PM   #9
wheelhaus
wheelhaus's Avatar
I don't think it will help because the gears aren't rotating unless you're moving. Remember, the clutch is on the front end of the transmission, not the back end. The output shaft (and all the gears) are sitting still when you're stopped. They rotate with the rear wheels, the only disconnect is neutral or the clutch. The input shaft will move a little bit when you row through the gears, be it won't be spinning either unless you engage the clutch. If you're in neutral with the clutch engaged, then the input shaft and intermediate shaft are spinning freely inside the gears, but no gears are selected so none are moving (if they were, then the rear wheels would be moving as well).
Old 12-09-2014, 12:39 PM   #10
radroach
Drives: car
3-2 shift will always feel a bit stiffer due to triple-coned syncros, but it gets better after 10k miles.
Warmup from cold start really helps, 5-10 minutes idling and then a quick loop around the parking lot or a slow roll down the road helps out, really only necessary on freezing days, otherwise I can usually take right off after initial warm up.
Old 12-09-2014, 02:06 PM   #11
kevman_101
Drives: 2013 Scion FRS
Originally Posted by HMX-92 View Post
Heya
Whats up. Northern NBer here . You will get used to the stiff cold shifts. 2nd gear is very grumpy when it`s cold. Either up from 1st or down from 3rd. It takes a bit before it wants to cooperate. Double clutching either up or down helps very often. Other times, you just need to keep some pressure and try to match the revs just perfectly. Clutch in of course. You`ll get a hang after awhile. My 02 Sentra Spec V was a pain for 2nd too so I got used to it and the same tips helped with the FRS too.
kevman_101 is offline   Reply With Quote
Old 12-09-2014, 03:34 PM   #12
billyk
billyk's Avatar
Drives: 2014 Argento FR-S
Here's an awesome thread on this topic.
Hope it helps.
-bk
billyk is offline   Reply With Quote
Old 12-09-2014, 05:48 PM   #13
Ultramaroon
not playing cards
Hope it helps.
-bk
Thank you, Search Ninja.
Old 12-09-2014, 05:59 PM   #14
mike the snake
Your clutch adjustment might be just off enough to barely hang up when cold, this can then go away once things warm up and expand.
My trans after adjusting tighter (clutch starts being actuated earlier when you push the pedal) made everything better.
Rev match downshift possible with OFT Simon99 Software Tuning 24 08-17-2014 05:20 PM
downshift to first swpbrz Engine, Exhaust, Transmission 13 05-07-2014 09:33 PM
Question about oil warming time on startup mp22 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 03-19-2014 05:46 PM
Downshift rattle?? driftartist Issues | Warranty | Recalls / TSB 17 08-03-2013 11:00 AM
eng warming up foxhu Issues | Warranty | Recalls / TSB 8 05-08-2013 01:07 AM
