Old 01-05-2015, 06:25 PM   #1
2015 86CUP presented by Cusco-Winmax Rules thread
Welcome to the 2015 86CUP presented by Cusco-Winmax!
86CUP is the premier independently organized FRS/BRZ/AE86 Time Trial series in North America. Utilizing a ruleset that is specific to the platforms, the 86CUP aims to provide a friendly, safe environment in which 86 enthusiasts can hone their driving skills. In 2014, we saw over 70 unique participants, consisting of former Honda Challenge champions, Nissan Gran Turismo Academy finalists, and several manufacturers coming out to showcase their talents and products. Come join us at our events, get a ride, and experience the true capabilities of our platform in its native environment!
2015 86CUP Rules
MODIFICATIONS
Power, Engine, and Drivetrain
□ 0.00 - OEM, unmodified FA20 with ALL factory parts
□ 0.25 - Any aftermarket intake system or modification to OEM intake (excludes drop-in OE replacement filters, such as TRD)
□ 0.125 - Any aftermarket header with a catalytic converter
□ 0.25 - Any aftermarket header without a catalytic converter
□ 0.125 - High-flow catalytic converter front pipe
□ 0.25 - catless front pipe
□ 0.00 - Cat-back or axle-back exhaust
□ 1.00 - Internal engine modifications (pistons, rods, crank, etc.)
□ 1.00 - Built head or aftermarket head (cams, valve springs, valves, etc.)
□ 2.50 - Any Forced Induction (e.g. AVO, Greddy, Jackson Racing, Innovate, Kraftwerks, Vortech, etc); must take separate penalties for ECU, and header as applicable
□ 0.00 - Aftermarket ECU or OEM ECU reflash
□ 1.00 - E85 tune
□ 0.00 - Aftermarket Axles
□ 0.25 - Aftermarket Driveshaft
□ 1.00 - Aftermarket transmission
□ 0.25 - Non-OEM Clutch and/or Flywheel and/or Pressure Plate
□ 0.25 - Non-OEM LSD
□ 0.00 - Non-OEM Final Drive
□ 4.50 - Engine Swap (can be ANY engine, must take points individually for modifications non-OEM to that specific engine or the original chassis, e.g. headers, intake, etc.)
Wheel and Tires
□ -2.00 - Any street tire TW 320+
□ -1.00 - Any street tire TW 220-300
□ 0.00 - Any street tire: TW 140-200 **Exceptions apply
□ 2.00 - Bridgestone Potenza RE71R, BFG Rival-S
□ 1.00 - Level 1 R-compound tire (100TW)
□ 2.00 - Level 2 R-compound tire (60-80TW)
□ 3.00 - Level 3 R-compound tire (0-50TW, DOT)
□ 4.00 - Level 4 R-compound tire (non-DOT slicks)
□ 0.00 - 215 width tires
□ 0.25 - 225 width tires
□ 0.50 - 235 width tires
□ 0.75 - 245 width tires
□ 1.00 - 255+ width tires
□ 0.00 - OEM wheels
□ 0.00 - Wheel spacers
□ 0.125 - 5-7.5" width aftermarket wheels
□ 0.25 - 8" width aftermarket wheels
□ 0.375 - 8.5" width aftermarket wheels
□ 0.5 - 9" width aftermarket wheels
□ 0.625 - 9.5" width aftermarket wheels
□ 0.75 - 10+" width aftermarket wheels
Aerodynamics
□ 0.25 - Level 1 Front Aero: aftermarket front bumper or any aftermarket lip, including TRD and STi (must not have splitter built-in)
□ 0.50 - Level 2 Front Aero: full front aero package (anything more than a simple lip or bumper; can include any spats and canards, splitters)
□ 0.125 - Canard Set (each set L/R, if not combined with L2 Front Aero)
□ 0.125 - Spats only (each set L/R, if not combined with L2 Front Aero)
□ 0.25 - Level 1 Rear Aero: rear diffuser that starts behind rear axles
□ 0.50 - Level 2 Rear Aero: rear diffuser that starts in front of rear axles
□ 0.125 - Vented hood
□ 0.125 - Vented fender and/or wide fenders
□ 0.125 - Aftermarket or modified/cut rear bumper
□ 0.125 - Vortex generators
□ 0.00 - OEM rear spoiler
□ 0.25 - Aftermarket rear spoiler (e.g. 5-axis, integrated duckbill in trunk, STi gurney flap)
□ 1.50 - Level 1 Wing: APR GTC-200 (all versions), Voltex 1S wing or smaller, 245mm stands maximum
□ 2.00 - Level 2 Wing: Any adjustable wing bigger than APR GTC-200/Voltex 1S
□ 0.125 - APR 2.5” Riser (applies only to APR GTC-200)
□ 0.125 - 275mm stands (applies to Voltex 1S only)
□ 0.125 - Gurney Flap (applies to Level 1 Wing only)
□ 0.00 - OEM underbody panels, including Blue Edition panels
Suspension
□ 0.00 - Any OEM BRZ or FRS suspension
□ 0.00 - any OEM or aftermarket sway bars
□ 0.375 - Any aftermarket top hat/damper mount, including camber plates
□ 0.00 - Any camber bolts
□ 0.125 - Any rear lower control arm
□ 0.50 - Aftermarket springs with OEM dampers
□ 0.50 - Aftermarket damper with OEM springs
□ 1.00 - Aftermarket springs with any off the shelf non-adjustable dampers
□ 2.00 - Any aftermarket damper with any aftermarket spring, or any coilover suspension
□ 0.50 - Any altered suspension mounting points, including offset mounts offset spring perches
Free Modifications
- any in-cabin safety equipment
- any brake pads
- any OE replacement drop-in air filter
- any aftermarket radiator
- any oil cooler
- aftermarket brake systems, brake ducts
- any OE-replacement lightweight parts that do not also enhance performance by improving power, aerodynamics, handling, etc.*
- any interior removal as needed for safety equipment
- any alignment, and camber bolt/kit, bump steer kit, tie rod end, roll center adjuster, but not camber plates or top hats.
