Old 12-23-2014, 02:59 PM   #1
jcw99
Drives: swp mt '14 brz premium
temperature range of differential?
I want to put a temp. gauge in my diff. this winter - does anybody know what the temp. range of a DD rear is. I live in Maryland - our temps here range from 10 F to 100 F. Thanx!
jcw99 is offline   Reply With Quote
Old 12-23-2014, 08:24 PM   #2
humfrz
I really don't know ...... but, I do feel that the differential would be one of the last of the moving parts in your car, to overheat and cause a problem .....
humfrz
Old 12-26-2014, 11:35 AM   #3
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
It's really not going to be stressed under street conditions but rear differentials can get 300 degrees in general under racing conditions. I've never actually put a temp sensor in my FRS diff however.
Element Tuning is offline   Reply With Quote
Old 12-26-2014, 06:57 PM   #4
350matt
Drives: toyota mr2/ Toyota GT86
if the oil goes over 140 degrees Celcius then it'll break down and your diff bearings will fail
so get a gauge that reads up to 140 Deg C
350matt is offline   Reply With Quote
Old 08-04-2017, 11:54 AM   #5
fika84
fika84's Avatar
I'm bringing this back from the dead!
I'm curious about the same thing, but only because I've got a mechanical LSD installed and do track days.. So I'm wondering if I'm just being paranoid, or if I should invest in a cooler or larger capacity cover. Any thoughts from the guys racing these with aftermarket diffs?
fika84 is offline   Reply With Quote
Review soon:OS Giken Super Lock Limited Slip Differential + Greddy differential cover mav1178 Engine, Exhaust, Transmission 5 02-11-2021 02:20 PM
Oil Pressure Range blackfireball5 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 135 12-10-2019 09:26 PM
Mid range really lacking goli5oda Electronics | Audio | NAV | Infotainment 4 08-19-2013 11:27 AM
Cruising Range? skoodge Scion FR-S / Toyota 86 GT86 General Forum 4 05-25-2012 03:31 AM
UK Price range £25-£32k!? ZeeSpeed Scion FR-S / Toyota 86 GT86 General Forum 56 11-27-2011 03:11 PM
