Drives: Grey GTS 86
How much extra power can I draw from the fuseboxes?
Pretty much I'm looking at adding an aftermarket amp that'll probably draw around 15A max. My question is: are there main fuses for the 2 fuseboxes (interior instrument panel fusebox and engine bay fusebox)? If so how big are they and how much headroom have I got to play with if I draw supply from one of the spare slots on either of those 2 fuseboxes? If there isn't enough "spare" amperage I'll have to draw directly from the battery but I'd like to avoid that if possible hence why I'm asking.
Thanks in advance
Drives: FRS
You should not do what you are looking to do, as the house wiring can only handle so much as well, for example if you get a 25A amp you probably want to run 8g wiring. Just my opinion. As far as the box having a master fuse, to my knowledge this does not exist.
#3 | |
Do not skimp out on power. Spend the extra $50-100 bucks for a wiring kit and take the hour or so to run those wires. |
Drives: Grey GTS 86
If the fusebox has no master fuse to protect its own wiring I wouldn't attempt it. Like you say, wouldn't want to push the stock wiring to far. I just thought there may have been some heads to play with given the number of spare fuse slots.
I love peanut butter
Drives: 2013 SWP BRZ Limited
Run a legit power line from the battery dude. Its super easy and power wire can be purchased super cheap on eBay.
Drives: 2017 Camaro 1SS
Drives: Grey GTS 86
| Amp draw | sw20kosh | Electronics | Audio | NAV | Infotainment | 4 | 08-20-2014 02:54 AM |
| REALLY, how much extra power is enough? | LBC Por Siempre | Forced Induction | 102 | 12-27-2013 04:24 PM |
| Subaru STi - flexible draw stiffener | illmatic | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 11-29-2013 12:04 PM |
| Draw your BRZ! | LeeMaster | BRZ Photos, Videos, Wallpapers, Gallery Forum | 14 | 09-26-2013 02:34 PM |
| Blow through vs draw through MAF | mrk1 | Forced Induction | 9 | 07-24-2013 08:21 AM |