- any bolt-on chassis braces
- updating or backdating OEM parts
- aftermarket steering wheel: only if R/H/S are installed for driver (otherwise prohibited)
- oil-catch cans, oil baffle pan
- any battery (including lightweight alternatives)
* If you are unsure whether your modification violates these rules, please ask for clarification. If you are found to be in violation after the fact, you will be disqualified from the event.
Absolutely Prohibited
- nitrous oxide systems
- removal of vital safety equipment such as bumper beams, roll-hoops or airbags without Rollbar/Harness/HANS, etc.
**AE86 Addendum**
AE86 chassis Corollas are allowed an extra 500 lb weight allowance from each class (e.g. a Street class AE86 is allowed to be 2350 lbs, instead of 2850 lbs).
**S2000 Addendum**
Discussion is being held for a cross-over event with the AP1/AP2 chassis. Currently, the belief is that the S2000 platform performs at a level "one class higher" than the FRS/BRZ/AE86.
86CUP CLASSES
Stock Class - 0.5 points maximum
The purpose of this class is to keep costs to a minimum and be attractive to a drivers with stock or minimally modified vehicles. Drivers of all experience levels are welcome, and tires are restricted to TW 140+ and no larger than 225 width.
Certain modifications are not allowed in Stock class:
- No Level 2 Front Aero
- No Level 1+ Rear Aero
- No Level 1+ Rear Wing
- No light-weight aftermarket parts, no aftermarket body panels, or any interior removal (unless necessary for safety equipment).
- No forced induction
Street Class - 4.0 points maximum
The purpose of this class is to allow moderate modifications to a primarily street-driven car. Drivers/owners are granted flexibility in choosing different modifications, while competing in an even playing field. Street class cars typically feature one of three major areas of modifications: aerodynamics, forced induction, or substantially increased mechanical grip. 2850lbs is the minimum weight for Street class with driver and FULL tank of gas.
Modified Class – 7.0 points maximum
Modified class cars are expected to have several dedicated performance modifications. Cars in this class will typically have two of the three major areas of modifications: aerodynamics, forced induction, and mechanical grip, and are usually readily identifiable as a track driven car. 2750lbs is the minimum weight with driver and FULL tank of gas for the Modified class.
Unlimited - no maximum
Minimum weight for Unlimited is 2700 pounds with driver and full tank of gas. Who knows what you may see in this class... anything goes!
2015 86CUP Board Members: @CSG Mike @mav1178 @ImperiousRex @juliog
WEIGHING
Rules
Each class has a minimum weight: at any point during the day, a competitor with driver inside must meet that minimum weight. If and when a competitor is found to be below minimum weight, he will be penalized 1 second for every 25 pounds he is under the minimum weight. If this is the competitor’s first violation, the first 25 pounds will be allowed as leeway (for possible scale-to-scale variation), but he will be penalized for any further discrepancy. Also, if this is the first violation, he may choose to forfeit all laptimes he has accrued until the weighing process, add back weight to his car to meet minimum weight, and re-start new timed laps instead of taking a lap-time penalty. Any repeat violations will automatically incur the lap time plenty as outlined above.
Weighing Protocol
One competitor from each group (Street and Modified) may be selected at random to be weighed at any time during the day. The probability of being weighed is directly proportional to the number of points he has accrued throughout the season (for example, this is equivalent to adding one’s name in a hat once for every point he scores, then drawing from that hat at random). That means top drivers have the highest likelihood of being weighed, and drivers who have yet to score points will never be weighed.
Weighing Logistics
Two drivers from each class may volunteer or will be randomly selected to participate in the weighing process. Only drivers from a different class may weigh one class (to create impartiality). For example, if a Stock class participant is being weighed, only the two drivers from Street and two drivers from Modified may assist in the weighing process. All who participate in the S2KC implicitly agree to help with the weighing process if called upon, barring any extenuating circumstances.
PROTEST PROTOCOL
A competitor may also be spot-weighed if two peers (or at least half of the participants of that day, whichever is less) from the same class believe the competitor to be in violation of minimum weight. That competitor will be liable to be weighed on the spot. In addition, if a competitor suspects another is underrepresenting his points, he may bring his concern to a member of the 86CUP board immediately, so that a board member can audit the car at that point, and compare the setup to that declared on the signup sheet. If a participant fails the audit, he can choose to: 1) correct the violation and forfeit all a previous laps and redo timed laps for any remaining sessions; or 2) take a 1 second penalty for every 0.25 points he is over the limit.
Prizes/Points
Prizes at individual events for each class will be awarded regardless of number of competitors in the class.
Year-end prize winners need to have participated in atleast 6 events. Unclaimed prizes and prizes without a winner will be thrown into a raffle pool to be raffled to participants at the end of the year. One raffle entry will be issued to every FRS/BRZ owner who attends the season finale, even if they do not participate in any 86CUP events.
The best 8 finishes of the 13 events will count toward the championship for each class. In the event of a tie, the participant with more 1st place finishes will be awarded the championship. In the event of a tie after the first tie-breaker parameter, the participant with more attendance will be awarded the championship. If there is still a tie after the second tie-breaker parameter, the participant with the faster time at the Mazda Raceway Laguna Seca event will be awarded the win.
1st - 10 points
2nd - 7 points
3rd - 5 points
4th - 4 points
5th - 3 points
6th - 2 points
7th+ - 1 point
***The Mazda Raceway Laguna Seca event will be worth double points toward the championship***
2015 86CUP Schedule
**any changes will have as much notice as possible**
8 out of 13 events will count toward year end results, with double points for the 5/23 Mazda Raceway Laguna Seca event.
1/24/2015 Streets of Willow Springs - eXtreme Speed
2/28/2015 Buttonwillow Raceway Park - Redline Time Attack
3/29/2015 Chuckwalla Valley Raceway - Speed Ventures
4/12/2015 Buttonwillow Raceway Park - Speed Ventures
5/2/2015 Auto Club Speedway - Speed Ventures
5/23/2015 Mazda Raceway Laguna Seca - NorCal Racing Club
6/27/2015 Buttonwillow Raceway Park - NorCal Racing Club
7/11/2015 Streets of Willow Springs - Speed Ventures
8/8/2015 Auto Club Speedway - Speed Ventures
9/19/2015 Buttonwillow Raceway Park - Speed Ventures
10/31/2015 Willow Springs International Raceway - Speed Ventures
11/21/2015 Chuckwalla Valley Raceway - Speed Ventures
12/5/2015 Streets of Willow Springs - Speed Ventures
*edit 1/6/2015*
added clarification on TRD/STi lips/spoilers/gurney
*edit 1/20/2015*
edited stock/street class names to be "GT Radial Stock Class" and "GT Radial Street Class"
*edit 1/23/2015*
Separated out bottom end and top end work under engine internal modifications. Bottom end mods are now separate from top end mods (as it was before). This allows for the AE86 with an alternative 4AG to be competitive. Additionally, a built engine is now worth 2 points (via the two separate 1.0 point values).
*edit* 3/11/2015*
Updated schedule
*edit* 7/21/2015*
Added RE71R and Rival-S tire points
Old 01-05-2015, 06:25 PM   #2
Please welcome our newest Title sponsor for the 86CUP, Cusco USA! Cusco will be offering a racer discount program for active participants, and providing some incredible end-of-year prizes.
Cusco is a manufacturer of street-legal and racing products including coil-over suspension kits, suspension components, Limited Slip Differential(LSD), Clutch system and body/suspension add-on parts such as strut/under braces and roll cages.
https://www.facebook.com/CuscoUSA
http://www.cuscousainc.com/
Please welcome the first of our two Title sponsors for 2015, Winmax brake pads. Winmax is now the title sponsor for the 2nd consecutive year, and will be the 86CUP with 20 sets of W1 brake pads. Participants that win a set of brake pads may elect to upgrade to any compound in the Winmax lineup for just the different in price from the W1 to their chosen compound (it's like a 50% discount on the race pads!)
https://www.facebook.com/WinmaxUsa
http://www.winmaxusa.com/
Please welcome GT Radial to the 86CUP presented by Cusco-Winmax. GT Radial will be offering a highly aggressive contingency program that allows 86CUP participants to win free tires! Additionally, GT Radial is now the class sponsor for the Stock and Street classes. We request that you now refer to the Stock class as the "GT Radial Stock class" and the Street class as the "GT Radial Street class".
GT Radial's generous contingency program is one of the most effective ways of reducing the cost of tracking your car and competing in the 86CUP.
Participants can be eligible by following the following guidelines:
- Run two GT Radial stickers OR a GT Radial windshield banner at the 86CUP events (stickers will be supplied by GT Radial)
- Have the GT Radial Champiro SX2 on all 4 corners at the track
**GT Radial understands that most 86CUP Participants already have tires that they have purchased for 2015, or left-over tires from 2014. As such, they will only require you to be running their stickers to qualify at the first three events of 2015!
- TWO (2) GT Radial SX2 will be awarded when participants accumulate enough season championship points to hit the following milestones:
-- 8 points, 15, points, 25 points, 40 points
- Although only 8 events count toward the season championship, all 13 events count toward the contingency program!
- Each participant can win a maximum of 8 tires (two sets) through the contingency program!
- Participants in ALL classes may participate in the GT Radial contingency program!
*** GT Radial will also be providing an ADDITIONAL TWO (2) Champiro SX2 tires to the top three participants in the GT Radial Stock class, and the GT Radial Street class after the first three events, so make sure you don't miss any events to get additional free tires!
The 86CUP presented by Cusco-Winmax board hopes that you find this program valuable! Please let us know if you believe this program is beneficial to you.
Also, if you see our sponsors at an event, please stop by and say thank you to them for supporting the 86CUP!
https://www.facebook.com/GTRadialUSA
http://www.gtradial-us.com/en/
Old 01-05-2015, 06:26 PM   #3
Infographics
Old 01-05-2015, 06:26 PM   #4
Reserved as a backup.
Old 01-05-2015, 06:29 PM   #5
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Excited for this year!
-Jack Burton
Old 01-05-2015, 06:57 PM   #6
juliog
juliog's Avatar
Drives: 86
Some videos from the 2014 season:
[ame]http://www.youtube.com/watch?v=MVhWwjtseZI[/ame]
[ame]http://www.youtube.com/watch?v=HZRoxBDl5ZU[/ame]
[ame]http://www.youtube.com/watch?v=L2UldnQEDbo[/ame]
juliog is offline   Reply With Quote
Old 01-05-2015, 07:53 PM   #7
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I wish we had something like this on the East Coast.
Old 01-05-2015, 08:11 PM   #8
Why don't you organize one?
@raul
Old 01-05-2015, 08:39 PM   #9
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Me too. This will be my 1st year.
Lunatic is offline   Reply With Quote
Old 01-05-2015, 09:01 PM   #10
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Ugh I wish I could do this soooo bad. But I live in northern Oregon plus a demanding job plus a 1yr old :/ can't deeicate time for so many road trips
FRSfan111 is offline   Reply With Quote
Old 01-05-2015, 10:19 PM   #11
Cop
Cop's Avatar
Drives: 2013 FRS
Where do I sign up
Cop is offline   Reply With Quote
Old 01-05-2015, 10:24 PM   #12
Originally Posted by Cop View Post
Where do I sign up
We have three different event organizers that are on our schedule this year
www.extremespeedtrackevents.com
www.speedventures.com
www.ncracing.org
At the actual event, you'll want to fill out a tech form to class your car (ask anyone who's attended in the past to help if you have questions! It's super easy), and make sure you have timing.
Old 01-06-2015, 12:23 AM   #13
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Reserved for the reserved post's reserved post bump.
-alex
Old 01-06-2015, 01:34 PM   #14
Lonewolf
Lonewolf's Avatar
Drives: Moped
Any chance this thread can be duplicated in the California subforums? Some members who want to participate in events like this might not be seeing the details here...
2014 86CUP presented by Winmax, rules and schedule CSG Mike Tracking / Autocross / HPDE / Drifting 210 10-19-2016 03:11 PM
2014 86CUP presented by Winmax, Photos to round out the season CSG Mike Tracking / Autocross / HPDE / Drifting 2 01-06-2015 07:35 PM
2014 86CUP presented by Winmax, Photos to round out the season CSG Mike FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 01-05-2015 05:15 AM
2014 86CUP presented by Winmax Results ImperiousRex Tracking / Autocross / HPDE / Drifting 35 11-24-2014 01:57 PM
86CUP presented by Winmax Event 11 - Auto Club Speedway (ROVAL) - Nov. 22, 2014 ImperiousRex Tracking / Autocross / HPDE / Drifting 15 11-23-2014 09:23 AM
